Transferring calls / groups what am i doing wrong?
thedevastator
howdy everyone
yet another problem with my cme setup , well its acutally a feature i hope someone can point me to the right direction
(quick specs )
2821 Router 1GB mem ,128mb flash , 2GB usb 24FXO slot , and a sip trunk from vodafone with 100 numbers
i have 20+ SCCP phones and 10 faxes
i can dial out using any phone , and can dial in from my test setup
im configuring departments , like sales , purchase , accounting
basicly when someone calls the main number the telehpone has to ring on the sales department , if no one answers the purchase dept has to pickup the incomming call , if they do not answer get back to the sales group again ..
so if someone dials the main line ,all the sales phones except the manager has to ring , if no answer , the purchase phones have to ring
ephone-dn  1
number 101 secondary 0262610290 ( THIS IS A TEST NUMBER)
pickup-group 1
name PURCHASE1
preference 0 secondary 1
hold-alert 30 originator
ephone-dn  13
number 122 secondary 0869100122
pickup-group 5
name SALES1
both groups need to able to answer the lines from one another
secondy if i call the main line and try to foward it to the sales , main line = 100 , 101 picks up purchase1, presses button transfer dials 104 purchase3
the display of purchase3 phone will read another phone instead of 101
anyone has an idea ?
3 Accepted Solutions
Hi Vincent.
Under ephone-dn add pickup-call any-group so that users can press GPickUp Softkey followed by * to pickup a call from any other pickup groups.
Please refer to the following doc.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1182075
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Vincent,
the phone 1 ( 101 ) answers , asks the customer whom it might need , presses transfer button , dials 104
104 answers call from (102) which should be 101 - Your ephone-dn is not set up as dual-line.
Set up like this it will work fine.
ephone-dn 1 dual-line
Rate all the helpful post.
Manish
Check by adding this
Router(config)#telephony-service
Router(config-telephony)# transfer-pattern .T
If that doesnt work send accross debug ccsip mess and debug voice ccapi inout.
Manish
7 Replies 7
Hi Vincent.
Carlo
Hi carlo ,
once again thanks for your quick reply .. so in essence i have to fill the ephone-dn's with "pickup-call any-group"
when i do that , any ephone-dn can pickup any group ? Example , LOGISTICS can take over a call from group SALES ?
i need to test that will get back to you on that tommorow when i have tested that
got an idea i can transfer calls ? example :
- a customer dials 111111100
Hi Vincent,
Manish
indeed
only i now face one problem , when i receive a call and want to transfer that to an external phone number EG more as 4 digits it doesnt work ..?
Make sure that you have the dail-peers to reach the 4 digit numbers.
hi , mohammed
the dailpeers i think are functioning fine , however maybe ill clarify
101 gets a call , 101 needs to consult a co-worker and dials 128 , 128 picks up the phone but has to verify with another office using an external number using a short list and dials #190, when 128 tries to dial , but gets unknown number
Manish
