Transfer of incoming calls based on calling numbers
Marc El Achkar
we have a BE6K.
Can we Transfer incoming calls to specifics extensions based on the calling numbers?
For example i want all incoming numbers starting with 01XXXXXX to go to 222, while 06XXXXXX to go to 223.
I use MGCP Gateway.
Best regards
Mark
Chris Deren
Here are good write ups on what to do in CUCM for MGCP:
https://www.byteworks.com/blog/calling-party-number-cpn-based-call-routing-using-cisco-unified-communications-manager-8-x-and-sip-gateway-protocol/
http://dbenda-en.blogspot.com/2013/06/cucm.html
Here is another doc talking about how to block calls based on CLI in CUCM, which can also be applied to routing, see section:
CUCM Route Next Hop by Calling Party Number
https://www.netcraftsmen.com/cisco-cucm-blocking-calls-by-calling-party-number-id/
Chris Deren
