06-17-2013 11:17 AM - edited 03-16-2019 05:55 PM
Hi guys
First.. Apologize my english, i know that it's not the best
I'm having problems trying to use the Cisco Small Bussines SPA112 with my CME. I use the CME with Cisco IP Phone 7942 and it works fine. Today i tried to add an extension for an analog phone with the ATA with this config:
ephone-dn 76 dual-line
number 502
description SJO
name SJO
corlist incoming Perfil-0
ephone 76
mac-address ACF2.C536.490C
max-calls-per-button 2
type ata
button 1:76
And in ATA config i set the proxy IP: 10.10.10.225, display name and user ID: 502
But it doesn't work
By the way, i configured the ATA to work with another PBX (NeXspan and configuring only proxy IP and userd ID in ATA) and it works correctly, but i really need to get the ATA working with the CME.
May you help me?
If you need more detailed configuration, i'll post it here.
Thanks in advance!
Solved! Go to Solution.
06-17-2013 01:59 PM
I'll try again, hope you can understand it better:
SPAxx must be configured as a third-party SIP phone. Not as a Cisco phone. It is not like the ATA186.
06-17-2013 12:08 PM
SPA112 is a SIP device, so you need to configure it like that.
You can search the forum for "third party SIP phone", there are many threads about.
06-17-2013 12:52 PM
Thank you for your answer Paolo!
When i set the type of terminal on CME, i've the following list:
12SP 12SP+ and 30VIP phones
6901 Cisco IP Phone 6901
6911 Cisco IP Phone 6911
6921 Cisco IP Phone 6921
6941 Cisco IP Phone 6941
6961 Cisco IP Phone 6961
7902 Cisco IP Phone 7902
7905 Cisco IP Phone 7905
7906 Cisco IP Phone 7906
7910 Cisco IP Phone 7910
7911 Cisco IP Phone 7911
7912 Cisco IP Phone 7912
7920 Cisco IP Phone 7920
7921 Cisco IP Phone 7921
7925 Cisco IP Phone 7925
7926 Cisco IP Phone 7926
7931 Cisco IP Phone 7931
7935 Cisco IP Conference Station 7935
7936 Cisco IP Phone 7936
7937 Cisco IP Conference Station 7937
7940 Cisco IP Phone 7940
7941 Cisco IP Phone 7941
7941GE Cisco IP Phone 7941GE
7942 Cisco IP Phone 7942
7945 Cisco IP Phone 7945
7960 Cisco IP Phone 7960
7961 Cisco IP Phone 7961
7961GE Cisco IP Phone 7961GE
7962 Cisco IP Phone 7962
7965 Cisco IP Phone 7965
7970 Cisco IP Phone 7970
7971 Cisco IP Phone 7971
7975 Cisco IP Phone 7975
7985 Cisco IP Phone 7985
CIPC Cisco IP Communicator
IP-STE SCCP IP STE
anl SCCP Gateway (AN)
ata ATA phone emulation for analog phone
bri SCCP Gateway (BR)
I've tried with 7942, ATA, CIPC, 12SP but still no working
Do i need to try with all models? I remember that with CME 3.0 and 3.1, the ATA 186 was recognized as 7960. I've also tried 7960.
Thanks!
06-17-2013 01:59 PM
06-18-2013 08:59 AM
Ok Paolo now all it's clear. Thank you for your help! That was the problem.
I set up the device as SIP device and other model. Now i have both ports of SPA112 in use.
Now i've dial tone, and i can receive calls, hear and in the other side of the call people can hear me. But when i'm trying to make calls, i receive a reorder tone. I've changed my dial plan to (xx.) but same result.
I tried ticking and unticking "use outbound proxy", "NAT mapping enable", "Keep NAT alive" but still get reorder tone.
Any idea, Paolo?
P.S. Syslog server is receiving few of this: SIP/2.0 489 BadEvent- `Malformed/Unsupported Event
06-19-2013 12:00 AM
You can take "debug ccsip message" with "term mon" on CME.
06-20-2013 11:45 AM
I really appreciated your time and help Paolo. Now my SPA is working fine! Last problem was due codec configuration.
Thank you!
06-20-2013 09:08 PM
Thank you for the nice rating and good luck!
11-10-2015 10:19 AM
Hi Paolo,
I have a working CME 2951/K9 , want to setup analogue fax machine. For that I bought 2 SPA112. Can you help me to know if this can be possible on this CME, if yes then what all I need to check.
01-03-2018 01:32 PM
Can you share the configuration for the CME for registering SPA 112? I have configured it as a SIP device and it is not registering. The CME is not responding to the SIP register requests. I have my configuration and screen shot of the packet capture on the post below:
