Time differential between IP phones and computer
norman.west
We're running CUCM 6.0. Users are reporting a time differential between their IP phone and their computer/cell phone. The publisher is referenced to a NTP source and is OK. The problem is that the subscriber is not synchronized with the publisher, confirmed by ssh'ing into each server and using the command "utils ntp status". Is there a way to synchronize them or is this a bug?
6 Replies 6
htluo
Level 9
Level 9
Could you SSH into the publisher and type "utils ntp status"? Then copy/paste the screen output here.
After that, SSH into the subscriber and type "utils ntp status". Then copy/paste the screen output here.
Thanks!
Michael
http://htluo.blogspot.com
Thank you Mike.
PUB:
admin:utils ntp status
ntpd (pid 6198) is running...
remote refid st t when poll reach delay offset jitter
127.127.1.0 127.127.1.0 10 l 52 64 377 0.000 0.000 0.004
+149.179.1.29 172.24.246.14 5 u 2 64 377 53.125 3307.36 32.633
*149.179.1.30 127.127.7.1 2 u 3 64 377 61.318 -1216.4 32.312
synchronised to NTP server (149.179.1.30) at stratum 3
time correct to within 4568 ms
polling server every 64 s
Current time in UTC is : Wed Sep 2 01:53:16 UTC 2009
Current time in America/Denver is : Tue Sep 1 19:53:16 MDT 2009
SUB:
ntpd (pid 5884) is running...
*127.127.1.0 127.127.1.0 10 l 50 64 377 0.000 0.000 0.004
138.241.136.10 149.179.1.30 3 u 53 64 377 0.169 1409793 2.945
synchronised to local net at stratum 11
time correct to within 11 ms
Current time in UTC is : Wed Sep 2 01:29:56 UTC 2009
Current time in America/Denver is : Tue Sep 1 19:29:56 MDT 2009
How long the subscriber NTP has been in this status?
Due to the design of NTP protocol, the subscriber won't synchronize its time with publisher immediately.
If it took more than an hour to sync up, you should get NTP logs.
Michael
1) The problem was reported in mid-August. It's cropped up before in the March/April time frame. (I think) the cluster was rebooted at that time and that seems to have resolved it. However it's probably been drifting since then.
(2) What is the CLI syntax to obtain the ntp.log file? I'm logged into the PUB and execute the command:
"admin:file list activelog syslog" yields
CiscoSyslog CiscoSyslog.1
CiscoSyslog.2 CiscoSyslog.3
CiscoSyslog.4 boot.log
boot.log.ori cron
cron.1 csalog
csalog.0 csalog.1
csalog.2 csalog.3
maillog messages
messages.ori ntp_one_shot.sh.log
ntp_one_shot.sh.log.0 ntp_reachability.sh.log
ntp_start.sh.log ntp_stop.sh.log
ntpd.log sd_ntp.log
sd_ntp.log.0 secure
secure.1 secure.2
secure.3 secure.4
secure.ori securitylog.txt
spooler
dir count = 0, file count = 33
How do I get to view the content of the ntp file?
"admin:file view activelog syslog /sd_ntp.log" yields
Expected 1 mandatory and up to 0 non-mandatory parmeter(s)
but 2 parameter(s) were found
maybe you already figured out, but you have to put a / before syslog
JH
stratum 11 is the problem.
You must stay below 10
JH
