Translation rules in Cisco ISR4431/K9
Dear all
We are in the process of upgrading Cisco voip routers from 38XX  to 44XX routers , we found one of the translation rule which works on 3825 doesn't seems be work with 4431 .
Translation rule
voice translation-rule 2002
rule 1 /^7\(5490$\)/ /*89392\1/
In 3825
voip-01#test voice translation-rule 2002 75490
Matched with rule 1
Original number: 75490 Translated number: *893925490
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
ios - c3845-ipvoicek9-mz.151-4.M10.bin
In 4431
Matched with rule 1
ios - isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
There was no config changes as this is just replacement.
Please help to check.
Mohamed
6 Replies 6
Manish Gogna
Hi Mohamed,
I am not aware of any such limitation or diff behavior of translation rules in ISR 4K compared to other routers, can you configure any other similar translation rule for testing and see if it also faces same issue.
Manish
Hi Manish
For this rule it translates good
rule 2 /^7\(555[12]$\)/ /*89392\1/
voip-01#test voice translation-rule 2002 75552
Matched with rule 2
Original number: 75552 Translated number: *893925552
but not with
Strange ...
Mohamed
Hi Mohamed,
Yes, that's odd, if you have already tried deleting that translation rule, restarting router and re-adding the rule and issue still persists then i will suggest checking this with TAC.
Manish
Hi Manish
Tried again , remove / restart / add but didnt help . Will contact TAC.
Thanks for your help.
Mohamed
Hi Mohamed,
Can you provide below debugs while testing this scenario:
Basic Debugs
debug dial-peer
debug voip ccapi inout
If you have configured "translation-rule",
   "debug translation"
If you have configured "voice translation-rule", "voice translation-profile",
  "debug voice translation"
Can you please share your solution working with TAC.
