translation-rule
Hi Pro.
i have a CME router.
the number we are receiving in directory without 00 in front and the user cannot dial from directory.
i have to create translation rule incoming,so that it changes all the incoming international number with 00 in front.
thxx
8 Replies 8
Jaime Valencia
it's a little tricky since you never know how many digits you're going to receive but you can try something like this:
voice translation-rule 1
rule 1 /\(^.......$\)/ /\1/
rule 2 /\(^..........$\)/ /\1/
rule 3 /\(^.*\)/ /00\1/
voice translation-profile profile1
translate calling 1
dial-peer voice 10 pots
translation-profile incoming profile1
incoming called number .
7 & 10 digit incoming will match rule 1 or 2 and anything else will match the last rule which will add the 00 in front of the received digits
java
if this helps, please rate
Thxx for reply..
We have 8 digits dialing inside the country and we dont have codes for cities. I want translation rule for international and i dont wanna change anything with the local numbers. Also we are not using 9 to dial outside.
this won't affect outside dialing, just how the call is presented to the called party for incoming calls
rule 1 /\(^........$\)/ /\1/
rule 2 /\(^.*\)/ /00\1/
if everything else incoming is only 8 digits change it like above, the 1st rule will always match 8 digits and won't add anything, anything that doesn't match that, will be prefixed with 00
java
i will check this out tommorrow..
i hope it works fine..
thxx again for your kind time..
hi..
sorry for being late i was not in the town..
i tried this one but its not working..
In the "incoming called number" promt what should i write,the DID number range.
when i tried putting this translation rule to one of the extension then the DID calls were not coming to that number.
voice translation-rule 2
voice translation-profile profile2
translate calling 2
dial-peer voice 123 pots
incoming called number 0788
the calls to extension 788 stopped working..
we are using primary extensiona as 0788/
paolo bevilacqua
That works fine for me:
rule 1 // /00/ type international international
The important thing is that incoming international are correctly marked as such in the setup message.
hi i have COR list for outgoing numbers..
i will post the dial-peer config here..
i have one more issue here..and i relate it with dial-peer probably as i understand..
when i call a PSTN number which is switched off, the calling number gets callback tone and keeps ringing though it should say the number is not reachable
what you get when calling numbers that are "switched off", depends by telco, and you cannot do anything about it.
The COR list has nothing to do with the translation-rule question, have you tried it ?
