I have two sites/offices within the same city. I am going to use a block of 10 DID's from office A for office B. They are on the same MPLS network so office A is 10.10.10.0/24 and office be will be 10.10.20.0/24. Calls will be coming into site A on their PRI and then sent over IP to Site B if it's on of the DID's in the block of 10.
Does anyone have an example of a dial-peer config they've done to handle this? I'm assuming the following.
Site A dial peer
dial-peer voice 200 voip
description Site A to Site B for 10 DID block
destination-pattern 123456789[0-9]
session-target ipv4:10.10.20.XX (site B)
dtmf-relay h245alphanumeric
no vad
Site B dial peer
This would just be a normal dial peer sending all out bound digits to our CUCM.
Am I way off here?
