Trace Files of CUCM Call flow
fayiz husain
How can I pull and interpret the trace files of CUCM call flow?
2 Accepted Solutions
Jaime Valencia
You use RTMT to get the traces, you may want to buy a book about troubleshooting VoIP to learn how to read traces.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Hi  Jaime,
Thanks for your reply. Which book would you recommend for that??..
