10-30-2021 02:12 PM
i have two cisco cp-8841 sitting next to each other, & one line drop between the two of them. How do I make this work ?
can I use a hub/switch, do I plug one
in to power so it’s not POE ?
please help me find a Solution.
10-30-2021 05:01 PM - edited 10-30-2021 06:11 PM
You cannot daisy chain two 8841. its not a right design or a right solution.
if you have only one cable , connected the cable to a small POE switch. And connect the two phones to the POE.
10-30-2021 06:14 PM - edited 10-30-2021 06:14 PM
Put a PoE switch on that desk.
There are switch models that are "fanless" and do not generate any noise. An example is the 2960CX/3560CX or the Cisco Micro Switch.
