TLS on 2900 and 15.7 IOS
Paul Austin
Level 4
Level 4
Hi All, I have a 2900 using c2900-universalk9-mz.SPA.157_3.M8.bin IOS. I am trying to configure TLS to and ITSP but some of the commands are not available. I am loosely following the guide - Cisco Unified Border Element Configuration Guide Through Cisco IOS XE 17.5 - SIP TLS Support on CUBE [Cisco Unified Border Element] - Cisco
Yes I now its the wrong IOS version but it was the only one I could find. Has anyone here configured TLS with version 15.7 IOS? Could someone offer a config so I can compare please?
Paul
b.winter
Have you activated the security license?
"license boot level securityk9"
Your router is end of life since yeeeears. You should replace it with a current one.
b.winter
Hi, Thats was one question I had from the start of this but couldn't find that - I suspected I had to but was misled. Yes I know they should be replaced but its a temporary solution just for now.
Then try to activate the license and reboot the router.
Afterwards, you should be able to enter security related commands.
Thanks - that was the "magic button". I did think whether I needed that enabling or not.
