transfer voicemails between seperate cue's
David Perez
Hello netpro!
What is needed to transfer voicemails between 2 cisco unity expresses ?
The customer has 2 sites with separate cme’s and cue's, but there is a wan connection between the sites.
For the cme’s, it is already configured to transfer calls between the sites, but they would like the ability to transfer voicemails from one extension to another extension on the other cme/cue.
CME version : 8.6
CUE : 7.3
Thank you in advance
Chris Deren
If there is no WAN there is no way to do it outside of forwarding from email client, if you had WAN connection you could integrate them via VPIM.
HTH,
Chris
