10-25-2021 03:27 AM
Hi to all
I will must migrate a customer's CUCM cluster from 11.5 to 14.x, and I will try to use a PDC to do it.
User's guide explain how to do this, but i have a question about this.
To create vServers with 11.5 software I have used .ova files for that version. PDC migrate to version 14. but at the end of that I will have a cluster migrated to version 14, but my vServer are reimain created with OVA 11.5 version.
My question are:
1 - this is an accettible solution?
2 - If I must create a SR, I will have some problem with this configuration?
Or after migration I must do a backup from new version 14, ri-create a new vServer with right version's OVA, and finally restore backup ???
thank you very much for help
Fabio
Solved! Go to Solution.
10-30-2021 12:53 PM
Hi Nithin
I'm sorry for delay in my answer.
Thanks for your help. I'll follow your advice
Fabio.
10-25-2021 03:55 AM
Why do you map the 11.5 OVA ? You need to use the 14 OVA when mapping the VM's on define migrations cluster step)
Below mentioned will be the steps.. There is also a dCloud lab available for PCD. you can make use of it.
You can also use below video to understand the PCD migration.
https://www.youtube.com/watch?v=Kd7dvvP103E
10-25-2021 04:05 AM
Hi Nithin
Thanks so much for your help.
I didn't realize that I could create a new cluster with the correct version of the OVA file and then migrate from the old cluster to the new cluster.
I thought the update was done on the same servers. I'll do a test in my lab first
and I will clearly look at the link to the video you sent me
thank you again
Fabio
10-25-2021 04:09 AM
When we say migrations, its from one hardware to another.When we say upgrade, we bring the same server to the latest versions. Whats your case? is it migrations or upgrade ?
10-25-2021 04:14 AM
Hi Nithin
you have right.
In my case is un upgrade version from 11.5 to 14.x, not migration. HW is the same.
Fabio
10-25-2021 04:23 AM - edited 10-25-2021 04:24 AM
In that case ignore my Previous post, thats applicable for Migrations.
For Upgrades, You need to read Upgrade/ Migrations guide, Release notes and readme file along with the PCD guide .
10-30-2021 12:53 PM
Hi Nithin
Fabio.
