Translation rule logs on CUBE
Fatih Cetin
Hello everybody,
I've created some translation rules on CUBE so that some IP phones will not be able to call some certain outside numbers, they are rejected/blocked on CUBE. The system works fine. I don't know if there is a logging system on CUBE which shows the rejected/blocked call attempts. Does CUBE have this kind of capability?
Thank you,
Fatih
paolo bevilacqua
There is no special logging for that.
You can enable debugs to see the attempts.
However normally, call blocking is doen using COR, ot translations
Hello Paolo,
Thanks for the answer. I've found examples of how to use COR on CME, but I couldn't find any example for CUBE. For CME, you can assign the COR to the ephones but how can I do that for a specific group of numbers on CUBE? Do you have any idea?
Fatih.
You assign corlist commands to dial-peer as necessary.
There were good documents about, now it seems the search engine is not able to find them.
