04-29-2012 07:28 PM - edited 03-16-2019 10:53 AM
Hi All,
I have desgined an translation rule for in bound call its working fine
voice translation-rule 1
rule 1 /^.*\(....\)/ /5489\1/
But I also want when some call some specific numbers in the same DID range whose last 4digts are like 4300 it should replaced with 54894241 insted of 54894300. I tried some transaltion rule that doen't work.
04-29-2012 08:02 PM
rule 1 /^54894300/ /54894241/
remember you can test this rule as follows:
test voice translation-rule 1 54894300
04-29-2012 10:51 PM
Hi Mink
Thanks for yor reply.Its not working.
My senario is like this I have an DID for incoming 4750XXXX when some call came in it translate last 4 digit and land to the internal extension 5489XXXX and it's working working fine with the dial peeer mentioned in the mail. But I want one specific number in DID to land on another internal number i.e when call came on 47504300 it should translate to 54894321 insted of 54894300 and rest all the numbers of DID range keep on translating in the same way.
04-29-2012 10:59 PM
You can use
rule 1 /^47504300/ /54894321/
rule 2 /^4750\[^4]\[^3]\[^0]\[^0]/ /5489\1\2\3\4/
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
