Toll Fraud Prevention on CCME
J_Vansen_S
Level 3
Level 3
Hi all,
We have recently deployed a simple CCME+CUE router and ASA firewall for a client.
Apparently all calls are made through 4 FXO Anolog lines to the Telephone provider.
No Sip/h323 ITSP or etc.
My client is cautious about their analog lines being hacked to make international calls.
Is there any hardening steps that i need to make on the CCME router or ASA firewall to prevent this?
Since there is no SIP/h323 services on the network.
For prevention would it be appropriate if i were to block all incoming SIP 5060 port at the ASA firewall?
Please advise
Regards: Jocelyn
paolo bevilacqua
Any firewall or nat router blocks incoming connection by default already.
For more information on the subject, use the search box her or on cisco.com.
Thanks for the info;
I would have thought so, as firewall has implicit deny on every end of rule.
So does it mean that without doing anything else i am safe from Toll fraud at this point?
I have read that it is advisable to upgrade the IOS to 15.1(2)T since it has a Toll Fraud Enchancement feature?
I am currently running Version 15.0(1)XA.
If so; is there a cost incurred in terms of licensing to upgrade to 15.1(2)T from 15.0(1)XA
Regards: Jocelyn
You don't need improved security because the device is not reachable from the Internet.
The same security would be obtainable alsowith any other IOS version.
For updates, you need a smartnet contract.
Please remember to rate useful posts clicking on the stars below.
Thanks again for the clarification
I came across an article about UC500 breaching via the CUE voicemail module instead of WAN facing
http://community.spiceworks.com/topic/111962?page=1
Am i also safe from this breach given that i have an ASA firewall facing WAN
