Time problem on Cisco IP Phone 8941
david_lozano
I have a problem with the date/time on severals Cisco IP phone 8941. We are still experiencing an issue with date/time on our IP phones - it freezes on some occasions and shows the same time since then.
If the phone has a reset, or an user logs out and login again (Extension Mobility), the time phone sets to a new value and stays there.
Version  CP-8941-K9= V01
App Load ID  SCCP 9-2-3-5
CISCO CALL MANAGER
System version: 8.5.1.12900-7
Thanks for your help,
David
Pawan Arora
Have you tried to upgrade the firmware of the 8941 IP phone.
Pawan Arora
fb_webuser
Level 6
Level 6
Does it show the correct time if you go under any menu options?
You are probably hitting this bug here:
8945 SCCP: Sometimes, phone doesn't update time in header
fixed in 9.3(1)
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl73175
Posted by WebUser Asad Raza from Cisco Support Community App
Pawan Arora
Pawan Arora
Thanks for your help.
We will uograde firmware phone.
Best Regards,
David Lozano
