10-23-2014 04:04 AM - edited 03-17-2019 12:39 AM
How possible to perform direct call between two VoiP routers, such as I have one office with 2921 CUCME+VOip users and another one office with CUCME 2921+VOip users, how users perform VOIP call between these networks.
Solved! Go to Solution.
10-23-2014 06:45 AM
In addition to dial-peers add the following on both sides:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
Depending on which protocol you are using SIP vs H323 you may need some of the above.
Chris
10-27-2014 07:50 AM
Great, let us know if there is anything else you need, otherwise please mark it as answered.
10-23-2014 06:45 AM
voice service voip
Chris
10-27-2014 07:15 AM
Thank you Chris.
Just one moment. As far as I understand dial peer trunk between both C2921 with CUCME will be SIP or H323 according to your config? And I should choose one of it. Am I right?
10-27-2014 07:23 AM
The config I provided would allow for either, the protocol is driven by the dial-peer configuration, if you have "session protocol sipv2" under the dial-peer then it's SIP, if there is no such line then it's H.323.
10-23-2014 10:34 PM
configure dial-peers from router to router and back
or share your config and I will do
10-27-2014 07:20 AM
Thank you, for support.
Just want to do it by myself, its more interesting than someone else )).
Also I downloaded of very usefull manual here http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.pdf
10-27-2014 07:50 AM
