trasferimento chiamata
nettuno8_20111
Hi, I have 8854 SIP IP phones, and I have a problem with call transfer. When an IP phone transfers a call and then I want to resume it, it doesn't resume it, how can I do it?
21 Replies 21
Thanks a lot for your video,
What is the value of max calls and busy trigger on both phones directory number?
Carlo
Please rate all helpful posts "The more you help the more you learn"
the number of call that triggers call forward busy per line button e 2
Can you please send a cucm trace from Realtime monitoring tool so we can dig more on your issue?
Carlo
Hi, I'm ready to connect to Webex
Hi, I can't find a solution regarding call forwarding. Can anyone help me? Thank you.
Can you provide a trace files from the CallManager service that includes the call as suggested by @Carlo Poggiarelli ? Without that it is difficult to diagnose a problem like you are describing.
Maren
