Transferring from FXO to FXO
recep.sefer
How can I disable outside calls from fxo
to be transferred to outside.
Under
Telephony-Service
transfer-pattern (1-8)...
does it, but disables transfer from inside also
Are there any solution?
TANKS
5 Replies 5
paolo bevilacqua
How you extensions are numbered, how the external numbers, and do you use an access digit for outside calls ?
Outside calls starts with 9T and 2...
Please, can you expand? What is 2.. ?
Excuse me,
Extensions are 3-digits, starts with (2)
2..
To outside access (9) is pressed
9T
Try transfer-pattern 9T
