Transfer licenses from 1 cucm cluster to another
Peter Coggle
Hi Experts,
Need your help.
we have 2 sites each with a CUCM cluster.
CUCM cluster A on ver 8.6
CUCM cluster B on ver 7.1.5
We would like to move all the phones on cluster B to cluster A and shut down cluster B.
Can we move the DLUs we have on CUCM cluster B to cluster A?
Thanks a lot in advance for your help.
Pete
They've done it in the past.  Your main problem is going to be moving 7.x DLUs to 8.x so they'll need to make sure you have UCSS or else there may be additional costs.  It would be the same as upgrading your 7.x cluster to 8.x.
Jaime Valencia
You need to reach licensing for this matter.
java
if this helps, please rate
Thanks  a lot for the reply.
Do you know if Cisco is OK with transferring the DLUs from one cluster to another.?
Pete
Thanks a lot for the helpful answer.
