Troubleshoot / debug dial-peer and call routing on CME / UC-540
rochdalemis
What debug commands I can use to see which dial peers match a phone number dialed and which dial peer is actually used to route a call?  I also want to see which port the call is routed through.
I plan to use csim start command from CLI to test routing.
Thanks for your help in advance!
Greg
6 Replies 6
Jaime Valencia
I usually use the debug voip ccapi inout to debug any routing issues, it will give you the whole bulk of info for the call.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Javalenc, I have tried to use debug voice ccapi all and while it was providing info on called number and chosen dial peer, the call, actually, was going through another dial peer. So, perhaps, I was looking at a different level.
I have an overlapping dial-peers (FXO and SIP), and while debug shows that a peer associated with an FXO port is used, the call actually goes through SIP trunk.
Any thoughts?
Thanks in advance,
Greg
That would totally depend on your dial-peer configuration, preference and hunting mechanism
You'd need to post your config for anyone to help.
java
java
Ok, but is there a way to see what decisions IOS makes as it goes through a list of configured dial peers, preferences, hunting groups?
I already posted a question here, but received back only what I already knew.
Briefly, below is what I have. When a number such as 3550000 is dialed, the call always goes through SIP trunk. changing pattern to 35..$ removes the dial peer from match report (debug voice dialpeer all), but the end result does not change.
dial-peer voice 80 pots
preference 7
destination-pattern [2-9]......$
port 0/1/0
dial-peer voice 81 pots
preference 5
port 0/1/1
dial-peer voice 82 pots
preference 3
port 0/1/2
dial-peer voice 83 pots
preference 1
port 0/1/3
dial-peer voice 84 pots
preference 6
port 0/2/0
dial-peer voice 85 pots
preference 4
port 0/2/1
dial-peer voice 86 pots
preference 2
port 0/2/2
dial-peer voice 87 pots
preference 8
port 0/2/3
dial-peer voice 900 voip
preference 10
destination-pattern 35..
session target ipv4:172.17.10.7
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer hunt 2
Having an ability to see IOS decision making process would help to understand why things don't work.
"Debug voip ccapi inout"  will tell you which Dial-peers are being matched.  If you search in the text for "outgoing
dial-peer" you will see which dial-peer it is matching.
Looking at your FXO setup, you might have an easier time setting up a Trunk Group for all FXO lines to be in.  This way, you don't have to create 8 differenct dial-peers for one dial-string.
Adam Compton
sanjay.khurana
Hi ,
I have two site where uc540 is installed and site to site calling working fine ealier.
Now I m facing issue from site A I am not able to dial site B number , where Site B is able to dial Site A no.
when I dial 022012 ext from Site A to Site B getting unknown number.
following is config of Site A.
dial-peer voice 2101 voip
 corlist incoming call-internal
 description **CCA*INTERSITE outbound calls to Site B
 translation-profile outgoing multisiteOutbound
 destination-pattern 02....
 voice-class h323 1
 session target ipv4:192.168.2.1
 fax protocol cisco
 no vad
voice translation-profile multisiteOutbound
 translate calling 1114
voice translation-rule 1114
 rule 1 /\(^....$\)/ /01\1/
Site B.
 description **CCA*INTERSITE outbound calls to Site A
 voice-class h323 1
 fax protocol cisco
 no vad
Debug voip ccapi inout logs of Site A & Site B is attached.
pls help me where I am wrong.
