ā02-08-2016 03:43 AM - edited ā03-18-2019 11:47 AM
can any one help me
Solved! Go to Solution.
ā02-08-2016 04:33 AM
Configure voice-class codec with at least G711u, G711a and G729, and assign it to outbound dial peer. Then make test call and share the output of debug ccsip messages and debug voice ccapi inout.
- Vivek
ā02-08-2016 03:49 AM
You are too short in asking question :)
Seems issue with codec. Check with your provider which all codecs are supported and configure gateway accordingly. If you are not sure, try to send all codecs (whatever possible) and see if it makes any change.
- Vivek
ā02-08-2016 04:09 AM
i have this message on debug ccsip messages:
SIP/2.0 503 Service Unavailable - registrar unavail or not enabled
ā02-08-2016 04:12 AM
Ok, then as asked by Deji, please provide more information about exact call flow.
- Vivek
ā02-08-2016 04:29 AM
im using cisco UC 560 i have configured a trunk sip with the provider
UC560 address 172.16.10.2
trunk sip : 172.16.10.1
dial-peer voice 136 voip
corlist outgoing call-national
description **outgoing sip trunk**
destination-pattern 0[237549].......
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 604 voip
description *** Appels entrants par SIP TRUNK GSM ***
translation-profile incoming ENTRANT
incoming called-number .T
dtmf-relay rtp-nte
codec g711alaw
no vad
ā02-08-2016 04:31 AM
087162: //16932/20CE0C24916B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 488 Not Acceptable Media
Via: SIP/2.0/UDP 172.16.10.2:5060;branch=z9hG4bK3DD91D2A
From: "Salle Serveur" <sip:312@172.16.10.1>;tag=A326A18-1AD6
To: <sip:020879800@172.16.10.1>;tag=E464B90-2153
Date: Mon, 08 Feb 2016 12:07:00 GMT
Call-ID: 2178558D-CD9211E5-9170B3C8-1F63F375@172.16.10.2
Timestamp: 1454932721
CSeq: 101 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-15.3.3.M5
Content-Length: 0
- Vivek
ā02-08-2016 04:03 AM
What is your call flow. What devices are involved in this solution. We need more details before we can help
