10-07-2010 11:55 AM - edited 03-16-2019 01:13 AM
Hi Guys,
I have a user who’s Active Directory account is continuously being locked out by our CCM Publisher. We use LDAP authentication but we’re not quite sure what device or where the authentication attempts are coming from.
What trace would I need to run on Call Manager in order to see the authentication attempts??
Thanks in advance,
Neil
Solved! Go to Solution.
10-07-2010 01:13 PM
Since you said "I have a user who’s Active Directory account is continuously being locked out by our CCM Publisher", you must have known the user ID.
There are only two components on CUCM will initiate authentication request against LDAP - Tomcat and CTIManager.
You may get "Tomcat Security Logs" and "CTIManager logs" from CUCM and search for the user ID in problem. Then cross reference the timestamp with your Active Directory event logs.
Michael
10-07-2010 01:13 PM
Michael
10-08-2010 03:31 AM
thanks Michael, that's exactly what I was looking for.
11-27-2012 07:31 AM
I'm having a similar issue to this one and was wondering if you could shed some light on it. I examined the logs mentioned above and can see where the authentication attempt is failing every 10 minutes. However, I dont see anything that indicates what app/service/device the authentication request is originating from. Would you know where I could look for some more information?
Thanks in advance!
Stuart
05-30-2019 12:46 PM
Stuart,
Did you ever figure this out?
Justin
10-07-2010 01:14 PM
Try these, the bold letters represent the checkboxes when downloading the traces from RTMT, the rest is how to configure the debug filter level:
Cisco Serviceability > Trace > Configuration > Server IP > Directory Services > Cisco DirSync > Detailed
Cisco Serviceability > Trace > Configuration > Server IP > Database and Administration Services > Cisco CallManager User Web Service > Detailed
Collecting traces:
http://supportforums.cisco.com/docs/DOC-11588
Please rate useful posts
10-07-2010 01:21 PM
Unfortunately, neither "DirSync logs" nor "CallManager User Web Service" will show you authentication information.
Michael
10-07-2010 01:26 PM
Nice.
