Tomcat
George Clark
Level 2
Level 2
Quick question we have 7 cm servers to update tomcat cert do we have to do a csr on each server for tomcat get it signed and upload it to the same server ?
Jaime Valencia
If your version doesn't have the option for multi-san certificates when generating the CSR, yes. That's the way it was done before multi-san was an option, per server certificates.
java
if this helps, please rate
We are on cucm 11.5.1 so if we generate on publisher sign it and upload it will replicate then we don’t have to do 1 for each
Use Multi san, it update all the nodes listed. But you need to restart the tomcat service on all node. Refer the below guide.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118731-configure-san-00.html
Response Signature
