UC-560 Calls dropped after transferring
mcevoyoliveoil
A call comes in, the receptionist answers it, transferrs the call to an extension & the peson is not available to answer so the receptionist resumes the call.  About 10 seconds later the call is terminated without a warning or a sound.
Does anyone know why this happens?  IT happens every time these situation occurs.
Dana
6 Replies 6
paolo bevilacqua
Which exact IOS are you running ?
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.0(1)XA, RELEASE SOFTWARE (fc2)
I tried to understand if release 8.0.5 for UC560 contains newer software, but failed. Please check yourself and update as necessary.
Marcel Ammann
Level 3
Level 3
could you post your configuration?
Is the error only on this phone?
Kind regards,
Marcel Ammann
Calls are dropped from all phones (509G & 7965) after attempting to transfer them and subesquently resuming the call.  Once the call is resumed it drops after 10 seconds.  Below is the current running config.
UC_560
Home Exec Configure
------------------ show version ------------------
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 22-Oct-09 06:29 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)XA, RELEASE SOFTWARE (fc1)
UC_560 uptime is 7 weeks, 6 days, 21 hours, 59 minutes
System returned to ROM by reload at 19:14:27 PDT Tue Oct 12 2010
System restarted at 19:15:36 PDT Tue Oct 12 2010
System image file is "flash:uc500-advipservicesk9-mz.150-1.XA"
Last reload reason: Reload Command
Cisco
UC560-T1E1-K9 (MPC8378) processor (revision 0x100) with 511180K/13108K bytes of memory.
Processor board ID FHK1427F48H
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
56 User Licenses
4 Gigabit Ethernet interfaces
24 Serial interfaces
2 terminal lines
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
8 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
64K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID   SN
*0     UC560-T1E1-K9         Serial # Was Here
------------------ show running-config ------------------
Building configuration...
Current configuration : 63438 bytes
! Last configuration change at 06:59:42 PST Tue Nov 30 2010
! NVRAM config last updated at 15:38:15 PST Tue Dec 7 2010
version 15.0
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname UC_560
boot-start-marker
boot-end-marker
card type t1 0 3
no logging queue-limit
no logging buffered
no logging rate-limit
enable secret 5
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
crypto pki trustpoint TP-self-signed-1340681818
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1340681818
revocation-check none
rsakeypair TP-self-signed-1340681818
crypto pki certificate chain TP-self-signed-1340681818
certificate self-signed 01
  3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31333430 36383138 3138301E 170D3130 31303133 30323136
  32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33343036
  38313831 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CBE0 09D7149D 906F07E3 9F8E23E6 96549E34 408B2514 555699A4 DD65AD44
  8801DA8C 7180B1A0 FFBBDE69 8816B887 67F36485 BE6F0453 2D208FEA AC482E92
  3CDA9E3C D6E9F2F1 BC3E1961 0D432EFF E4A72204 2EB52A2D AAF571A2 A264E353
  026FE2A7 5D14F875 104E03C1 EFD57214 D2CAAE36 816E97A4 3F37D64B 457BFFEA
  12AB0203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
  551D1104 0A300882 0655435F 35363030 1F060355 1D230418 30168014 3F132CC2
  2D3D5D9E F18D15B1 3F00FC46 44487D9F 301D0603 551D0E04 1604143F 132CC22D
  3D5D9EF1 8D15B13F 00FC4644 487D9F30 0D06092A 864886F7 0D010104 05000381
  81000B5E 81E26F34 E21ACF2E 5109F065 D7D93C8A 3B378E6C D3226EC4 BA04E697
  942A02F9 1BB423AD 401798B1 70B01E82 82B711E9 BB5C9F6C 8F5BDF4E 387036A9
  CB2A5DB0 D711C0B6 4498B2D3 8FA20BD5 396DC163 4050E96A F79E64C3 749EDBAD
  979BD45A F592483B EAAEC8FD 13A68054 50006768 51EAA20F 1C1E3646 7C7DB863 FEB4
   quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-5ess
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice translation-rule 4
rule 1 /4109/ /7077694109/
rule 2 /4132/ /7077694132/
rule 3 /4121/ /7077694121/
rule 4 /4120/ /7077694120/
rule 5 /4123/ /7077694123/
rule 6 /4106/ /7077694106/
rule 7 /4131/ /7077694131/
rule 8 /4105/ /7077694105/
rule 15 /^....$/ /7077782307/
voice translation-rule 5
rule 1 /307/ /2307/
voice translation-rule 12
rule 1 /100/ /4100/
rule 2 /101/ /4101/
rule 3 /102/ /4102/
rule 4 /103/ /4103/
rule 5 /104/ /4104/
rule 6 /105/ /4105/
rule 7 /106/ /4106/
rule 8 /107/ /4107/
rule 9 /108/ /4108/
rule 10 /109/ /4109/
voice translation-rule 14
rule 1 /110/ /4110/
rule 2 /111/ /4111/
rule 3 /112/ /4112/
rule 4 /113/ /4113/
rule 5 /114/ /4114/
rule 6 /115/ /4115/
rule 7 /116/ /4116/
rule 8 /117/ /4117/
rule 9 /118/ /4118/
rule 10 /119/ /4119/
voice translation-rule 19
rule 1 /120/ /4120/
rule 2 /121/ /4121/
rule 3 /122/ /4122/
rule 4 /123/ /4123/
rule 5 /124/ /4124/
rule 6 /125/ /4125/
rule 7 /126/ /4126/
rule 8 /127/ /4127/
rule 9 /128/ /4128/
rule 10 /129/ /4129/
voice translation-rule 20
rule 1 /130/ /4130/
rule 2 /131/ /4131/
rule 3 /132/ /4132/
rule 4 /133/ /4133/
rule 5 /134/ /4134/
rule 6 /135/ /4135/
rule 7 /136/ /4136/
rule 8 /137/ /4137/
rule 9 /138/ /4138/
rule 10 /139/ /4139/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^8/ //
voice translation-rule 1115
rule 1 /\(^....$\)/ /707769\1/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^81900......./ //
rule 2 /^81976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile MainLine_Called_5
translate called 5
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile OUT_TRANSLATION_PROFILE_EMG
translate calling 1115
voice translation-profile PRI0_Called_12
translate called 12
voice translation-profile PRI0_Called_14
translate called 14
voice translation-profile PRI0_Called_19
translate called 19
voice translation-profile PRI0_Called_20
translate called 20
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
license udi pid UC560-T1E1-K9 sn xxxxxxx
archive
log config
  logging enable
  logging size 600
  hidekeys
username phoneadmin privilege 15 secret 5
username admin privilege 15 secret 5
username Winery password 0
username AimeeM password 0
username TastingRoom password 0
username Tours password 0
username JoanC password 0
username GardenStaff password 0
username UpprBrkRm password 0
username McEvoyMain password 0
username UserO password 0
username AnthonyF password 0
username user6 password 0
username MoritaTrailer password 0
controller T1 0/3/0
pri-group timeslots 1-24
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport mode trunk
macro description cisco-switch
interface GigabitEthernet0/1/1
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface GigabitEthernet0/1/2
macro description cisco-desktop
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address ^011.* plan unknown type unknown
isdn supp-service name calling
isdn sending-complete
trunk-group ALL_T1E1
no cdp enable
interface Vlan1
description $FW_INSIDE$
ip address 192.168.15.240 255.255.255.0
ip access-group 101 in
ip nat inside
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Vlan90
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.15.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.15.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 101 remark SDM_ACL Category=1
access-list 101 deny   ip 10.1.10.0 0.0.0.3 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 deny   ip 192.168.15.0 0.0.0.255 any
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 103 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 103 deny   ip 192.168.15.0 0.0.0.255 any
access-list 103 deny   ip 10.1.1.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 192.168.15.0 0.0.0.255 any
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any log
snmp-server community RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-2.bin alias spa525g-7-4-2.bin
tftp-server flash:/phones/5x5/spa5x5-7-4-2.bin alias spa5x5-7-4-2.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.3.3.SBN alias APPS-1.3.3.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.3.LOADS alias CP7921G-1.3.3.LOADS
tftp-server flash:/phones/7921/GUI-1.3.3.SBN alias GUI-1.3.3.SBN
tftp-server flash:/phones/7921/MISC-1.3.3.SBN alias MISC-1.3.3.SBN
tftp-server flash:/phones/7921/SYS-1.3.3.SBN alias SYS-1.3.3.SBN
tftp-server flash:/phones/7921/TNUX-1.3.3.SBN alias TNUX-1.3.3.SBN
tftp-server flash:/phones/7921/WLAN-1.3.3.SBN alias WLAN-1.3.3.SBN
tftp-server flash:/phones/7925/APPSH-1.3.3.SBN alias APPSH-1.3.3.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.3.LOADS alias CP7925G-1.3.3.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.3.SBN alias GUIH-1.3.3.SBN
tftp-server flash:/phones/7925/MISCH-1.3.3.SBN alias MISCH-1.3.3.SBN
tftp-server flash:/phones/7925/SYSH-1.3.3.SBN alias SYSH-1.3.3.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.3.SBN alias TNUXH-1.3.3.SBN
tftp-server flash:/phones/7925/WLANH-1.3.3.SBN alias WLANH-1.3.3.SBN
tftp-server flash:/phones/7931/apps31.8-5-3TH1-6.sbn alias apps31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-3TH1-6.sbn alias cnu31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-3TH1-6.sbn alias cvm31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-3TH1-6.sbn alias dsp31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-3TH1-6.sbn alias jar31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-3S.loads alias SCCP31.8-5-3S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-20-0.bin alias cmterm_7936.3-3-20-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-3TH1-6.sbn alias cnu41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
voice-port 0/0/0
station-id number 4110
caller-id enable
voice-port 0/0/1
station-id number 4130
caller-id enable
voice-port 0/0/2
station-id number 4137
caller-id enable
voice-port 0/0/3
no echo-cancel enable
no comfort-noise
timeouts ringing infinity
station-id name Bottling Ringer
station-id number 4135
caller-id enable
voice-port 0/3/0:23
bearer-cap Speech
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar 201
caller-id enable
voice-port 0/1/1
connection plar 202
shutdown
caller-id enable
voice-port 0/1/2
connection plar 203
shutdown
caller-id enable
voice-port 0/1/3
connection plar 204
shutdown
caller-id enable
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
station-id number 4115
caller-id enable
voice-port 0/2/3
station-id number 4117
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
shutdown
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
description ** CCA Analog Fax **
destination-pattern 4110
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 4115
port 0/2/2
no sip-register
dial-peer voice 3 pots
destination-pattern 4137
port 0/0/2
no sip-register
dial-peer voice 4 pots
service stcapp
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 150 pots
incoming called-number ....
direct-inward-dial
port 0/3/0:23
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 3099
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 3098
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 3097
b2bua
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_T1E1
corlist outgoing call-emergency
description **CCA*North American-7-digit*Emergency**
translation-profile outgoing OUT_TRANSLATION_PROFILE_EMG
preference 3
destination-pattern 8911
forward-digits 3
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_T1E1
corlist outgoing call-local
description **CCA*North American-7-digit*7-Digit Local**
preference 3
destination-pattern 8[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_T1E1
description **CCA*North American-7-digit*Service Numbers**
preference 3
destination-pattern 8[2-9]11
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_T1E1
corlist outgoing call-national
description **CCA*North American-7-digit*Long Distance**
preference 3
destination-pattern 81[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_T1E1
corlist outgoing call-international
description **CCA*North American-7-digit*International**
preference 3
destination-pattern 8011T
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_T1E1
corlist outgoing call-toll-free
description **CCA*North American-7-digit*Toll-Free**
preference 3
destination-pattern 81800.......
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 81888.......
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 81877.......
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 81866.......
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 3007 pots
description PRI0
translation-profile incoming PRI0_Called_12
incoming called-number 10.
direct-inward-dial
port 0/3/0:23
dial-peer voice 3009 pots
description PRI0
translation-profile incoming PRI0_Called_14
incoming called-number 11.
direct-inward-dial
port 0/3/0:23
dial-peer voice 3014 pots
description PRI0
translation-profile incoming PRI0_Called_19
incoming called-number 12.
direct-inward-dial
port 0/3/0:23
dial-peer voice 3015 pots
description PRI0
translation-profile incoming PRI0_Called_20
incoming called-number 13.
direct-inward-dial
port 0/3/0:23
dial-peer voice 2006 voip
description ** cue auto attendant2 number **
destination-pattern 3096
b2bua
codec g711ulaw
no vad
dial-peer voice 3000 pots
description MainLine
translation-profile incoming MainLine_Called_5
incoming called-number 307
direct-inward-dial
port 0/3/0:23
dial-peer voice 1110 pots
destination-pattern 110
port 0/0/0
dial-peer voice 1111 pots
destination-pattern 130
port 0/0/1
dial-peer voice 1112 pots
destination-pattern 137
port 0/0/2
dial-peer voice 1113 pots
destination-pattern 135
port 0/0/3
dial-peer voice 7 pots
service stcapp
port 0/2/3
no sip-register
dial-peer voice 3095 voip
destination-pattern 3095
b2bua
codec g711ulaw
no vad
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 114
max-dn 600
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message McEvoy Ranch
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.3
load 7925 CP7925G-1.3.3
load 7931 SCCP31.8-5-3S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-3S
load 7941GE SCCP41.8-5-3S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-3S
load 7961 SCCP41.8-5-3S
load 7961GE SCCP41.8-5-3S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-3S
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-2
load 501G spa5x5-7-4-2
load 502G spa5x5-7-4-2
load 504G spa5x5-7-4-2
load 508G spa5x5-7-4-2
load 509G spa5x5-7-4-2
time-zone 5
voicemail 3099
max-conferences 8 gain -6
call-forward pattern .T
web admin system name cisco secret 5 $1$aYMW$kPB09kEwkBiyTTP6VW4Vq.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 8.T
transfer-pattern 6.... blind
transfer-pattern 55..
secondary-dialtone 8
fac standard
create cnf-files version-stamp 7960 Oct 13 2010 14:50:43
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
softkeys idle  Redial Pickup Cfwdall Gpickup Dnd Login Newcall
softkeys seized  Redial Pickup Cfwdall Callback Endcall Gpickup
softkeys connected  Hold Trnsfer TrnsfVM Confrn Park Endcall
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-template  19
ephone-dn  1  dual-line
number 4113 secondary 7077694113 no-reg primary
label Guillermo-4113
description 4113
name Guillermo Barba
call-forward noan 3099 timeout 35
huntstop channel
no huntstop
hold-alert 30 originator
ephone-dn  2  dual-line
number 4100 no-reg primary
label Shari-4100
description 4100
name Shari DeJoseph
huntstop channel
no huntstop
ephone-dn  3  dual-line
number 4101 secondary 7077694101 no-reg primary
label Margaret-4101
description 4101
name Margaret KoskiKent
call-forward noan 3099 timeout 15
huntstop channel
no huntstop
ephone-dn  4  dual-line
number 4102 secondary 7077694102 no-reg primary
label 4102
description 4102
name Tasting RM+RRS
huntstop channel
no huntstop
ephone-dn  5  dual-line
number 4104 secondary 7077694104 no-reg primary
label Adult Center-4104
description 4104
name Adult Center
huntstop channel
no huntstop
ephone-dn  6  dual-line
number 4105 no-reg primary
label Joan
description 4105
name Joan Cuppoletti
huntstop channel
no huntstop
ephone-dn  7  dual-line
number 4106 secondary 7077694106 no-reg primary
label CK-4106
description 4106
name Country Kitchen
huntstop channel
no huntstop
ephone-dn  8  dual-line
number 4107 secondary 7077694107 no-reg primary
label Upper Breakroom
description 4107
name Upper Breakroom
huntstop channel
no huntstop
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 4108 secondary 7077694108 no-reg primary
label Garden Staff-4108
description 4108
name Garden Staff
call-forward noan 3095 timeout 35
huntstop channel
no huntstop
ephone-dn  11  dual-line
number 4109 secondary 7077694109
label Dana-4109
description 4109 - Dana
name Dana Breaux
corlist incoming user-international
corlist outgoing user-international
huntstop channel
no huntstop
ephone-dn  12  dual-line
number 4111 secondary 7077694111 no-reg primary
label MH Kitchen-4111
description 4111
name MH Kitchen
huntstop channel
no huntstop
ephone-dn  13  dual-line
number 4113 no-reg primary
label Line 2
description 4113
preference 1
caller-id block
huntstop channel
ephone-dn  14  dual-line
number 4117 secondary 7077694117 no-reg primary
label Jeff-4117
description 4117
name Jeff Creque
huntstop channel
no huntstop
ephone-dn  15  dual-line
number 4119 no-reg primary
label Break Room
description 4119
name Break Room
huntstop channel
no huntstop
ephone-dn  16  dual-line
number 4120 secondary 7077694120 no-reg primary
label Jill-4120
description 4120
name Jill Lee
huntstop channel
no huntstop
ephone-dn  17  dual-line
number 2001 secondary 7077692001 no-reg primary
label user
description 2001
name user one
call-forward noan 3099 timeout 25
huntstop channel
no huntstop
ephone-dn  19  dual-line
number 2004 no-reg primary
label 2004
description userthree userthree
name userthree userthree
ephone-dn  20  dual-line
number 4126 no-reg primary
label Winery-4126
description 4126
name Winery
huntstop channel
no huntstop
ephone-dn  21  dual-line
number 4124 no-reg primary
label Mike-4124
description 4124
name Mike Morelli
huntstop channel
no huntstop
ephone-dn  22  dual-line
number 4107 no-reg primary
label Line 2
description 4107
preference 1
huntstop channel
ephone-dn  23  dual-line
number 4117 no-reg primary
label Jeff Line 2
description 4117
name Jeff Creque
preference 1
call-forward busy 3099
huntstop channel
ephone-dn  24  dual-line
number 4135 no-reg primary
label Marina-4135
description 4135
name Marina Acosta
call-forward noan 3099 timeout 20
huntstop channel
no huntstop
ephone-dn  25  dual-line
number 4131 no-reg primary
label Stephanie
description 4131
name Stephanie Delaney
huntstop channel
no huntstop
ephone-dn  26  dual-line
label Stephanie-4131
description 4131
preference 1
huntstop channel
no huntstop
ephone-dn  27  dual-line
number 4102 no-reg primary
label 4102 Line 2
description 4102
name Tasting RM+RRS
preference 1
huntstop channel
ephone-dn  28  dual-line
number 4122 no-reg primary
label Christina-4122
description 4122
name Christina Cavallaro
huntstop channel
no huntstop
ephone-dn  29  dual-line
number 4127 no-reg primary
label Jane-4127
description 4127
name Jane Steele
huntstop channel
no huntstop
ephone-dn  30  dual-line
number 4120 no-reg primary
label Jill Line 2
description 4120
name Jill Lee
preference 1
huntstop channel
ephone-dn  31  dual-line
label Line 2
description 4100
name Shari DeJoseph
preference 1
huntstop channel
ephone-dn  32  dual-line
number 4111 no-reg primary
label MH Line 2
description 4111
name MH Kitchen
preference 1
huntstop channel
ephone-dn  33  dual-line
number 4132 no-reg primary
label Aimee-4132
description 4132
name Aimee Myers
huntstop channel
no huntstop
ephone-dn  34  dual-line
number 4109 no-reg primary
label Dana Line 2
name Dana Breaux
preference 1
huntstop channel
ephone-dn  35  dual-line
number 4121 no-reg primary
label Dick-4121
description 4121
name Dick Neilsen
huntstop channel
no huntstop
ephone-dn  36  dual-line
number 4129 no-reg primary
label Alice-4129
description 4129
name Alice Rundle
huntstop channel
no huntstop
ephone-dn  37  dual-line
number 1003 no-reg primary
label Victorian
description 1003
name Victorian
huntstop channel
ephone-dn  38  dual-line
label Joan Line 2
description 4105
preference 1
huntstop channel
ephone-dn  39  dual-line
number 4104 no-reg primary
label Line 2
description 4104
name Adult Center
preference 1
huntstop channel
ephone-dn  40  dual-line
number 4106 no-reg primary
label CK Line 2
description 4106
preference 1
huntstop channel
ephone-dn  41  dual-line
number 4108 no-reg primary
label Line 2
description 4108
name Garden Staff
preference 1
call-forward busy 3095
huntstop channel
ephone-dn  42  dual-line
number 4101 no-reg primary
label Line 2
description 4101
preference 1
huntstop channel
ephone-dn  43  dual-line
number 4123 no-reg primary
label Samantha-4123
description 4123
name Samantha Dorsey
call-forward all 3099
call-forward noan 3099 timeout 50
huntstop channel
no huntstop
ephone-dn  44  dual-line
number 4128 no-reg primary
label Amy-4128
description 4128
name Amy Schafbauch
huntstop channel
no huntstop
ephone-dn  45  dual-line
label Line 2
description Break Room
name Break Room
preference 1
huntstop channel
ephone-dn  46  dual-line
number 4121 secondary 7077694121 no-reg primary
label Dick Line 2
description 4121
name Dick Neilsen
preference 1
huntstop channel
ephone-dn  47  dual-line
number 2005 no-reg primary
label 2005
description userfour userfour
name userfour userfour
ephone-dn  50  dual-line
label Line 2
description 4122
preference 1
huntstop channel
ephone-dn  51  dual-line
number 4123 secondary 7077694123
label Sam Line 2
description 4123
preference 1
huntstop channel
ephone-dn  52  dual-line
label Mike Line 2
description 4124
name Mike Morelli
preference 1
huntstop channel
ephone-dn  53  dual-line
label Line 2
description 4135
name Marina Acosta
preference 1
huntstop channel
ephone-dn  54  dual-line
number 4126 secondary 7077694126 no-reg primary
label Line 2
description 4126
name Winery
preference 1
huntstop channel
ephone-dn  55  dual-line
number 4127 secondary 7077694127 no-reg primary
label Jane Line 2
description 4127
name Jane Steele
preference 1
huntstop channel
ephone-dn  56  dual-line
number 4128 secondary 7077694128 no-reg primary
label Amy Line 2
description 4128
name Amy Schafbauch
preference 1
huntstop channel
ephone-dn  57  dual-line
label Alice Line 2
description 4129
name Alice Rundle
preference 1
huntstop channel
ephone-dn  58  dual-line
label Aimee Line 2
description 4132
name Aimee Myers
preference 1
huntstop channel
ephone-dn  59  dual-line
number 4103
label Jan-4103
description 4103
name Jan Williams
huntstop channel
no huntstop
ephone-dn  60  dual-line
number 4103
label Jan Line 2
description Jan Williams
name Jan Williams
preference 1
huntstop channel
ephone-dn  61
number 5562
label Ellen
description 5562
name Ellen Roggemann
caller-id block
call-forward noan 3099 timeout 10
ephone-dn  62  dual-line
number 4131 secondary 7077694131 no-reg primary
label .
description 4131
preference 2
huntstop channel
ephone-dn  63  dual-line
number 4138
label Tours-4138
description 4138
name Tours
call-forward noan 3099 timeout 40
huntstop channel
no huntstop
ephone-dn  64  dual-line
number 4138
label Tours Line 2
description 4138
name Tours
preference 1
huntstop channel
ephone-dn  65  dual-line
number 4112
label Harvest Party-4112
description 4112
name Harvest Party
huntstop channel
no huntstop
ephone-dn  66  dual-line
number 4112
label HP Line 2
description 4112
name Harvest Party
preference 1
huntstop channel
ephone-dn  67
number 5563
label Russ Morita
description 5563
name Russ Morita
ephone-dn  68
number 5564
label Pepe
description 5564
name Pepe Chavez
ephone-dn  69
number 5565
label Gerardo
description 5565
name Gerardo Gonzales
ephone-dn  70
number 5566
label Francesca
description 5566
name Francesca Perez
ephone-dn  71
number 5568
label Jeff
description 5568
name Jeff Callinan
ephone-dn  72
number 5569
label Andres
description 5569
name Andres Ramirez
ephone-dn  73
number 5571
label Willow
description 5571
name Willow ringer
ephone-dn  74
number 5572
label Blake
description 5572
name Blake Yarger
ephone-dn  75
number 5573
label Kellie
description 5573
name Kellie Gillingham
ephone-dn  76
number 5576
label Patty
description 5576
name Patty Hawkley
ephone-dn  77
number 5577
label Ananda
description 5577
name Ananda Bagackias
ephone-dn  78
number 5578
label Lorna
description 5578
name Lorna Rayos
call-forward all 87792355
call-forward noan 87077792355 timeout 10
ephone-dn  79  dual-line
number 4134 no-reg primary
label Mark-4134
description 4134
name Mark Rohrmeier
huntstop channel
no huntstop
ephone-dn  80  dual-line
number 4134
label Mark Line 2
description 4134
name Mark Rohrmeier
preference 1
huntstop channel
ephone-dn  81
number 4136
description BacklineVM
name BacklineVM
call-forward all 3096
call-forward busy 3096
call-forward noan 3096 timeout 3
no huntstop
ephone-dn  82  dual-line
number 2307 no-reg primary
label Main Line
description McEvoy Main
name McEvoy Main
call-forward noan 3098 timeout 40
huntstop channel
no huntstop
ephone-dn  83  dual-line
label .
name McEvoy Main
preference 1
huntstop channel
no huntstop
ephone-dn  84  dual-line
number 2307
label .
name McEvoy Main
preference 2
call-forward busy 3098
huntstop channel
ephone-dn  85
number 5567
name Abel Arreola
ephone-dn  86  dual-line
label line 2
name user
preference 1
huntstop channel
ephone-dn  87
number 5575
label Diane
description 5575
name Diane Wayland
ephone-dn  88  dual-line
number 4125 secondary 7077694125 no-reg primary
label Conference Phone
description 4125
name Conference Phone
huntstop channel
ephone-dn  89
number 4139 no-reg primary
label Anthony-4139
description 4139
name Anthony Frost
preference 1
ephone-dn  90  dual-line
number 4114 secondary 7077694114 no-reg primary
label Morita-4114
description 4114
name Morita Trailer
huntstop channel
no huntstop
ephone-dn  91
number 4114 no-reg primary
label Line 2-4114
description 4114
name Morita Trailer
preference 1
ephone-dn  596
number 7002 no-reg primary
park-slot
label Park Slot 7002
ephone-dn  597
number 7001 no-reg primary
park-slot
label Park Slot 7001
ephone-dn  598
number 6.... no-reg primary
description ***CCA XFER TO VM EXTENSION***
ephone-dn  599
number A801.... no-reg primary
mwi off
ephone-dn  600
number A800.... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 0026.99AA.B731
ephone-template 16
max-calls-per-button 4
username "mikem"
type 7921
button  1:21 2:52 3:89
ephone  2
mac-address 5475.D013.E730
ephone-template 16
username "CountryKitchen"
type 7921
button  1:7 2:40
ephone  3
mac-address 8843.E132.9CA0
ephone-template 16
username "MHKitchen"
type 7921
button  1:12 2:32
ephone  4
mac-address FBD4.0C00.2003
max-calls-per-button 2
username "Marina" password 4135
type anl
button  1:24 2:53
ephone  5
video
mac-address 1C17.D336.88C8
ephone-template 16
username "DanaB" password 9876
fastdial 1 84671940 name 01-Ukiah
fastdial 2 814155441871 name 03-Brain Jeffs
fastdial 3 814156860320 name 02-Dick Neilsen
fastdial 4 818007314661 name 04-Kaiser
fastdial 5 814155184943 name 05-Ali Khatibi
fastdial 6 814152919880 name 06-Sharon Wilkinson
fastdial 7 814157725710 name 07-Paul Escobosa
fastdial 8 817025620162 name 08-Lois Wylie (Hm)
fastdial 9 817024999154 name 09-Lois Wylie (C)
fastdial 10 814157725717 name 10-Steve Lanctot
fastdial 11 87629484 name 11-Jean Court
speed-dial 1 87627367 label "John Miller"
speed-dial 2 87629017 label "Home"
type 7965
button  1:11 2:34 3m82 4m25
ephone  6
mac-address 8843.E155.0AB0
ephone-template 16
username "Storage"
type 501G
button  1:20 2:54
ephone  7
mac-address 8843.E155.0AE7
ephone-template 16
username "UpperBreakroom" password 123456
type 501G
button  1:8 2:22
ephone  8
mac-address 0002.FDFF.8F9E
ephone-template 16
username "MikeM" password 123456
type 509G
ephone  9
mac-address 0002.FDFF.8F91
ephone-template 16
type 509G
button  1:17 2:86
ephone  10
mac-address 0002.FDFF.8E74
ephone-template 16
username "JeffC" password 123456
type 509G
button  1:14 2:23
ephone  11
mac-address 8843.E155.0AE9
ephone-template 16
username "BreakRoom" password 123456
type 501G
button  1:15 2:45
ephone  12
video
mac-address 1C17.D336.862D
ephone-template 16
username "McEvoyM" password 2307
speed-dial 1 84671940 label "Ukiah"
type 7965 addon 1 7916-24 2 7916-24
button  1:82 2:83 3:84 4:59
button  5:60 7m33 8m36 9m44
button  10m28 11m11 12m35 13m7
button  14m29 15m14 16m16 17m3
button  31m24 32m21 33m43 34m2
button  35m25 36m4
ephone  13
video
mac-address 1C17.D336.899B
ephone-template 16
username "StephanieD" password 123456
type 7965
button  1:25 2:26 3:62 4s82
button  5s83 6s84
ephone  14
video
mac-address 1C17.D336.8AA9
ephone-template 16
username "MH" password 123456
type 7965
button  1:12 2:32
ephone  15
video
mac-address 1C17.D336.896C
ephone-template 16
username "AimeeC" password 123456
type 7965
button  1:33 2:58 3m25 4m82
ephone  16
mac-address 0002.FDFF.8F82
ephone-template 16
username "MarinaA" password 123456
type 509G
button  1:24 2:53
ephone  17
mac-address 0002.FDFF.8F97
ephone-template 16
username "harvest" password 123456
type 509G
button  1:63 2:64 3:4 4:27
ephone  18
mac-address 0002.FDFF.8F94
ephone-template 16
username "ChristinaC" password 123456
type 509G
button  1:28 2:50
ephone  19
mac-address 0002.FDFF.9021
ephone-template 16
username "JaneS" password 123456
type 509G
button  1:29 2:55
ephone  20
mac-address 0002.FDFF.8FD2
ephone-template 16
username "JillL" password 123456
type 509G
button  1:16 2:30 3:65 4:66
ephone  21
mac-address 0002.FDFF.8FAA
ephone-template 16
username "ShariD" password 123456
type 509G
button  1:2 2:31
ephone  22
mac-address 0002.FDFF.9011
ephone-template 16
username "GardenStaff" password 9632
type 509G
button  1:35 2:46
ephone  23
mac-address 0002.FDFF.8FDB
ephone-template 16
username "AliceR" password 123456
type 509G
button  1:36 2:57
ephone  24
mac-address 0002.FDFF.8F92
ephone-template 16
username "ChildrensCenter" password 123456
type 509G
button  1:6 2:38
ephone  25
mac-address 0002.FDFF.900A
ephone-template 16
username "AdultCenter" password 123456
type 509G
button  1:5 2:39
ephone  26
mac-address 0002.FDFF.8F86
ephone-template 16
username "CountyKitchen" password gea67375
type 509G
button  1:7 2:40
ephone  27
mac-address 0002.FDFF.8F95
ephone-template 16
username "SiloOffice" password 123456
type 509G
button  1:10 2:41
ephone  28
mac-address 0002.FDFF.8FBB
ephone-template 16
username "MargaretK" password 123456
type 509G
button  1:3 2:42
ephone  29
mac-address 0002.FDFF.8F9C
ephone-template 16
username "SamanthaD" password 123456
type 509G
button  1:43 2:51
ephone  30
mac-address 0002.FDFF.900D
ephone-template 16
username "AmyS" password 123456
type 509G
button  1:44 2:56
ephone  31
mac-address 0002.FDFF.8FC8
ephone-template 16
username "GuillermoB" password 123456
type 509G
button  1:1 2:13
ephone  32
mac-address FBD4.0C00.2103
type anl
button  1:14 2:23
ephone  33
mac-address 0002.FDFF.9005
ephone-template 16
username "ServiceKitchen" password 123456
type 509G
button  1:37
ephone  34
mac-address 0002.FDFF.8FA2
ephone-template 16
username "MarkR" password 123456
type 509G
button  1:79 2:80
ephone  35
mac-address 0002.FDFF.8F9B
ephone-template 16
username "user3" password 123456
type 509G
button  1:19
ephone  36
mac-address 0002.FDFF.8F93
ephone-template 16
username "user4" password 123456
type 509G
button  1:47
ephone  37
mac-address 0002.FDFF.8FA3
type 509G
button  1:90 2:91
ephone  38
mac-address 0002.FDFF.9015
ephone-template 16
type 509G
button  1:90 2:91
ephone  39
mac-address 0004.F2E5.EC08
type 7936
button  1:88
ephone  40
mac-address 0026.99AA.B91A
type 7921
ephone  41
mac-address 5475.D014.094A
type 7921
button  1:79 2:80
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 2.2 (5). Mon Sep 13 16:24:27 PDT 2010^^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 5 100
ntp master
ntp server 192.168.15.1 prefer
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
8500/9000   EEM ED RF
11028/12000  MRIB IPv4 Init Process
11448/12000  MRIB IPv6 Init Process
4944/6000   Inspect Init Msg
5524/6000   SPAN Subsystem
2764/12000  Init
58888/60000  EEM Auto Registration Proc
5200/6000   DIB error message
5532/6000   SASL MAIN
2512/3000   allegro libretto init
5052/6000   LICENSE AGENT DEFAULT
59300/60000  script background loader
5328/6000   RADIUS INITCONFIG
5768/12000  HTTP SSL PKI CERTIFICATE CREATE PROC
5536/6000   FLEX DSPRM boot download main
33996/36000  TCP Command
2448/3000   Rom Random Update Process
5532/12000  TFTP Server
9164/12000  TTY Daemon
13980/24000  HTTP CP
4460/12000  Virtual Exec
9292/12000  SCCP Application
4760/12000  SCCP Telephony Control Application
2700/6000   FTP Read Process
49468/60000  AFW_application_process
Interrupt level stacks:
Level    Called Unused/Size  Name
  4   384775023   5864/9000  Host/PCI Bridge Interrupt
  5           0   9000/9000  Timebase Reference Interrupt
  6      969416   8916/9000  16552 Con/Aux Interrupt
  7  1207799954   8912/9000  M8300_TIMER_INTERRUPT
Spurious interrupts: 2545922
------------------ show interfaces ------------------
GigabitEthernet0/0 is up, line protocol is down
  Hardware is PQII_PRO_TSEC, address is 68ef.bd40.c000 (bia 68ef.bd40.c000)
  Description: $FW_OUTSIDE$
  Internet address will be negotiated using DHCP
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto Speed, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input never, output 00:00:02, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     482839 packets output, 28970372 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Integrated-Service-Engine0/0 is up, line protocol is up
  Hardware is Service Module Mgmt
  Description: cue is initialized with default IMAP group
  Interface is unnumbered. Using address of Vlan90 (10.1.10.2)
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Last input 3w6d, output never, output hang never
  Output queue: 0/0 (size/max)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     3 packets output, 170 bytes, 0 underruns
GigabitEthernet0/1/0 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 68ef.bd40.c002 (bia 68ef.bd40.c002)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 100 usec,
  Full-duplex, 1000Mb/s
  Last input 00:00:03, output never, output hang never
  Input queue: 0/75/3273/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 281000 bits/sec, 147 packets/sec
  5 minute output rate 269000 bits/sec, 154 packets/sec
     122964162 packets input, 2174183902 bytes, 0 no buffer
     Received 11957348 broadcasts, 0 runts, 0 giants, 0 throttles
     110055857 packets output, 1776929246 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
GigabitEthernet0/1/1 is up, line protocol is down
  Hardware is Gigabit Ethernet, address is 68ef.bd40.c003 (bia 68ef.bd40.c003)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Auto-duplex, Auto-speed
  Last input never, output never, output hang never
     0 packets output, 0 bytes, 0 underruns
GigabitEthernet0/1/2 is up, line protocol is down
  Hardware is Gigabit Ethernet, address is 68ef.bd40.c004 (bia 68ef.bd40.c004)
GigabitEthernet0/1/3 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 68ef.bd40.c000 (bia 68ef.bd40.c005)
  Description: Interface used to communicate with integrated service module
  5 minute input rate 43000 bits/sec, 17 packets/sec
  5 minute output rate 48000 bits/sec, 22 packets/sec
     15680549 packets input, 3700303272 bytes, 0 no buffer
     Received 5800 broadcasts, 0 runts, 0 giants, 0 throttles
     20139584 packets output, 237107911 bytes, 0 underruns
Serial0/3/0:0 is up, line protocol is up
  Hardware is DSX1
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive not set
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     0 carrier transitions
Serial0/3/0:1 is up, line protocol is up
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:2 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:3 is up, line protocol is up
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:4 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:5 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:6 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:7 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:8 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:9 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:10 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:11 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:12 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:13 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:14 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:15 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:16 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:17 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:18 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:19 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:20 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:21 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:22 is up, line protocol is up
  Hardware is DSX1
  Keepalive not set
Serial0/3/0:23 is up, line protocol is up (spoofing)
  Hardware is DSX1
  Last input 00:00:14, output never, output hang never
     Conversations  0/1/256 (active/max active/max total)
     249167 packets input, 1515505 bytes, 0 no buffer
     Received 4 broadcasts, 570 runts, 0 giants, 0 throttles
     1279 input errors, 1279 CRC, 0 frame, 0 overrun, 0 ignored, 260 abort
     249190 packets output, 1608392 bytes, 0 underruns
     11 carrier transitions
  Timeslot(s) Used:24, SCC: 0, Transmitter delay is 0 flags
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 68ef.bd40.c002 (bia 68ef.bd40.c002)
  Description: $FW_INSIDE$
  Internet address is 192.168.15.240/24
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  5 minute input rate 7000 bits/sec, 5 packets/sec
     20218271 packets input, 3629851771 bytes, 0 no buffer
     Received 11846761 broadcasts, 0 runts, 0 giants, 0 throttles
     1605337 packets output, 876380145 bytes, 0 underruns
     0 output errors, 1 interface resets
     4919011 unknown protocol drops
Vlan90 is up, line protocol is up
  Internet address is 10.1.10.2/30
  5 minute input rate 44000 bits/sec, 18 packets/sec
  5 minute output rate 48000 bits/sec, 23 packets/sec
     15680558 packets input, 3636500078 bytes, 0 no buffer
     17484137 packets output, 4266007792 bytes, 0 underruns
Vlan100 is up, line protocol is up
  Internet address is 10.1.1.1/24
  5 minute input rate 250000 bits/sec, 135 packets/sec
  5 minute output rate 257000 bits/sec, 151 packets/sec
     74645239 packets input, 2016213304 bytes, 0 no buffer
     Received 110582 broadcasts, 0 runts, 0 giants, 1 throttles
     96406645 packets output, 3565049523 bytes, 0 underruns
NVI0 is administratively down, line protocol is down
  Hardware is NVI
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
------------------ show controllers ------------------
Interface GigabitEthernet0/0
= Hardware =
ADDR: 860967AC, FASTSEND: 80065B1C
Route Cache Flag: 11
= Media  RJ45 =
= MPC8300 TSEC Registers =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000004
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
IEVENT=0x00000000, IMASK=B3718180, EDIS=00000000, ECNTRL=00003022
MINFLR=0x40000000, PTV=00000000, DMACTRL=000000C2, TBIPA=0000001C
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1F443058
TBASE=0x1F442FA0, OSTBD=0x00000000, OSTBDP=0x00000000, RCTRL=0x00000004
RSTAT=0x00000000, RBDLEN=0x00000000, CRBPTR=0x00000000, MRBLR=0x00000600
RBASE=0x1F442B60, MACCFG1=0x0000003F, MACCFG2=0x00007225, IPGIFG=0x40605060
HAFDUP=0x0001F037, MAXFRM=0x00000600, MIIMCFG=0x00000012, MIIMCOM=0x00000000
MIIMADD=0x00000101, MIIMCON=0x00009B7F, MIIMSTAT=0x00000000, MIIMIND=0x00000000
IFSTAT=0x00000008, MACSTNADDR1=0x00C040BD, MACSTNADDR2=0xEF680000
ATTR=0x000048C0, ATTRELI=0x00000008
RMON MIB Registers
TR64=70136, TR127=0, TR255=0, TR511=0
TR1K=0, TRMAX=0, TRMGV=0
RBYT=0, RPKT=0, RFCS=0, RMCA=0
RBCA=0, RXCF=0, RXPF=0, RXUO=0
RALN=0, RFLR=0, RCDE=0, RCSE=0
RUND=0, ROVR=0, RFRG=0, RJBR=0
RDRP=0
TBYT=4488704, TPKT=70136, TMCA=0, TBCA=0
TXPF=0, TDFR=0, TEDF=0, TSCL=0
TMCL=0, TLCL=0, TNCL=0, TDRP=0
TJBR=0, TFCS=0, TXCF=0, TOVR=0
TUND=0, TFRG=0
CAR1=0x00000000, CAR2=0x00000000
CAM1=0xFE03FFFF, CAM2=0x000FFFFD
TBI MII Registers
TBI (CR:0x00)= 0x0140, TBI (SR:0x01)= 0x014D
TBI (AN:0x04)= 0x0000, TBI (CON:0x11)= 0x0020
Software MAC address filter(hash:length/addr/mask/hits):
  0xC0:  0  0100.0ccc.cccc  0000.0000.0000         0
= Device stats/data =
throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_crc_err=0, rx_short_err=0
rx_non_align_err=0, rx_truncation_err=0
rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
PHY Registers
All pages
  Register 0x00:   1000  7949  0141  0C97  01E1  0000  0004  2001
  Register 0x08:   0000  0300  0000  0000  0000  0000  0000  3000
  Register 0x16:   0000
  PHY Control (0x00):
  AUTONEG_EN
  PHY Status (0x01):
  LINK_DOWN
  Auto-Negotiation Advertisement (0x04):
  100FD 100HD 10FD 10HD
  Link Partner Ability (0x05):
  1000BASE-T Control (0x09):
  M/S_AUTO DTE 1000FD 1000HD
  1000BASE-T Status (0x0A):
  M/S_CFG_OK SLAVE
Page 0
  Register 0x10:   6060  8040  0000  0040  0000  0000  0000
  Register 0x1A:   0040
  Copper Specific Status 1 (0x11):
  1000 HD NOT-RESOLVED LINK_DOWN MDIX
Page 2
  Register 0x02:   0141
  Register 0x10:   0288  0440  0000  0000  0000  0000  0002  0000
  Register 0x18:   0000  0000  0000
= Ring Buffer Information =
tsec_instance=0x86098510
rx ring entries=128, tx ring entries=64
rxring=0x1F442B60, rxr shadow=0x86098880, rx_head=0, rx_tail=0
txring=0x1F442FA0, txr shadow=0x86098AB4, tx_head=23, tx_tail=23, tx_count=0
Driver Level Counters: (Cumulative, Zeroed only at Reset)
Rx Frames=0, Bytes=0
Tx Frames=482839, Bytes=28970372
== RX_RING_ENTRIES ==
0 status 9000,  len 0, buf_ptr 1F37EE88
1 status 9000,  len 0, buf_ptr 1F37E828
2 status 9000,  len 0, buf_ptr 1F37E1C8
3 status 9000,  len 0, buf_ptr 1F37DB68
4 status 9000,  len 0, buf_ptr 1F37D508
5 status 9000,  len 0, buf_ptr 1F37CEA8
6 status 9000,  len 0, buf_ptr 1F37C848
7 status 9000,  len 0, buf_ptr 1F37C1E8
8 status 9000,  len 0, buf_ptr 1F37BB88
9 status 9000,  len 0, buf_ptr 1F37B528
10 status 9000,  len 0, buf_ptr 1F37AEC8
11 status 9000,  len 0, buf_ptr 1F37A868
12 status 9000,  len 0, buf_ptr 1F37A208
13 status 9000,  len 0, buf_ptr 1F379BA8
14 status 9000,  len 0, buf_ptr 1F379548
15 status 9000,  len 0, buf_ptr 1F378EE8
16 status 9000,  len 0, buf_ptr 1F378888
17 status 9000,  len 0, buf_ptr 1F378228
18 status 9000,  len 0, buf_ptr 1F377BC8
19 status 9000,  len 0, buf_ptr 1F377568
20 status 9000,  len 0, buf_ptr 1F376F08
21 status 9000,  len 0, buf_ptr 1F3768A8
22 status 9000,  len 0, buf_ptr 1F376248
23 status 9000,  len 0, buf_ptr 1F375BE8
24 status 9000,  len 0, buf_ptr 1F375588
25 status 9000,  len 0, buf_ptr 1F374F28
26 status 9000,  len 0, buf_ptr 1F3748C8
27 status 9000,  len 0, buf_ptr 1F374268
28 status 9000,  len 0, buf_ptr 1F373C08
29 status 9000,  len 0, buf_ptr 1F3735A8
30 status 9000,  len 0, buf_ptr 1F372F48
31 status 9000,  len 0, buf_ptr 1F3728E8
32 status 9000,  len 0, buf_ptr 1F3921C8
33 status 9000,  len 0, buf_ptr 1F391B68
34 status 9000,  len 0, buf_ptr 1F391508
35 status 9000,  len 0, buf_ptr 1F390EA8
36 status 9000,  len 0, buf_ptr 1F390848
37 status 9000,  len 0, buf_ptr 1F3901E8
38 status 9000,  len 0, buf_ptr 1F38FB88
39 status 9000,  len 0, buf_ptr 1F38F528
40 status 9000,  len 0, buf_ptr 1F38EEC8
41 status 9000,  len 0, buf_ptr 1F38E868
42 status 9000,  len 0, buf_ptr 1F38E208
43 status 9000,  len 0, buf_ptr 1F38DBA8
44 status 9000,  len 0, buf_ptr 1F38D548
45 status 9000,  len 0, buf_ptr 1F38CEE8
46 status 9000,  len 0, buf_ptr 1F38C888
47 status 9000,  len 0, buf_ptr 1F38C228
48 status 9000,  len 0, buf_ptr 1F38BBC8
49 status 9000,  len 0, buf_ptr 1F38B568
50 status 9000,  len 0, buf_ptr 1F38AF08
51 status 9000,  len 0, buf_ptr 1F38A8A8
52 status 9000,  len 0, buf_ptr 1F38A248
53 status 9000,  len 0, buf_ptr 1F389BE8
54 status 9000,  len 0, buf_ptr 1F389588
55 status 9000,  len 0, buf_ptr 1F388F28
56 status 9000,  len 0, buf_ptr 1F3888C8
57 status 9000,  len 0, buf_ptr 1F388268
58 status 9000,  len 0, buf_ptr 1F387C08
59 status 9000,  len 0, buf_ptr 1F3875A8
60 status 9000,  len 0, buf_ptr 1F386F48
61 status 9000,  len 0, buf_ptr 1F3868E8
62 status 9000,  len 0, buf_ptr 1F386288
63 status 9000,  len 0, buf_ptr 1F385C28
64 status 9000,  len 0, buf_ptr 1F3855C8
65 status 9000,  len 0, buf_ptr 1F384F68
66 status 9000,  len 0, buf_ptr 1F384908
67 status 9000,  len 0, buf_ptr 1F3842A8
68 status 9000,  len 0, buf_ptr 1F383C48
69 status 9000,  len 0, buf_ptr 1F3835E8
70 status 9000,  len 0, buf_ptr 1F382F88
71 status 9000,  len 0, buf_ptr 1F382928
72 status 9000,  len 0, buf_ptr 1F3A2208
73 status 9000,  len 0, buf_ptr 1F3A1BA8
74 status 9000,  len 0, buf_ptr 1F3A1548
75 status 9000,  len 0, buf_ptr 1F3A0EE8
76 status 9000,  len 0, buf_ptr 1F3A0888
77 status 9000,  len 0, buf_ptr 1F3A0228
78 status 9000,  len 0, buf_ptr 1F39FBC8
79 status 9000,  len 0, buf_ptr 1F39F568
80 status 9000,  len 0, buf_ptr 1F39EF08
81 status 9000,  len 0, buf_ptr 1F39E8A8
82 status 9000,  len 0, buf_ptr 1F39E248
83 status 9000,  len 0, buf_ptr 1F39DBE8
84 status 9000,  len 0, buf_ptr 1F39D588
85 status 9000,  len 0, buf_ptr 1F39CF28
86 status 9000,  len 0, buf_ptr 1F39C8C8
87 status 9000,  len 0, buf_ptr 1F39C268
88 status 9000,  len 0, buf_ptr 1F39BC08
89 status 9000,  len 0, buf_ptr 1F39B5A8
90 status 9000,  len 0, buf_ptr 1F39AF48
91 status 9000,  len 0, buf_ptr 1F39A8E8
92 status 9000,  len 0, buf_ptr 1F39A288
93 status 9000,  len 0, buf_ptr 1F399C28
94 status 9000,  len 0, buf_ptr 1F3995C8
95 status 9000,  len 0, buf_ptr 1F398F68
96 status 9000,  len 0, buf_ptr 1F398908
97 status 9000,  len 0, buf_ptr 1F3982A8
98 status 9000,  len 0, buf_ptr 1F397C48
99 status 9000,  len 0, buf_ptr 1F3975E8
100 status 9000,  len 0, buf_ptr 1F396F88
101 status 9000,  len 0, buf_ptr 1F396928
102 status 9000,  len 0, buf_ptr 1F3962C8
103 status 9000,  len 0, buf_ptr 1F395C68
104 status 9000,  len 0, buf_ptr 1F395608
105 status 9000,  len 0, buf_ptr 1F394FA8
106 status 9000,  len 0, buf_ptr 1F394948
107 status 9000,  len 0, buf_ptr 1F3942E8
108 status 9000,  len 0, buf_ptr 1F393C88
109 status 9000,  len 0, buf_ptr 1F393628
110 status 9000,  len 0, buf_ptr 1F392FC8
111 status 9000,  len 0, buf_ptr 1F392968
112 status 9000,  len 0, buf_ptr 1F3B2248
113 status 9000,  len 0, buf_ptr 1F3B1BE8
114 status 9000,  len 0, buf_ptr 1F3B1588
115 status 9000,  len 0, buf_ptr 1F3B0F28
116 status 9000,  len 0, buf_ptr 1F3B08C8
117 status 9000,  len 0, buf_ptr 1F3B0268
118 status 9000,  len 0, buf_ptr 1F3AFC08
119 status 9000,  len 0, buf_ptr 1F3AF5A8
120 status 9000,  len 0, buf_ptr 1F3AEF48
121 status 9000,  len 0, buf_ptr 1F3AE8E8
122 status 9000,  len 0, buf_ptr 1F3AE288
123 status 9000,  len 0, buf_ptr 1F3ADC28
124 status 9000,  len 0, buf_ptr 1F3AD5C8
125 status 9000,  len 0, buf_ptr 1F3ACF68
126 status 9000,  len 0, buf_ptr 1F3AC908
127 status B000,  len 0, buf_ptr 1F3AC2A8
== TX_RING_ENTRIES ==
0 status 0,  len 3C, buf_ptr 1F33A00A
1 status 0,  len 3C, buf_ptr 1F33AA0A
2 status 0,  len 3C, buf_ptr 1F945B0A
3 status 0,  len 3C, buf_ptr 1F945D8A
4 status 0,  len 3C, buf_ptr 1F339B0A
5 status 0,  len 3C, buf_ptr 1F946F0A
6 status 0,  len 3C, buf_ptr 1F94664A
7 status 0,  len 3C, buf_ptr 1F946A0A
8 status 0,  len 3C, buf_ptr 1F339C4A
9 status 0,  len 3C, buf_ptr 1F33AB4A
10 status 0,  len 3C, buf_ptr 1F9468CA
11 status 0,  len 3C, buf_ptr 1F33AA0A
12 status 0,  len 3C, buf_ptr 1F94704A
13 status 0,  len 3C, buf_ptr 1F9459CA
14 status 0,  len 3C, buf_ptr 1F94678A
15 status 0,  len 3C, buf_ptr 1F33A14A
16 status 0,  len 3C, buf_ptr 1F33A8CA
17 status 0,  len 3C, buf_ptr 1F94600A
18 status 0,  len 3C, buf_ptr 1F33A78A
19 status 0,  len 3C, buf_ptr 1F33A78A
20 status 0,  len 3C, buf_ptr 1F33AB4A
21 status 0,  len 3C, buf_ptr 1F33974A
22 status 0,  len 3C, buf_ptr 1F946A0A
23 status 0,  len 3C, buf_ptr 1F83826A
24 status 0,  len 3C, buf_ptr 1F33AB4A
25 status 0,  len 3C, buf_ptr 1F33AA0A
26 status 0,  len 3C, buf_ptr 1F33AF0A
27 status 0,  len 3C, buf_ptr 1F33938A
28 status 0,  len 3C, buf_ptr 1F33AB4A
29 status 0,  len 3C, buf_ptr 1F33A50A
30 status 0,  len 3C, buf_ptr 1F94574A
31 status 0,  len 3C, buf_ptr 1F33A3CA
32 status 0,  len 3C, buf_ptr 1F9468CA
33 status 0,  len 3C, buf_ptr 1F94628A
34 status 0,  len 3C, buf_ptr 1F94664A
35 status 0,  len 3C, buf_ptr 1F945D8A
36 status 0,  len 3C, buf_ptr 1F33A50A
37 status 0,  len 3C, buf_ptr 1F33AC8A
38 status 0,  len 3C, buf_ptr 1F9463CA
39 status 0,  len 3C, buf_ptr 1F9459CA
40 status 0,  len 3C, buf_ptr 1F33A28A
41 status 0,  len 3C, buf_ptr 1F9463CA
42 status 0,  len 3C, buf_ptr 1F94650A
43 status 0,  len 3C, buf_ptr 1F94704A
44 status 0,  len 3C, buf_ptr 1F33B18A
45 status 0,  len 3C, buf_ptr 1F946B4A
46 status 0,  len 3C, buf_ptr 1F9463CA
47 status 0,  len 3C, buf_ptr 1F94704A
48 status 0,  len 3C, buf_ptr 1F94600A
49 status 0,  len 3C, buf_ptr 1F33A3CA
50 status 0,  len 3C, buf_ptr 1F946B4A
51 status 0,  len 3C, buf_ptr 1F927E6A
52 status 0,  len 3C, buf_ptr 1F3399CA
53 status 0,  len 3C, buf_ptr 1F9463CA
54 status 0,  len 3C, buf_ptr 1F33ADCA
55 status 0,  len 3C, buf_ptr 1F33A8CA
56 status 0,  len 3C, buf_ptr 1F945C4A
57 status 0,  len 3C, buf_ptr 1F33960A
58 status 0,  len 3C, buf_ptr 1F945D8A
59 status 0,  len 3C, buf_ptr 1F946F0A
60 status 0,  len 3C, buf_ptr 1F94718A
61 status 0,  len 3C, buf_ptr 1F946B4A
62 status 0,  len 3C, buf_ptr 1F946F0A
63 status 2000,  len 3C, buf_ptr 1F9472CA
Interface GigabitEthernet0/1/0
Marvell switch registers
Number of Packets received with errors:
Bad Marvell Trailer: 0  Packets received on stacked port: 0
Marvell PHY (0) Register:
Reg 29 = 0x0     Reg 30 = 0x0
Intr enable: 0x400     Intr status : 0x0
Control    : 0x1000     Status      : 0x796D
Identifier : 0x141  0xCB1
Auto Neg   : 0x1E1     Auto Neg Exp: 0xD
LP Ability : 0xC1E1     LP NxtPg    : 0x4AAC
PHY ctrl   : 0x3360     PHY status  : 0xAC48
Marvell MAC Port (0) Registers:
Status     : 0x1E80     Control     : 0x477
MAC Control : 0x3
Identifier : 0x1066     Vlan Map    : 0x7FE
VID and PRI: 0x1     Rate Control: 0x3000
Port Asc Vt: 0x1
TX counter : 0x0     RX counter  : 0x0
Global Registers:
Status   : 0x8874     Control  : 0x482
Port (CPU PORT) Registers:
Status     : 0xE86     Control     : 0x173
MAC Control : 0x43E
Identifier : 0x1066     Vlan Map    : 0x7DF
Port Asc Vt: 0x20
SerDes CRTL : 0x140    SerDes SPIC : 0xDB
Outputs    : 0x6E2A121     Inputs      : 0x7C04F17
Output err : 0x0     Input err   : 0x0
Output drop: 0x0     Input drops : 0x0
Output Coll: 0x0     Input Giants: 0x0
Number of VLANs on unit (0): 3
Vlan[db]\Port| 0  | 1  | 2  | 3  | CPU|
  <1[1]>   | EUT| NM | NM | NM | ET |
  <90[2]>   | ET | NM | NM | EUT| ET |
  <100[3]>   | ET | NM | NM | NM | ET |
= Hardware =
ADDR: 860BCE54, FASTSEND: 80065B1C
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
MINFLR=0x40000000, PTV=00000000, DMACTRL=000000C2, TBIPA=0000001D
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1F4EFFA0
TBASE=0x1F4EFE60, OSTBD=0x00000000, OSTBDP=0x00000000, RCTRL=0x0000000C
RSTAT=0x00000080, RBDLEN=0x00000000, CRBPTR=0x00000000, MRBLR=0x00000600
RBASE=0x1F4EFA20, MACCFG1=0x0000003F, MACCFG2=0x00007225, IPGIFG=0x40605060
HAFDUP=0x0001F037, MAXFRM=0x00000600, MIIMCFG=0x00000007, MIIMCOM=0x00000000
MIIMADD=0x00001D11, MIIMCON=0x00000140, MIIMSTAT=0x00000020, MIIMIND=0x00000000
IFSTAT=0x00000000, MACSTNADDR1=0x00C040BD, MACSTNADDR2=0xEF680000
RMON MIB Registers
TR64=1715969, TR127=2037870, TR255=765430, TR511=3386049
TR1K=57143, TRMAX=32765, TRMGV=0
RBYT=4191249825, RPKT=2700940, RFCS=0, RMCA=1117558
RBCA=2407581, RXCF=0, RXPF=0, RXUO=0
RUND=0, ROVR=18193, RFRG=0, RJBR=0
RDRP=0
TBYT=4084672685, TPKT=1144122, TMCA=2094327, TBCA=37
TJBR=0, TFCS=0, TXCF=0, TOVR=1371
TUND=0, TFRG=0
CAR1=0x70008000, CAR2=0x00011000
TBI MII Registers
PHY Registers
All pages
  Register 0x00:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x08:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x16:   FFFF
  PHY Control (0x00):
  RESET LOOPBACK 100MBPS AUTONEG_EN POWERDOWN ISOLATE AUTONEG_RESTART FULLDUPLEX 1000MBPS
  PHY Status (0x01):
  AUTONEG_DONE REMOTE_FAULT LINK_UP
  ASYM_PAUSE PAUSE 100FD 100HD 10FD 10HD
  M/S_MANUAL_MASTER HUB 1000FD 1000HD
  M/S_CFG_FAULT MASTER LOCAL_RX_OK REMOTE_RX_OK 1000FD 1000HD
Page 0
  Register 0x10:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x1A:   FFFF
  reserved FD RESOLVED LINK_UP MDIX
Page 2
  Register 0x02:   FFFF
  Register 0x10:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x18:   FFFF  FFFF  FFFF
tsec_instance=0x860BDFCC
rxring=0x1F4EFA20, rxr shadow=0x860BE33C, rx_head=30, rx_tail=0
txring=0x1F4EFE60, txr shadow=0x860BE570, tx_head=40, tx_tail=40, tx_count=0
Rx Frames=111741470, Bytes=1743333098
Tx Frames=130043816, Bytes=1595812221
0 status 9000,  len DE, buf_ptr 1F524328
1 status 9000,  len 44, buf_ptr 1F4FF5C8
2 status 9000,  len 44, buf_ptr 1F52F6D8
3 status 9000,  len 44, buf_ptr 1F516B88
4 status 9000,  len DE, buf_ptr 1F4F57A8
5 status 9000,  len 44, buf_ptr 1F4F0FC8
6 status 9000,  len 44, buf_ptr 1F51D028
7 status 9000,  len 44, buf_ptr 1F4FE038
8 status 9000,  len 44, buf_ptr 1F5258B8
9 status 9000,  len 12E, buf_ptr 1F522668
10 status 9000,  len DE, buf_ptr 1F51ECE8
11 status 9000,  len 44, buf_ptr 1F511548
12 status 9000,  len 44, buf_ptr 1F511C78
13 status 9000,  len 44, buf_ptr 1F51F418
14 status 9000,  len DE, buf_ptr 1F4F6D38
15 status 9000,  len 44, buf_ptr 1F50A978
16 status 9000,  len 44, buf_ptr 1F4FD908
17 status 9000,  len 44, buf_ptr 1F504C08
18 status 9000,  len 44, buf_ptr 1F512AD8
19 status 9000,  len DE, buf_ptr 1F526718
20 status 9000,  len 44, buf_ptr 1F52D2E8
21 status 9000,  len 44, buf_ptr 1F50BF08
22 status 9000,  len 44, buf_ptr 1F527578
23 status 9000,  len DE, buf_ptr 1F50B0A8
24 status 9000,  len 44, buf_ptr 1F502818
25 status 9000,  len 12E, buf_ptr 1F4FC378
26 status 9000,  len 44, buf_ptr 1F5209A8
27 status 9000,  len 44, buf_ptr 1F516458
28 status 9000,  len 44, buf_ptr 1F506198
29 status 9000,  len DE, buf_ptr 1F4F0898
30 status 9000,  len 44, buf_ptr 1F513938
31 status 9000,  len 44, buf_ptr 1F529968
32 status 9000,  len FA, buf_ptr 1F521F38
33 status 9000,  len 164, buf_ptr 1F514EC8
34 status 9000,  len DE, buf_ptr 1F4F4218
35 status 9000,  len DE, buf_ptr 1F4F3AE8
36 status 9000,  len DE, buf_ptr 1F525FE8
37 status 9000,  len 12E, buf_ptr 1F4F82C8
38 status 9000,  len DE, buf_ptr 1F4FA6B8
39 status 9000,  len DE, buf_ptr 1F50FFB8
40 status 9000,  len DE, buf_ptr 1F4F2558
41 status 9000,  len 12E, buf_ptr 1F5106E8
42 status 9000,  len DE, buf_ptr 1F4F7B98
43 status 9000,  len DE, buf_ptr 1F5234C8
44 status 9000,  len DE, buf_ptr 1F5123A8
45 status 9000,  len 12E, buf_ptr 1F52EFA8
46 status 9000,  len DE, buf_ptr 1F52FE08
47 status 9000,  len DE, buf_ptr 1F50C638
48 status 9000,  len DE, buf_ptr 1F513208
49 status 9000,  len 12E, buf_ptr 1F525188
50 status 9000,  len DE, buf_ptr 1F506FF8
51 status 9000,  len DE, buf_ptr 1F505338
52 status 9000,  len 44, buf_ptr 1F51E5B8
53 status 9000,  len DE, buf_ptr 1F4F89F8
54 status 9000,  len 12E, buf_ptr 1F4F6608
55 status 9000,  len DE, buf_ptr 1F50F158
56 status 9000,  len DE, buf_ptr 1F508CB8
57 status 9000,  len DE, buf_ptr 1F4FFCF8
58 status 9000,  len 12E, buf_ptr 1F51B368
59 status 9000,  len DE, buf_ptr 1F51C8F8
60 status 9000,  len DE, buf_ptr 1F5196A8
61 status 9000,  len DE, buf_ptr 1F515D28
62 status 9000,  len 12E, buf_ptr 1F500B58
63 status 9000,  len DE, buf_ptr 1F505A68
64 status 9000,  len DE, buf_ptr 1F507E58
65 status 9000,  len DE, buf_ptr 1F522D98
66 status 9000,  len 12E, buf_ptr 1F4F5078
67 status 9000,  len DE, buf_ptr 1F51FB48
68 status 9000,  len DE, buf_ptr 1F50CD68
69 status 9000,  len 12E, buf_ptr 1F50F888
70 status 9000,  len DE, buf_ptr 1F501288
71 status 9000,  len DE, buf_ptr 1F52AEF8
72 status 9000,  len DE, buf_ptr 1F508588
73 status 9000,  len DE, buf_ptr 1F509B18
74 status 9000,  len 12E, buf_ptr 1F5068C8
75 status 9000,  len DE, buf_ptr 1F50D498
76 status 9000,  len DE, buf_ptr 1F521808
77 status 9000,  len DE, buf_ptr 1F500428
78 status 9000,  len 12E, buf_ptr 1F4F5ED8
79 status 9000,  len 44, buf_ptr 1F528B08
80 status 9000,  len DE, buf_ptr 1F523BF8
81 status 9000,  len 44, buf_ptr 1F4F7468
82 status 9000,  len 44, buf_ptr 1F50E2F8
83 status 9000,  len 44, buf_ptr 1F4FB518
84 status 9000,  len 44, buf_ptr 1F514798
85 status 9000,  len 44, buf_ptr 1F4F0168
86 status 9000,  len DE, buf_ptr 1F52E148
87 status 9000,  len 44, buf_ptr 1F514068
88 status 9000,  len 44, buf_ptr 1F52A098
89 status 9000,  len 44, buf_ptr 1F50B7D8
90 status 9000,  len DE, buf_ptr 1F4F33B8
91 status 9000,  len 44, buf_ptr 1F526E48
92 status 9000,  len 12E, buf_ptr 1F50A248
93 status 9000,  len 44, buf_ptr 1F503678
94 status 9000,  len 44, buf_ptr 1F52A7C8
95 status 9000,  len 44, buf_ptr 1F5020E8
96 status 9000,  len 44, buf_ptr 1F4F4948
97 status 9000,  len 44, buf_ptr 1F4F9858
98 status 9000,  len DE, buf_ptr 1F51BA98
99 status 9000,  len 44, buf_ptr 1F4F9F88
100 status 9000,  len 44, buf_ptr 1F518F78
101 status 9000,  len 44, buf_ptr 1F52E878
102 status 9000,  len DE, buf_ptr 1F5044D8
103 status 9000,  len 44, buf_ptr 1F4FADE8
104 status 9000,  len 44, buf_ptr 1F518848
105 status 9000,  len 44, buf_ptr 1F52CBB8
106 status 9000,  len 44, buf_ptr 1F507728
107 status 9000,  len 44, buf_ptr 1F5179E8
108 status 9000,  len 12E, buf_ptr 1F527CA8
109 status 9000,  len DE, buf_ptr 1F51DE88
110 status 9000,  len 44, buf_ptr 1F52C488
111 status 9000,  len 44, buf_ptr 1F51AC38
112 status 9000,  len 44, buf_ptr 1F4FCAA8
113 status 9000,  len 44, buf_ptr 1F4F9128
114 status 9000,  len DE, buf_ptr 1F51D758
115 status 9000,  len 44, buf_ptr 1F50EA28
116 status 9000,  len 44, buf_ptr 1F502F48
117 status 9000,  len 44, buf_ptr 1F518118
118 status 9000,  len 44, buf_ptr 1F52BD58
119 status 9000,  len DE, buf_ptr 1F51C1C8
120 status 9000,  len 44, buf_ptr 1F4F16F8
121 status 9000,  len DE, buf_ptr 1F51A508
122 status 9000,  len 44, buf_ptr 1F52DA18
123 status 9000,  len 12E, buf_ptr 1F503DA8
124 status 9000,  len 44, buf_ptr 1F5172B8
125 status 9000,  len 44, buf_ptr 1F519DD8
126 status 9000,  len 44, buf_ptr 1F5093E8
127 status B000,  len 44, buf_ptr 1F5155F8
0 status 0,  len DA, buf_ptr 1F848672
1 status 0,  len 526, buf_ptr 1F94B6E6
2 status 0,  len 526, buf_ptr 1F95C306
3 status 0,  len 526, buf_ptr 1F94A246
4 status 0,  len 526, buf_ptr 1F94C4A6
5 status 0,  len DA, buf_ptr 1F851752
6 status 0,  len 526, buf_ptr 1F957E46
7 status 0,  len 526, buf_ptr 1F952BC6
8 status 0,  len 502, buf_ptr 1F9599C6
9 status 0,  len 526, buf_ptr 1F9562C6
10 status 0,  len DA, buf_ptr 1F87B9D2
11 status 0,  len 3E2, buf_ptr 1F953986
12 status 0,  len 526, buf_ptr 1F94F4C6
13 status 0,  len DA, buf_ptr 1F874572
14 status 0,  len 526, buf_ptr 1F955506
15 status 0,  len 526, buf_ptr 1F9592E6
16 status 0,  len 526, buf_ptr 1F957766
17 status 0,  len 526, buf_ptr 1F951046
18 status 0,  len DA, buf_ptr 1F883A12
19 status 0,  len 526, buf_ptr 1F95AE66
20 status 0,  len 502, buf_ptr 1F95BC26
21 status 0,  len 526, buf_ptr 1F95B546
22 status 0,  len DA, buf_ptr 1F87B2B2
23 status 0,  len 3E2, buf_ptr 1F95A786
24 status 0,  len 526, buf_ptr 1F33F826
25 status 0,  len 526, buf_ptr 1F33EA66
26 status 0,  len DA, buf_ptr 1F858BB2
27 status 0,  len 526, buf_ptr 1F9524E6
28 status 0,  len 526, buf_ptr 1F957086
29 status 0,  len DA, buf_ptr 1F8610B2
30 status 0,  len 526, buf_ptr 1F94EDE6
31 status 0,  len 526, buf_ptr 1F94D946
32 status 0,  len 502, buf_ptr 1F94E706
33 status 0,  len 526, buf_ptr 1F94CB86
34 status 0,  len DA, buf_ptr 1F84A552
35 status 0,  len 3E2, buf_ptr 1F33E386
36 status 0,  len 526, buf_ptr 1F949B66
37 status 0,  len DA, buf_ptr 1F863452
38 status 0,  len 526, buf_ptr 1F950966
39 status 0,  len 526, buf_ptr 1F958526
40 status 0,  len 526, buf_ptr 1F94B6E6
41 status 0,  len 526, buf_ptr 1F95C306
42 status 0,  len DA, buf_ptr 1F83FA52
43 status 0,  len 526, buf_ptr 1F94A246
44 status 0,  len DA, buf_ptr 1F85DC72
45 status 0,  len 502, buf_ptr 1F94C4A6
46 status 0,  len 526, buf_ptr 1F957E46
47 status 0,  len 3E2, buf_ptr 1F952BC6
48 status 0,  len 526, buf_ptr 1F9599C6
49 status 0,  len DA, buf_ptr 1F845952
50 status 0,  len 526, buf_ptr 1F9562C6
51 status 0,  len 526, buf_ptr 1F953986
52 status 0,  len 3E2, buf_ptr 1F9524E6
53 status 0,  len 526, buf_ptr 1F957086
54 status 0,  len 526, buf_ptr 1F94EDE6
55 status 0,  len 526, buf_ptr 1F94D946
56 status 0,  len DA, buf_ptr 1F864E72
57 status 0,  len 526, buf_ptr 1F94E706
58 status 0,  len 526, buf_ptr 1F94CB86
59 status 0,  len DA, buf_ptr 1F85A5D2
60 status 0,  len 526, buf_ptr 1F33E386
61 status 0,  len 502, buf_ptr 1F949B66
62 status 0,  len 526, buf_ptr 1F950966
63 status 2000,  len 3E2, buf_ptr 1F958526
Interface GigabitEthernet0/1/1
Marvell PHY (1) Register:
Intr enable: 0x400     Intr status : 0x40
Control    : 0x1000     Status      : 0x7949
Auto Neg   : 0x1E1     Auto Neg Exp: 0x4
LP Ability : 0x0     LP NxtPg    : 0x0
PHY ctrl   : 0x3360     PHY status  : 0x8010
Marvell MAC Port (1) Registers:
Status     : 0x1080     Control     : 0x474
MAC Control : 0x3
Identifier : 0x1066     Vlan Map    : 0x7FD
Port Asc Vt: 0x2
MAC Control : 0x43E
Port Asc Vt: 0x20
= Hardware =
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1F4F0018
RMON MIB Registers
TR64=0, TR127=6, TR255=6, TR511=0
TR1K=1, TRMAX=10, TRMGV=0
RBYT=880, RPKT=8, RFCS=0, RMCA=0
RDRP=0
TBYT=15070, TPKT=15, TMCA=0, TBCA=0
TUND=0, TFRG=0
TBI MII Registers
PHY Registers
All pages
  Register 0x16:   FFFF
  PHY Control (0x00):
  PHY Status (0x01):
Page 0
  Register 0x1A:   FFFF
Page 2
  Register 0x02:   FFFF
rxring=0x1F4EFA20, rxr shadow=0x860BE33C, rx_head=38, rx_tail=0
txring=0x1F4EFE60, txr shadow=0x860BE570, tx_head=55, tx_tail=55, tx_count=0
Rx Frames=111741478, Bytes=1743333978
Tx Frames=130043831, Bytes=1595827231
33 status 9000,  len DE, buf_ptr 1F529238
34 status 9000,  len 44, buf_ptr 1F514EC8
35 status 9000,  len 44, buf_ptr 1F4F4218
36 status 9000,  len 44, buf_ptr 1F4F3AE8
37 status 9000,  len 44, buf_ptr 1F525FE8
38 status 9000,  len 44, buf_ptr 1F4F82C8
39 status 9000,  len DE, buf_ptr 1F4FA6B8
40 status 9000,  len 12E, buf_ptr 1F50FFB8
41 status 9000,  len 44, buf_ptr 1F4F2558
42 status 9000,  len 44, buf_ptr 1F5106E8
52 status 0,  len 526, buf_ptr 1F94F4C6
53 status 0,  len 526, buf_ptr 1F955506
54 status 0,  len DA, buf_ptr 1F8475D2
55 status 0,  len 526, buf_ptr 1F9592E6
56 status 0,  len 502, buf_ptr 1F957766
57 status 0,  len 526, buf_ptr 1F951046
58 status 0,  len DA, buf_ptr 1F8649B2
59 status 0,  len 3E2, buf_ptr 1F95AE66
60 status 0,  len 526, buf_ptr 1F95BC26
61 status 0,  len DA, buf_ptr 1F853892
62 status 0,  len 526, buf_ptr 1F95B546
63 status 2000,  len 526, buf_ptr 1F95A786
Interface GigabitEthernet0/1/2
Marvell PHY (2) Register:
Marvell MAC Port (2) Registers:
MAC Control : 0x3
Identifier : 0x1066     Vlan Map    : 0x7FB
Port Asc Vt: 0x4
MAC Control : 0x43E
Port Asc Vt: 0x20
= Hardware =
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1F4EFE80
RMON MIB Registers
TR64=0, TR127=6, TR255=5, TR511=1
TR1K=1, TRMAX=9, TRMGV=0
RBYT=1154, RPKT=9, RFCS=0, RMCA=0
RDRP=0
TBYT=13526, TPKT=13, TMCA=0, TBCA=0
TUND=0, TFRG=0
TBI MII Registers
PHY Registers
All pages
  Register 0x16:   FFFF
  PHY Control (0x00):
  PHY Status (0x01):
Page 0
  Register 0x1A:   FFFF
Page 2
  Register 0x02:   FFFF
rxring=0x1F4EFA20, rxr shadow=0x860BE33C, rx_head=47, rx_tail=0
txring=0x1F4EFE60, txr shadow=0x860BE570, tx_head=4, tx_tail=4, tx_count=0
Rx Frames=111741487, Bytes=1743335132
Tx Frames=130043844, Bytes=1595840705
43 status 9000,  len 44, buf_ptr 1F4F7B98
44 status 9000,  len DE, buf_ptr 1F5234C8
45 status 9000,  len 44, buf_ptr 1F5123A8
46 status 9000,  len 44, buf_ptr 1F52EFA8
47 status 9000,  len 44, buf_ptr 1F52FE08
48 status 9000,  len 44, buf_ptr 1F50C638
49 status 9000,  len DE, buf_ptr 1F513208
50 status 9000,  len 44, buf_ptr 1F525188
0 status 0,  len 526, buf_ptr 1F33F826
1 status 0,  len 526, buf_ptr 1F33EA66
2 status 0,  len 526, buf_ptr 1F9524E6
3 status 0,  len DA, buf_ptr 1F859792
4 status 0,  len 502, buf_ptr 1F957086
5 status 0,  len 526, buf_ptr 1F94EDE6
6 status 0,  len DA, buf_ptr 1F868E92
7 status 0,  len 3E2, buf_ptr 1F94D946
8 status 0,  len 526, buf_ptr 1F94E706
9 status 0,  len 526, buf_ptr 1F94CB86
10 status 0,  len 526, buf_ptr 1F33E386
11 status 0,  len 526, buf_ptr 1F949B66
12 status 0,  len 526, buf_ptr 1F950966
13 status 0,  len DA, buf_ptr 1F86DCF2
14 status 0,  len 526, buf_ptr 1F958526
Interface GigabitEthernet0/1/3
Control    : 0xFFFF     Status      : 0xFFFF
Identifier : 0xFFFF  0xFFFF
Auto Neg   : 0xFFFF     Auto Neg Exp: 0xFFFF
LP Ability : 0xFFFF     LP NxtPg    : 0xFFFF
PHY ctrl   : 0xFFFF     PHY status  : 0xFFFF
Marvell MAC Port (3) Registers:
Status     : 0xE86     Control     : 0x477
MAC Control : 0x43E
Identifier : 0x1066     Vlan Map    : 0x7EF
VID and PRI: 0x5A     Rate Control: 0x3000
Port Asc Vt: 0x10
MAC Control : 0x43E
Port Asc Vt: 0x20
= Hardware =
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1F4EFF00
RMON MIB Registers
TR64=0, TR127=7, TR255=5, TR511=1
TR1K=1, TRMAX=12, TRMGV=0
RBYT=1222, RPKT=10, RFCS=0, RMCA=0
RDRP=0
TBYT=17456, TPKT=16, TMCA=0, TBCA=0
TUND=0, TFRG=0
TBI MII Registers
PHY Registers
All pages
  Register 0x16:   FFFF
  PHY Control (0x00):
  PHY Status (0x01):
Page 0
  Register 0x1A:   FFFF
Page 2
  Register 0x02:   FFFF
rxring=0x1F4EFA20, rxr shadow=0x860BE33C, rx_head=57, rx_tail=0
txring=0x1F4EFE60, txr shadow=0x860BE570, tx_head=20, tx_tail=20, tx_count=0
Rx Frames=111741497, Bytes=1743336354
Tx Frames=130043860, Bytes=1595858097
51 status 9000,  len 44, buf_ptr 1F506FF8
52 status 9000,  len 44, buf_ptr 1F505338
53 status 9000,  len DE, buf_ptr 1F51E5B8
54 status 9000,  len 44, buf_ptr 1F4F89F8
55 status 9000,  len 44, buf_ptr 1F4F6608
56 status 9000,  len 12E, buf_ptr 1F50F158
57 status 9000,  len 44, buf_ptr 1F508CB8
58 status 9000,  len 44, buf_ptr 1F4FFCF8
59 status 9000,  len 44, buf_ptr 1F51B368
15 status 0,  len DA, buf_ptr 1F848D92
16 status 0,  len 502, buf_ptr 1F94B6E6
17 status 0,  len 526, buf_ptr 1F95C306
18 status 0,  len 526, buf_ptr 1F94A246
19 status 0,  len 526, buf_ptr 1F94C4A6
20 status 0,  len DA, buf_ptr 1F83FF12
21 status 0,  len 526, buf_ptr 1F957E46
22 status 0,  len 526, buf_ptr 1F952BC6
23 status 0,  len 526, buf_ptr 1F9599C6
24 status 0,  len DA, buf_ptr 1F83A992
25 status 0,  len 502, buf_ptr 1F9562C6
26 status 0,  len 526, buf_ptr 1F953986
27 status 0,  len 3E2, buf_ptr 1F94F4C6
28 status 0,  len 526, buf_ptr 1F955506
29 status 0,  len 526, buf_ptr 1F9592E6
30 status 0,  len 526, buf_ptr 1F957766
Interface Serial0/3/0:23
Hardware is HDLC32
HDLC32 resource allocated to this interface:
Slot 0, Vic_slot 3, Port 0
CRC on 1, idle flags 1, frame inverted 0, clocking 0
Channel-group number 23, hdlc32 channel number 0
Channel-group bitfield 0x100, hdlc32 quad used 0x1
Channel HW state: 2
TX Ring:
data_ptr: 0x0, descriptor: 0x0
RX Ring:
data_ptr: 0x1F999C24, descriptor: 0x88800000
data_ptr: 0x1F9999C4, descriptor: 0x88800000
data_ptr: 0x1F999504, descriptor: 0x88800000
data_ptr: 0x1F999764, descriptor: 0x88800000
hdlc_chan hdlc_quad owner_idb chan chan_bitfield vic_slot port
0         1         8825AA44  23   100           3        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
------------------ show user ------------------
------------------ show file systems ------------------
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   archive:
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     rw   null:
             -             -   network     rw   tftp:
        262144        230989     nvram     rw   nvram:
*    260177920     118382592      disk     rw   flash:#
             -             -    opaque     wo   syslog:
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -    opaque     ro   tar:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
------------------ show file descriptors ------------------
File Descriptors:
   FD  Position  Open  PID  Path
  No open file descriptors
------------------ dir nvram: ------------------
Directory of nvram:/
  228  -rw-       26111                      startup-config
  229  ----        1920                      private-config
  230  -rw-       26111                      underlying-config
    1  ----         102                      persistent-data
    2  -rw-         578                      IOS-Self-Sig#1.cer
    3  -rw-           0                      ifIndex-table
262144 bytes total (230989 bytes free)
------------------ show flash: all ------------------
-#- --length-- -----date/time------ path
1     37988016 Jul 04 2010 02:58:50 uc500-advipservicesk9-mz.150-1.XA
2            0 Jul 04 2010 03:04:18 phones
3            0 Jul 04 2010 03:04:18 phones/7975
4      2935993 Jul 04 2010 03:04:30 phones/7975/apps75.8-5-3TH1-6.sbn
5       524876 Jul 04 2010 03:04:32 phones/7975/cnu75.8-5-3TH1-6.sbn
6      2100554 Jul 04 2010 03:04:42 phones/7975/cvm75sccp.8-5-3TH1-6.sbn
7       340615 Jul 04 2010 03:04:44 phones/7975/dsp75.8-5-3TH1-6.sbn
8      1887312 Jul 04 2010 03:04:52 phones/7975/jar75sccp.8-5-3TH1-6.sbn
9          650 Jul 04 2010 03:04:54 phones/7975/SCCP75.8-5-3S.loads
10         654 Jul 04 2010 03:04:54 phones/7975/term75.default.loads
11           0 Jul 04 2010 03:04:56 phones/7970_7971
12     2933329 Jul 04 2010 03:05:06 phones/7970_7971/apps70.8-5-3TH1-6.sbn
13      500084 Jul 04 2010 03:05:10 phones/7970_7971/cnu70.8-5-3TH1-6.sbn
14     2103754 Jul 04 2010 03:05:18 phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn
15      537925 Jul 04 2010 03:05:22 phones/7970_7971/dsp70.8-5-3TH1-6.sbn
16     1828410 Jul 04 2010 03:05:34 phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn
17         650 Jul 04 2010 03:05:36 phones/7970_7971/SCCP70.8-5-3S.loads
18         654 Jul 04 2010 03:05:36 phones/7970_7971/term70.default.loads
19         654 Jul 04 2010 03:05:36 phones/7970_7971/term71.default.loads
20           0 Jul 04 2010 03:05:36 phones/7945_7965
21     2935993 Jul 04 2010 03:05:50 phones/7945_7965/apps45.8-5-3TH1-6.sbn
22      524969 Jul 04 2010 03:05:54 phones/7945_7965/cnu45.8-5-3TH1-6.sbn
23     2100804 Jul 04 2010 03:06:18 phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn
24      340615 Jul 04 2010 03:06:22 phones/7945_7965/dsp45.8-5-3TH1-6.sbn
25     1882934 Jul 04 2010 03:06:30 phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn
26         650 Jul 04 2010 03:06:32 phones/7945_7965/SCCP45.8-5-3S.loads
27         654 Jul 04 2010 03:06:32 phones/7945_7965/term45.default.loads
28         654 Jul 04 2010 03:06:32 phones/7945_7965/term65.default.loads
29           0 Jul 04 2010 03:06:32 phones/7942_7962
30     2935993 Jul 04 2010 03:06:46 phones/7942_7962/apps42.8-5-3TH1-6.sbn
31      524917 Jul 04 2010 03:06:52 phones/7942_7962/cnu42.8-5-3TH1-6.sbn
32     2099070 Jul 04 2010 03:07:00 phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn
33      340615 Jul 04 2010 03:07:02 phones/7942_7962/dsp42.8-5-3TH1-6.sbn
34     1756328 Jul 04 2010 03:07:10 phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn
35         670 Jul 04 2010 03:07:10 phones/7942_7962/SCCP42.8-5-3S.loads
36         674 Jul 04 2010 03:07:10 phones/7942_7962/term42.default.loads
37         674 Jul 04 2010 03:07:12 phones/7942_7962/term62.default.loads
38           0 Jul 04 2010 03:07:12 phones/7941_7961
39     2933329 Jul 04 2010 03:07:22 phones/7941_7961/apps41.8-5-3TH1-6.sbn
40      499644 Jul 04 2010 03:07:26 phones/7941_7961/cnu41.8-5-3TH1-6.sbn
41     2101414 Jul 04 2010 03:07:34 phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn
42      537925 Jul 04 2010 03:07:38 phones/7941_7961/dsp41.8-5-3TH1-6.sbn
43     1628021 Jul 04 2010 03:07:44 phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn
44         650 Jul 04 2010 03:07:46 phones/7941_7961/SCCP41.8-5-3S.loads
45         654 Jul 04 2010 03:07:46 phones/7941_7961/term41.default.loads
46         654 Jul 04 2010 03:07:46 phones/7941_7961/term61.default.loads
47           0 Jul 04 2010 03:07:46 phones/7940_7960
48      130552 Jul 04 2010 03:07:48 phones/7940_7960/P00308010200.bin
49         461 Jul 04 2010 03:07:48 phones/7940_7960/P00308010200.loads
50      708448 Jul 04 2010 03:07:52 phones/7940_7960/P00308010200.sb2
51      130956 Jul 04 2010 03:07:52 phones/7940_7960/P00308010200.sbn
52           0 Jul 04 2010 03:07:54 phones/7937
53     8095286 Jul 04 2010 03:08:24 phones/7937/apps37sccp.1-3-4-0.bin
54           0 Jul 04 2010 03:08:24 phones/7936
55     1850153 Jul 04 2010 03:08:32 phones/7936/cmterm_7936.3-3-20-0.bin
56           0 Jul 04 2010 03:08:34 phones/7931
57     2942935 Jul 04 2010 03:08:46 phones/7931/apps31.8-5-3TH1-6.sbn
58      503753 Jul 04 2010 03:08:48 phones/7931/cnu31.8-5-3TH1-6.sbn
59     2100286 Jul 04 2010 03:08:56 phones/7931/cvm31sccp.8-5-3TH1-6.sbn
60      340615 Jul 04 2010 03:09:00 phones/7931/dsp31.8-5-3TH1-6.sbn
61     1616425 Jul 04 2010 03:09:06 phones/7931/jar31sccp.8-5-3TH1-6.sbn
62         651 Jul 04 2010 03:09:08 phones/7931/SCCP31.8-5-3S.loads
63         655 Jul 04 2010 03:09:08 phones/7931/term31.default.loads
64           0 Jul 04 2010 03:09:08 phones/7925
65     2599169 Jul 04 2010 03:09:18 phones/7925/APPSH-1.3.3.SBN
66         900 Jul 04 2010 03:09:18 phones/7925/CP7925G-1.3.3.LOADS
67     1892036 Jul 04 2010 03:09:26 phones/7925/GUIH-1.3.3.SBN
68        1916 Jul 04 2010 03:09:28 phones/7925/MISCH-1.3.3.SBN
69     2118620 Jul 04 2010 03:09:34 phones/7925/SYSH-1.3.3.SBN
70      939293 Jul 04 2010 03:09:40 phones/7925/TNUXH-1.3.3.SBN
71     1939872 Jul 04 2010 03:09:48 phones/7925/WLANH-1.3.3.SBN
72           0 Jul 04 2010 03:09:48 phones/7921
73     2591877 Jul 04 2010 03:09:58 phones/7921/APPS-1.3.3.SBN
74         900 Jul 04 2010 03:10:00 phones/7921/CP7921G-1.3.3.LOADS
75     1848343 Jul 04 2010 03:10:06 phones/7921/GUI-1.3.3.SBN
76        1916 Jul 04 2010 03:10:08 phones/7921/MISC-1.3.3.SBN
77     2083047 Jul 04 2010 03:10:16 phones/7921/SYS-1.3.3.SBN
78      896477 Jul 04 2010 03:10:28 phones/7921/TNUX-1.3.3.SBN
79     1379535 Jul 04 2010 03:10:36 phones/7921/WLAN-1.3.3.SBN
80           0 Jul 04 2010 03:10:36 phones/7916
81      166179 Jul 04 2010 03:10:36 phones/7916/B016-1-0-4.SBN
82           0 Jul 04 2010 03:10:38 phones/7915
83      147287 Jul 04 2010 03:10:38 phones/7915/B015-1-0-4.SBN
84           0 Jul 04 2010 03:10:38 phones/7914
85       50244 Jul 04 2010 03:10:38 phones/7914/S00105000400.sbn
86           0 Jul 04 2010 03:10:40 phones/7906_7911
87     2942935 Jul 04 2010 03:10:50 phones/7906_7911/apps11.8-5-3TH1-6.sbn
88      503269 Jul 04 2010 03:10:54 phones/7906_7911/cnu11.8-5-3TH1-6.sbn
89     2104751 Jul 04 2010 03:11:02 phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn
90      340615 Jul 04 2010 03:11:06 phones/7906_7911/dsp11.8-5-3TH1-6.sbn
91     1616686 Jul 04 2010 03:11:14 phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn
92         670 Jul 04 2010 03:11:16 phones/7906_7911/SCCP11.8-5-3S.loads
93         674 Jul 04 2010 03:11:16 phones/7906_7911/term06.default.loads
94         674 Jul 04 2010 03:11:16 phones/7906_7911/term11.default.loads
95           0 Jul 04 2010 03:11:18 phones/5x5
96     3477171 Jul 04 2010 03:11:30 phones/5x5/spa5x5-7-4-2.bin
97           0 Jul 04 2010 03:11:30 phones/525
98    10753536 Jul 04 2010 03:12:10 phones/525/spa525g-7-4-2.bin
99           0 Jul 04 2010 03:12:12 phones/521_524
100     892511 Jul 04 2010 03:12:16 phones/521_524/cp524g-8-1-17.bin
101          0 Jul 04 2010 03:12:24 Desktops
102     131470 Jul 04 2010 03:12:24 Desktops/CampusNight.png
103      80565 Jul 04 2010 03:12:26 Desktops/CiscoFountain.png
104       8156 Jul 04 2010 03:12:26 Desktops/CiscoLogo.png
105     138278 Jul 04 2010 03:12:26 Desktops/Fountain.png
106     109076 Jul 04 2010 03:12:28 Desktops/MorroRock.png
107     108087 Jul 04 2010 03:12:28 Desktops/NantucketFlowers.png
108      10820 Jul 04 2010 03:12:30 Desktops/TN-CampusNight.png
109       9657 Jul 04 2010 03:12:30 Desktops/TN-CiscoFountain.png
110       2089 Jul 04 2010 03:12:30 Desktops/TN-CiscoLogo.png
111       7953 Jul 04 2010 03:12:30 Desktops/TN-Fountain.png
112       7274 Jul 04 2010 03:12:30 Desktops/TN-MorroRock.png
113       9933 Jul 04 2010 03:12:32 Desktops/TN-NantucketFlowers.png
114          0 Jul 04 2010 03:12:32 Desktops/320x216x16
115        651 Jul 04 2010 03:12:32 Desktops/320x216x16/List.xml
116          0 Jul 04 2010 03:12:32 Desktops/320x212x16
117        651 Jul 04 2010 03:12:32 Desktops/320x212x16/List.xml
118          0 Jul 04 2010 03:12:32 Desktops/320x212x12
119        651 Jul 04 2010 03:12:34 Desktops/320x212x12/List.xml
120          0 Jul 04 2010 03:12:34 autoattendant
121      94503 Jul 04 2010 03:12:34 autoattendant/AA_SBCS_v01.aef
122      96166 Jul 04 2010 03:12:34 autoattendant/AA_SBCS_v02.aef
123      15891 Jul 04 2010 03:12:36 autoattendant/AA_transfer.aef
124          0 Jul 04 2010 03:12:36 bacdprompts
125      30421 Jul 04 2010 03:12:36 bacdprompts/app-b-acd-3.0.0.2.tcl
126      55599 Jul 04 2010 03:12:36 bacdprompts/app-b-acd-aa-3.0.0.2.tcl
127      75650 Jul 04 2010 03:12:38 bacdprompts/en_bacd_allagentsbusy.au
128      83291 Jul 04 2010 03:12:38 bacdprompts/en_bacd_disconnect.au
129      63055 Jul 04 2010 03:12:40 bacdprompts/en_bacd_enter_dest.au
130      37952 Jul 04 2010 03:12:40 bacdprompts/en_bacd_invalidoption.au
131     496521 Jul 04 2010 03:12:42 bacdprompts/en_bacd_music_on_hold.au
132     123446 Jul 04 2010 03:12:44 bacdprompts/en_bacd_options_menu.au
133      42978 Jul 04 2010 03:12:44 bacdprompts/en_bacd_welcome.au
134      34794 Jul 04 2010 03:12:44 bacdprompts/en_bacd_xferto_operator.au
135          0 Jul 04 2010 03:12:46 cca
136        657 Jul 04 2010 03:12:46 cca/Key_Phoneloads.csv
137      91626 Jul 04 2010 03:12:46 cca/sccpphoneloadstable.csv
138        385 Jul 04 2010 03:12:46 cca/UC500_CCA_Dir_8.0.0.txt
139          0 Jul 04 2010 03:12:48 gui
140       4118 Jul 04 2010 03:12:48 gui/admin_user.html
141     677820 Jul 04 2010 03:12:50 gui/admin_user.js
142       1029 Jul 04 2010 03:12:52 gui/CiscoLogo.gif
143        657 Jul 04 2010 03:12:52 gui/CME_GUI_README.TXT
144        953 Jul 04 2010 03:12:52 gui/Delete.gif
145      16344 Jul 04 2010 03:12:52 gui/dom.js
146        864 Jul 04 2010 03:12:54 gui/downarrow.gif
147       6315 Jul 04 2010 03:12:54 gui/ephone_admin.html
148       4558 Jul 04 2010 03:12:54 gui/logohome.gif
149       3978 Jul 04 2010 03:12:54 gui/normal_user.html
150      78428 Jul 04 2010 03:12:54 gui/normal_user.js
151       1347 Jul 04 2010 03:12:56 gui/Plus.gif
152        843 Jul 04 2010 03:12:56 gui/sxiconad.gif
153        174 Jul 04 2010 03:12:56 gui/Tab.gif
154       2494 Jul 04 2010 03:12:56 gui/telephony_service.html
155        870 Jul 04 2010 03:12:58 gui/uparrow.gif
156      10230 Jul 04 2010 03:12:58 gui/xml-test.html
157       3412 Jul 04 2010 03:12:58 gui/xml.template
158          0 Jul 04 2010 03:12:58 gui/sn
159      11899 Jul 04 2010 03:12:58 gui/sn/handshake.html
160     633459 Jul 04 2010 03:13:02 gui/sn/handshake.swf
161          0 Jul 04 2010 03:13:02 media
162     496521 Jul 04 2010 03:13:04 media/music-on-hold.au
163     496521 Jul 04 2010 03:13:06 media/music-on-hold_10db.au
164          0 Jul 04 2010 03:13:08 ringtones
165       8160 Jul 04 2010 03:13:08 ringtones/Analog1.raw
166       8160 Jul 04 2010 03:13:08 ringtones/Analog2.raw
167       5280 Jul 04 2010 03:13:10 ringtones/AreYouThere.raw
168       5040 Jul 04 2010 03:13:10 ringtones/AreYouThereF.raw
169       8160 Jul 04 2010 03:13:10 ringtones/Bass.raw
170      12240 Jul 04 2010 03:13:10 ringtones/CallBack.raw
171      16040 Jul 04 2010 03:13:10 ringtones/Chime.raw
172       8160 Jul 04 2010 03:13:12 ringtones/Classic1.raw
173      16080 Jul 04 2010 03:13:12 ringtones/Classic2.raw
174      10800 Jul 04 2010 03:13:12 ringtones/ClockShop.raw
175       2823 Jul 04 2010 03:13:12 ringtones/DistinctiveRingList.xml
176       9600 Jul 04 2010 03:13:12 ringtones/Drums1.raw
177      13440 Jul 04 2010 03:13:14 ringtones/Drums2.raw
178      15840 Jul 04 2010 03:13:14 ringtones/FilmScore.raw
179      16080 Jul 04 2010 03:13:14 ringtones/HarpSynth.raw
180       8160 Jul 04 2010 03:13:14 ringtones/Jamaica.raw
181      16080 Jul 04 2010 03:13:16 ringtones/KotoEffect.raw
182      12720 Jul 04 2010 03:13:16 ringtones/MusicBox.raw
183       8160 Jul 04 2010 03:13:16 ringtones/Piano1.raw
184      15360 Jul 04 2010 03:13:16 ringtones/Piano2.raw
185       9360 Jul 04 2010 03:13:16 ringtones/Pop.raw
186       7200 Jul 04 2010 03:13:18 ringtones/Pulse1.raw
187       4000 Jul 04 2010 03:13:18 ringtones/Ring1.raw
188       4000 Jul 04 2010 03:13:18 ringtones/Ring2.raw
189       4000 Jul 04 2010 03:13:18 ringtones/Ring3.raw
190       4000 Jul 04 2010 03:13:18 ringtones/Ring4.raw
191       4000 Jul 04 2010 03:13:20 ringtones/Ring5.raw
192       4000 Jul 04 2010 03:13:20 ringtones/Ring6.raw
193       4000 Jul 04 2010 03:13:20 ringtones/Ring7.raw
194       2823 Jul 04 2010 03:13:20 ringtones/RingList.xml
195      10800 Jul 04 2010 03:13:22 ringtones/Sax1.raw
196      14160 Jul 04 2010 03:13:22 ringtones/Sax2.raw
197      16080 Jul 04 2010 03:13:22 ringtones/Vibe.raw
198          0 Jul 04 2010 03:13:22 sn
199          0 Jul 04 2010 03:13:22 sn/tmp
200          0 Jul 04 2010 03:13:22 sn/status
201        720 Jul 04 2010 03:13:24 vlan.dat
202      30169 Jul 04 2010 03:13:32 UC560-T1E1-K9-factory-8.0.0.cfg
203       1161 Sep 09 2010 17:18:38 FHK1427F48H_20100909171749679.lic
204       1161 Sep 09 2010 17:18:38 uc500-48u-upgrade.lic
205        981 Oct 27 2010 15:04:10 speeddial.xml
118382592 bytes available (141795328 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Manufacturer Name
   Model Number           UNIGEN FLASH
   Serial Number          UNIGEN      10007781
   Firmware Revision      081107
   Number of Heads        16
   Number of Cylinders    994
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          508928
ATA PARTITION 1 INFO
   Start Sector           32
   Number of Sectors      508896
   Size in Bytes          260554752
   File System Type       FAT16
   Number of FAT Sectors  249
   Sectors Per Cluster    8
   Number of Clusters     63520
   Number of Data Sectors 508160
   Base FAT Sector        205
   Base Root Sector       703
   Base Data Sector       735
ATA MONLIB INFO
   Image Monlib size      100616
   Disk Monlib Size       100616
   Disk Space Available   104448
   Name                   freddo-atafslib-m
   Start sector           2
   End sector             198
   Updated By             UC500-ADVIPSERVICESK9-M15.0(1)XA
   Version                2
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   85BFADD4   427000364    90127528   336872836   335657980   336401848
      I/O   1F333000    13422592     8444588     4978004     4827456     4746652
------------------ show process memory ------------------
Processor Pool Total:  427000364 Used:   90126128 Free:  336874236
      I/O Pool Total:   13422592 Used:    8444208 Free:    4978384
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  155548188   81382936   69493800          0          0 *Init*
   0   0      12052 1450141996      12052          0          0 *Sched*
   0   0 2041022716 3385862908    7863448    3952548    3952548 *Dead*
   0   0          0          0    1968632          0          0 *MallocLite*
   1   0   44788220   40485312    4545916          0          0 Chunk Manager
   2   0        236        236       4076          0          0 Load Meter
   3   0      13836        628      38964          0          0 LICENSE AGENT
   4   0   82575764   82510924      91356          0          0 EDDRI_MAIN
   5   0       3368        268      10176          0          0 Check heaps
   6   0   24664672   39413844      74320    4582360   12644780 Pool Manager
   7   0          0    2126612       7076          0     971432 DiscardQ Backgro
   8   0        236        236       7076          0          0 Timers
   9   0          0          0       7076          0          0 License Client N
  10   0          0          0      25076          0          0 Crash writer
  11   0          0          0       7076          0          0 IPC Process leve
  12   0          0          0       7076          0          0 IPC Dynamic Cach
  13   0          0          0       7076          0          0 IPC Zone Manager
  14   0          0          0       7076          0          0 IPC Service NonC
  15   0          0          0       7076          0          0 IPC Periodic Tim
  16   0          0          0       7076          0          0 IPC Deferred Por
  17   0       1704          0       8780          0          0 IPC Seat Manager
  18   0          0          0       7076          0          0 IPC Seat Control
  19   0          0          0       7076          0          0 IPC Loadometer
  20   0      43648      23440      27284          0          0 ARP Input
  21   0      55764      55224      40604          0          0 ARP Background
  22   0        236        236       7076          0          0 ATM Idle Timer
  23   0          0          0       7076          0          0 AAA_SERVER_DEADT
  24   0          0          0      13076          0          0 Policy Manager
  25   0        236        236       7076          0          0 DDR Timers
  26   0      23036      46464      30112          0       8320 Entity MIB API
  27   0     280372          0     290448      99792          0 EEM ED Syslog
  28   0        636        636       7076          0          0 PrstVbl
  29   0        236        236       7076          0          0 Serial Backgroun
  30   0          0          0       7076          0          0 RO Notify Timers
  31   0          0          0       4076          0          0 RMI RM Notify Wa
  32   0        236        236       7076          0          0 SMART
  33   0        236        236       7076          0          0 GraphIt
  34   0        236        236      13076          0          0 Dialer event
  35   0          0          0       7076          0          0 SERIAL A'detect
  36   0        236        236      13076          0          0 XML Proxy Client
  37   0          0          0       7076          0          0 Critical Bkgnd
  38   0      99116       2612      78344       3048          0 Net Background
  39   0       1996       1996      13076          0          0 IDB Work
  40   0      69684        276      13076      40608          0 Logger
  41   0      82804      90140       7076      31752          0 TTY Background
  42   0          0          0      10076          0          0 Per-Second Jobs
  43   0     158544  136592552     165044          0          0 IF-MGR control p
  44   0          0          0       7076          0          0 IF-MGR event pro
  45   0          0          0       4076          0          0 Inode Table Dest
  46   0        236        236       7076          0          0 Fast Throttle Ti
  47   0          0       2868       7076          0          0 AggMgr Process
  48   0          0          0       7076          0          0 Transport Port A
  49   0          0          0       7076          0          0 HC Counter Timer
  50   0        236        236       7076          0          0 AUX
  51   0        236        236       7076          0          0 Eswilp Storm Con
  52   0    2828544      25084    1418684          0          0 ESWPPM
  53   0        236        236       7076          0          0 SM Monitor
  54   0          0          0       4076          0          0 dev_device_inser
  55   0          0          0       4076          0          0 dev_device_remov
  56   0        236        236       7076          0          0 Netclock Backgro
  57   0      80432        236      87272          0          0 VNM DSPRM MAIN
  58   0        236        236       7076          0          0 FLEX DNLD MAIN
  59   0        236        236       7076          0          0 Service Module E
  60   0        284        284       7076          0          0 COLLECT STAT COU
  61   0        796        796       7076          0          0 Switch Link Moni
  62   0          0          0       7076          0          0 IGMP Snooping Pr
  63   0          0          0       7076          0          0 IGMP Snooping Re
  64   0 3604025396 3679360840     578480    8680176      35532 Skinny Msg Serve
  65   0          0          0       7076          0          0 Platform Compact
  66   0          0          0      10076          0          0 Crypto Device Up
  67   0          0          0       7076          0          0 Multi-ISA Event
  68   0          0          0       7076          0          0 Multi-ISA Cleanu
  69   0     426748     421664      12160          0          0 crypto engine pr
  70   0        236        236       7076          0          0 SEC BATCH
  71   0        236          0       4312          0          0 Async write proc
  72   0        236          0       4312          0          0 Async write proc
  73   0        236          0       4312          0          0 Async write proc
  74   0        236          0       4312          0          0 Async write proc
  75   0          0          0       4076          0          0 DFS flush period
  76   0        236        236       7076          0          0 PI MATM Aging Pr
  77   0       1076        236       7916          0          0 DTP Protocol
  78   0        236        236       7076          0          0 Dot1x Mgr Proces
  79   0          0          0       7076          0          0 EAP Framework
  80   0          0          0       7076          0          0 MAB Framework
  81   0        236        236      13076          0          0 Ethernet CFM
  82   0        236        236      13076          0          0 Ethernet Timer C
  83   0        236        236      13076          0          0 Ethernet Msec Ti
  84   0          0          0       7076          0          0 linktest
  85   0        236        236       9076          0          0 Dot11 Mgmt & Ass
  86   0        236        236      10076          0          0 Dot11 aaa proces
  87   0          0          0      10076          0          0 pmkid
  88   0        236        236      10076          0          0 Dot11 auth Dot1x
  89   0          0          0       7076          0          0 Dot11 Mac Auth
  90   0    6981712        236       7076          0          0 AAA Server
  91   0          0          0       7076          0          0 AAA ACCT Proc
  92   0      49392          0      56468          0          0 ACCT Periodic Pr
  93   0          0          0       7076          0          0 AAA System Acct
  94   0      31808      29924       8668          0          0 CDP Protocol
  95   0        236        236       7076          0          0 AAA Dictionary R
  96   0        236        236      10076          0          0 Ethernet OAM Pro
  97   0        228          0      13304          0          0 CEF switching ba
  98   0        228          0       4304          0          0 ADJ NSF process
  99   0      20648        220      33504          0          0 ADJ resolve proc
100   0        236        236       7076          0          0 IPAM/ODAP Events
101   0      54448          0      67524          0          0 IPAM Manager
102   0        236        236      13076          0          0 IPAM Events
103   0      86640      38064      55652          0          0 IP ARP Adjacency
104   0      49384          0      56460          0          0 IP ARP Retry Age
105   0  121085352   81187184      91004       3120     769860 IP Input
106   0          0          0       7076          0          0 ICMP event handl
107   0        236        236       7076          0          0 PIM register asy
108   0        236        236       7076          0          0 TurboACL
109   0        236        236       7076          0          0 TurboACL chunk
110   0          0          0       7076          0          0 IPv6 ping proces
111   0        236        236       7076          0          0 PPP SIP
112   0        236        236       7076          0          0 PPP Bind
113   0        236        236      13076          0          0 PPP IP Route
114   0    7558180    7366624      72092          0          0 AFW_application_
115   0          0          0      13076          0          0 SSS Manager
116   0          0          0      13076          0          0 SSS Policy Manag
117   0          0          0       7076          0          0 SSS Feature Mana
118   0          0          0       7076          0          0 SSS Feature Time
119   0      39840        236      13312       7020          0 Spanning Tree
120   0        236        236      13076          0          0 SSM connection m
121   0          0          0       7076          0          0 Authentication P
122   0          0          0       7076          0          0 Auth-proxy AAA B
123   0        236        236      10076          0          0 EAPoUDP Process
124   0        236        236      10076          0          0 IP Host Track Pr
125   0        236        236      13076          0          0 KRB5 AAA
126   0      12084         76      19392          0          0 CEF background p
127   0      20080       2896      20012          0          0 CEF: IPv4 proces
128   0        228          0       7304          0          0 ADJ background
129   0       1624        664       8700          0          0 L2MM
130   0          0          0       7076          0          0 MRD
131   0          0          0       7076          0          0 IGMPSN
132   0        472        236       7312          0          0 Dot1x Supplicant
133   0        472        236       7312          0          0 Dot1x Supplicant
134   0        464        236       7304          0          0 Dot1x Supplicant
135   0        236        236       7076          0          0 RLM groups Proce
136   0  973058892  973058892       7076          0          0 Licensing Auto U
137   0          0          0       7076          0          0 SNMP Timers
138   0        236        236       7076          0          0 PPP Compress Inp
139   0        236        236       7076          0          0 PPP Compress Res
140   0          0          0       7076          0          0 Socket Timers
141   0       4320    3276944      13076          0      94752 TCP Timer
142   0   30895280       3208      13076          0          0 TCP Protocols
143   0        940          0      62016          0          0 COPS
144   0        236        236       7076          0          0 Flow Exporter Ti
145   0 2671926872 1283462744      46608       5076          0 HTTP CORE
146   0          0          0       7076          0          0 IP Traceroute
147   0      21104      46376      17572          0       3384 SCCP Application
148   0        228          0      13304          0          0 MFIB Master back
149   0          0          0       7076          0          0 RARP Input
150   0      12584      18200      10152          0          0 IP Background
151   0     258360     231324      41272          0          0 IP Connected Rou
152   0      19888       7376      25588          0          0 IP RIB Update
153   0      12108      21020      10076          0          0 static
154   0          0          0      10076          0          0 IP IRDP
155   0          0          0       7076          0          0 IPv6 Inspect Tim
156   0          0          0       7076          0          0 MQC Flow Event B
157   0          0          0       7076          0          0 HQF Shaper Backg
158   0        236        236       7076          0          0 RUDPV1 Main Proc
159   0      85224        236      26332          0          0 SCTP Main Proces
160   0          0          0      13076          0          0 VPDN call manage
161   0          0          0      13076          0          0 IPS Process
162   0      16796        236      29636          0          0 IPS Auto Update
163   0        372        236       7212          0          0 SDEE Management
164   0        236        236       7076          0          0 Inspect process
165   0          0       1772       7092          0          0 DHCPD Timer
166   0        236        236       7076          0          0 FW DP Inspect pr
167   0        236        236       7076          0          0 CCE DP URLF cach
168   0     189088          0      15476          0          0 SSH Event handle
169   0       1176        236       8016          0          0 URL filter proc
170   0          0          0       7076          0          0 Select Timers
171   0      76456        236      83296          0          0 HTTP Process
172   0       2196        236       9036          0          0 CIFS API Process
173   0      12576        236      19416          0          0 CIFS Proxy Proce
174   0     218132        472     215660          0          0 Crypto HW Proc
175   0       9180        236      16020          0          0 CCVPM_HDSPRM
176   0  185654564  185654564       7076          0          0 CRM_CALL_UPDATE_
177   0          0          0      13076          0          0 Skinny MOH Serve
178   0        236        236       7076          0          0 AAA Cached Serve
179   0        236        236       7076          0          0 ENABLE AAA
180   0          0          0       7076          0          0 EM Background Pr
181   0          0          0       7076          0          0 IDMGR CORE
182   0          0          0       7076          0          0 Key chain liveke
183   0        236        236       7076          0          0 LINE AAA
184   0     366656    7043432       7076          0          0 LOCAL AAA
185   0       1088        236       7928          0          0 TPLUS
186   0        236        236       7076          0          0 VSP_MGR
187   0        940          0      26016          0          0 FW_TEST_TRP
188   0          0          0       7116          0          0 EPM MAIN PROCESS
189   0      71008        236      79848          0          0 Crypto WUI
190   0        236        236       7076          0          0 Crypto Support
191   0          0          0       7076          0          0 IPSECv6 PS Proc
192   0  145393716   68028428     388904       9072          0 CCVPM_HTSP
193   0        236        236       7076          0          0 VPM_MWI_BACKGROU
194   0        436          0       7512          0          0 CCVPM_R2
195   0          0          0       7076          0          0 EPHONE MWI Refre
196   0          0          0       7076          0          0 FB/KS Log HouseK
197   0        304        304       7076          0          0 EPHONE MWI BG Pr
198   0       8244          0      15320          0          0 Skinny HW confer
199   0     560524       1888     315252          0          0 FLEX DSPRM MAIN
200   0          0          0       7076          0          0 FLEX DSP KEEPALI
201   0       5944        236      30784          0          0 CTI Front End Pr
202   0        236        236       7076          0          0 CTI Call Control
203   0        236        236       7076          0          0 CTI Line Monitor
204   0          0          0       7076          0          0 CME CTI Device M
205   0        304        304       7076          0          0 VOICE REG BG Pro
206   0       5052          0      12128          0          0 Presence Process
207   0   19358300   19297920      57016          0          0 SCCP Telephony C
208   0        940          0      62016          0          0 http client proc
209   0          0          0       7124          0          0 ASNL
210   0     254136          0     264212          0          0 QOS_MODULE_MAIN
211   0        284          0      25360          0          0 RPMS_PROC_MAIN
212   0          0          0      25076          0          0 VoIP AAA
213   0      23848        236      30688          0          0 Dialog Manager
214   0       2340       1576      14600          0          0 Crypto CA
215   0          0          0      13076          0          0 Crypto PKI-CRL
216   0          0          0      13136          0          0 encrypt proc
217   0  700356584  713313132       8740          0          0 crypto sw pk pro
218   0          0          0       7076          0          0 Crypto INT
219   0        236        708      13076          0          0 Crypto IKE Dispa
220   0       5212        236      18052          0          0 Crypto IKMP
221   0          0          0       7076          0          0 IPSEC manual key
222   0     174256      90292      17404       2268          0 IPSEC key engine
223   0          0          0       7076          0          0 CRYPTO QoS proce
224   0      59464      67984      25712          0          0 Crypto ACL
225   0          0          0       7076          0          0 Crypto PAS Proc
226   0          0          0       7076          0          0 GDOI GM Process
227   0          0          0       7076          0          0 UNICAST REKEY
228   0          0          0       7076          0          0 UNICAST REKEY AC
229   0        236        236       7076          0          0 Environmental mo
230   0      21920      28884      11460          0          0 PM Callback
231   0        236        236       7076          0          0 Control-plane ho
232   0          0          0      10076          0          0 Licensing MIB pr
233   0        224          0       7300          0          0 DATA Transfer Pr
234   0        224          0       7300          0          0 DATA Collector
235   0    3494416  184852476       7076          0          0 AAA SEND STOP EV
236   0       3700          0      13776          0          0 EEM ED Track
237   0       5508          0      15584          0          0 EEM ED Resource
238   0       3700          0      13776          0          0 EEM ED Routing
239   0        236        236       7076          0          0 RMON Recycle Pro
240   0        236        236       7076          0          0 RMON Deferred Se
241   0          0          0       7076          0          0 Syslog Traps
242   0          0          0       7076          0          0 Crypto cTCP proc
243   0     473344     464392      15868          0          0 VLAN Manager
244   0        224          0       7300          0          0 DHCPD Database
245   0          0          0       7076          0          0 trunk conditioni
246   0       4660          0      11736          0          0 trunk conditioni
247   0        812          0      25888          0          0 RTSP_CLIENT
248   0          0          0       7076          0          0 CME Extension Mo
249   0     188916          0     195992          0          0 EEM Server
250   0      11264       1740      16600          0          0 EEM Policy Direc
251   0       3700          0      13776          0          0 EEM ED CLI
252   0       3700          0      13776          0          0 EEM ED Counter
253   0       3700          0      13776          0          0 EEM ED Interface
254   0       3700          0      13776          0          0 EEM ED IOSWD
255   0       5752          0      15828          0          0 EEM ED None
256   0       3700          0      13776          0          0 EEM ED OIR
257   0        232          0      13376          0          0 Collection proce
258   0       3700          0      13776          0          0 EEM ED Timer
259   0       3700          0      13776          0          0 EEM ED Ipsla
260   0       3700          0      13776          0          0 EEM ED SNMP Obje
261   0       3700          0      13776          0          0 EEM ED Test
262   0       3700          0      13776          0          0 EEM ED Config
263   0       3700          0      13776          0          0 EEM ED Env
264   0       3700          0      13776          0          0 EM ED GOLD
265   0       8752          0      18828          0          0 EEM ED Nf
266   0    6370524    6370524      13076          0          0 Syslog
267   0          0          0       7076          0          0 VDC process
268   0       3700          0      13776          0          0 EEM ED RPC
269   0          0          0       7076          0          0 Net Input
270   0        236        236       7076          0          0 Compute load avg
271   0       2036  460391164       7076        756          0 Per-minute Jobs
272   0       1388        236      14228          0          0 MRIB Process
273   0          0          0       9076          0          0 Key Proc
274   0        236        236       7076          0          0 TRP_PSEUDOTIMER
275   0        524        236       7364          0          0 Resource Monitor
276   0 1515378724   15594392     233912          0          0 CC-API_VCM
277   0        236        236      13076          0          0 confmsp
278   0 1640595760 1866415940     253004       2268          0 DSMP
279   0 4187254332 3348780348     743216       4536          0 VTSP
280   0    4282988   42821244      10816       2268          0 VOIP_RTCP
281   0     249944          0      32412          0          0 Session Applicat
282   0     407808        236     420648          0          0 swmtp_msp
283   0      35304   11201112      60380          0          0 TSP
284   0        872          0      13948          0          0 lib_off_app
285   0        236        236       7076          0          0 Voice Player
286   0          0          0       7076          0          0 Media Record
287   0          0          0       7076          0          0 Resource Measure
288   0     912920        236     973760          0          0 CCH323_CT
289   0          0          0       7076          0          0 CCH323_DNS
290   0  751432692  890869220    2407376          0          0 CCSIP_SPI_CONTRO
291   0          0          0      13076          0          0 CCSIP_DNS
292   0  187726264   89720284     135088       5076          0 CCSIP_UDP_SOCKET
293   0     216140        236     240980          0          0 CCSIP_TCP_SOCKET
294   0     218136        236     242976          0          0 CCSIP_TLS_SOCKET
295   0     460052          0     485128          0          0 RTPSPI
296   0       1436        304       8228          0          0 e1t1 Framer back
297   0     777736     714948      59992          0          0 DHCPD Receive
298   0          0          0       7076          0          0 RTSP_DNS
299   0  186182212   47948996     298532       8316          0 ISDN
300   0        236        236      25076          0          0 ISDN Timer
301   0          0      59568       7076          0          0 ISDNMIB Backgrou
302   0          0    3650312       7076          0          0 CallMIB Backgrou
303   0          0          0       7076          0          0 ISDN From Driver
304   0          0          0      13076          0          0 DHCP Client
305   0          0          0       7076          0          0 RAC I/F Conf.
306   0       4256       4848       7076          0          0 IP NAT Ager
307   0          0          0       7076          0          0 IP NAT WLAN
308   0          0          0       7076          0          0 IP VFR proc
309   0        800      26064      25940          0          0 MRCP_CLIENT
310   0      11756          0      17660          0          0 DNS Server
311   0       1184        236      14044          0          0 IP SNMP
312   0          0          0      13076          0          0 PDU DISPATCHER
313   0        636        636      13076          0          0 SNMP ENGINE
314   0      11236        236      24076          0          0 IP SNMPV6
315   0          0          0      13076          0          0 SNMP ConfCopyPro
316   0        236        236      13076          0          0 SNMP Traps
317   0          0          0       7076          0          0 NAT MIB Helper
318   0        236          0       7312          0          0 DNS Server Input
319   0     931372     921840      34608          0          0 HTTP CP
320   0      36132        236      48972          0          0 MLD
321   0          0          0      10076          0          0 IPv6 RIB Event H
322   0        236        236       7076          0          0 Skinny MOH Event
323   0    7290876    6798476      27144          0          0 Skinny Socket Se
324   0  699803744  699803504      13316          0          0 Web Write Housek
325   0       1000        692      13384          0          0 NTP
326   0          0          0      10076          0          0 ISDN L2 Process
327   0          0          0       7076          0          0 ISDN L3 Timer Pr
328   0          0          0       7076          0          0 ISDN L2D SRQ Pro
                                 98548976 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 20%/18%; one minute: 4%; five minutes: 3%
PID Runtime(uS)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1      996000       15097         65  0.00%  0.00%  0.00%   0 Chunk Manager
   2      740000      966233          0  0.00%  0.00%  0.00%   0 Load Meter
   3           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
   4     5048000      419790         12  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5    30792704      735169       5884  0.00%  0.07%  0.05%   0 Check heaps
   6      576000        6251         92  0.00%  0.00%  0.00%   0 Pool Manager
   7        4000          95         42  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   9           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  10           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  11           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  12      352000       80477          4  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  13           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  14     1920000      965620          1  0.00%  0.00%  0.00%   0 IPC Service NonC
  15      336000     4716182          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  16      184000     4716182          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  18           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Control
  19       84000      966146          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  20   436336000     3950762        110  0.07%  0.00%  0.00%   0 ARP Input
  21     2964000     5031942          0  0.00%  0.00%  0.00%   0 ARP Background
  22           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  23           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  24           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  25      136000       12022         11  0.00%  0.00%  0.00%   0 DDR Timers
  26        4000           2       2000  0.00%  0.00%  0.00%   0 Entity MIB API
  27     3452000       70289         49  0.00%  0.00%  0.00%   0 EEM ED Syslog
  28     1992000          14     142285  0.00%  0.00%  0.00%   0 PrstVbl
  29           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  30           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  31           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  32           0           2          0  0.00%  0.00%  0.00%   0 SMART
  33      368000     4831158          0  0.00%  0.00%  0.00%   0 GraphIt
  34           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  35           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  36           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  37           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  38    18940000      508812         37  0.00%  0.00%  0.00%   0 Net Background
  39           0           3          0  0.00%  0.00%  0.00%   0 IDB Work
  40      600000       61413          9  0.00%  0.00%  0.00%   0 Logger
  41    10344000     4827011          2  0.00%  0.00%  0.00%   0 TTY Background
  42     1440000     4831502          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
  43    36564000      359863        101  0.00%  0.00%  0.00%   0 IF-MGR control p
  44      340000       21487         15  0.00%  0.00%  0.00%   0 IF-MGR event pro
  45           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  46     5420000     2432659          2  0.00%  0.00%  0.00%   0 Fast Throttle Ti
  47           0          15          0  0.00%  0.00%  0.00%   0 AggMgr Process
  48           0          49          0  0.00%  0.00%  0.00%   0 Transport Port A
  49    32932000      986707         33  0.00%  0.00%  0.00%   0 HC Counter Timer
  50           0           2          0  0.00%  0.00%  0.00%   0 AUX
  51           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  52      200000          13      15384  0.00%  0.00%  0.00%   0 ESWPPM
  53     8544000      322025         26  0.00%  0.00%  0.00%   0 SM Monitor
  54           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  55           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  56     1256000    19312093          0  0.00%  0.00%  0.00%   0 Netclock Backgro
  57           0           2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  58        8000         254         31  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
  59      568000      482837          1  0.00%  0.00%  0.00%   0 Service Module E
  60  1803596000    24129678         74  0.07%  0.00%  0.02%   0 COLLECT STAT COU
  61       12000          10       1200  0.00%  0.00%  0.00%   0 Switch Link Moni
  62           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  63     1292000       33117         39  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  64   753881408    35672597        261  0.63%  0.21%  0.20%   0 Skinny Msg Serve
  65           0           1          0  0.00%  0.00%  0.00%   0 Platform Compact
  66      180000     4831167          0  0.00%  0.00%  0.00%   0 Crypto Device Up
  67           0           2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
  68           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
  69       92000          13       7076  0.00%  0.00%  0.00%   0 crypto engine pr
  70           0           2          0  0.00%  0.00%  0.00%   0 SEC BATCH
  71           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
  72           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
  73           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
  74           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
  75     1572000       80477         19  0.00%  0.00%  0.00%   0 DFS flush period
  76     1268000     4827015          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  77           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  78           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  79           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
  80           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
  81           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  82      968000    30014978          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
  83    15076000   613216716          0  0.00%  0.00%  0.00%   0 Ethernet Msec Ti
  84     1292000     4827025          0  0.00%  0.00%  0.00%   0 linktest
  85           0           2          0  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass
  86           0           2          0  0.00%  0.00%  0.00%   0 Dot11 aaa proces
  87      972000       80477         12  0.00%  0.00%  0.00%   0 pmkid
  88           0           2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  89           0           1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  90      180000         544        330  0.00%  0.00%  0.00%   0 AAA Server
  91           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  92           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  93           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  94    56444000      566571         99  0.00%  0.00%  0.00%   0 CDP Protocol
  95           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  96           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
  97           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
  98           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
  99        4000           9        444  0.00%  0.00%  0.00%   0 ADJ resolve proc
100           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
101     9560000   150591510          0  0.00%  0.00%  0.00%   0 IPAM Manager
102           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
103       88000         318        276  0.00%  0.00%  0.00%   0 IP ARP Adjacency
104           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
105  1977816704    28546665        219  0.00%  0.12%  0.16%   0 IP Input
106           0          84          0  0.00%  0.00%  0.00%   0 ICMP event handl
107           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
108           0           4          0  0.00%  0.00%  0.00%   0 TurboACL
109           0           2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
110           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
111           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
112           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
113           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
114     2084000        4310        483  0.00%  0.00%  0.00%   0 AFW_application_
115           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
116           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
117           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
118     1348000    18860511          0  0.00%  0.00%  0.00%   0 SSS Feature Time
119   124836000     7837648         15  0.00%  0.00%  0.00%   0 Spanning Tree
120           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
121           0       16104          0  0.00%  0.00%  0.00%   0 Authentication P
122           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
123           0           2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
124           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
125           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
126     2184000       96692         22  0.00%  0.00%  0.00%   0 CEF background p
127    10544000     5567244          1  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
128           0           3          0  0.00%  0.00%  0.00%   0 ADJ background
129     2084000       66518         31  0.00%  0.00%  0.00%   0 L2MM
130           0           1          0  0.00%  0.00%  0.00%   0 MRD
131     2992000       33112         90  0.00%  0.00%  0.00%   0 IGMPSN
132           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
133           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
134           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
135           0           2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
136  2685900000       80476      33375  0.63%  0.08%  0.05%   0 Licensing Auto U
137           0           2          0  0.00%  0.00%  0.00%   0 SNMP Timers
138           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
139           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
140           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
141     2652000      916080          2  0.00%  0.00%  0.00%   0 TCP Timer
142      700000        1382        506  0.00%  0.00%  0.00%   0 TCP Protocols
143           0           1          0  0.00%  0.00%  0.00%   0 COPS
144           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
145  1840364000     4452245        413  0.15%  0.01%  0.04%   0 HTTP CORE
146           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
147   354016000      711954        497  0.00%  0.00%  0.00%   0 SCCP Application
148           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
149           0          34          0  0.00%  0.00%  0.00%   0 RARP Input
150      876000       80529         10  0.00%  0.00%  0.00%   0 IP Background
151        8000          95         84  0.00%  0.00%  0.00%   0 IP Connected Rou
152           0           8          0  0.00%  0.00%  0.00%   0 IP RIB Update
153        4000          10        400  0.00%  0.00%  0.00%   0 static
154           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
155           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
156           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
157    40860000  1202301801          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
158     2488000     4827098          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
159        4000           2       2000  0.00%  0.00%  0.00%   0 SCTP Main Proces
160           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
161           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
162           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
163           0           2          0  0.00%  0.00%  0.00%   0 SDEE Management
164      492000     9431808          0  0.00%  0.00%  0.00%   0 Inspect process
165        4000       40300          0  0.00%  0.00%  0.00%   0 DHCPD Timer
166       56000      311592          0  0.00%  0.00%  0.00%   0 FW DP Inspect pr
167      516000     9431807          0  0.00%  0.00%  0.00%   0 CCE DP URLF cach
168       52000        2685         19  0.00%  0.00%  0.00%   0 SSH Event handle
169           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
170           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
171       28000           2      14000  0.00%  0.00%  0.00%   0 HTTP Process
172           0           2          0  0.00%  0.00%  0.00%   0 CIFS API Process
173           0           2          0  0.00%  0.00%  0.00%   0 CIFS Proxy Proce
174        4000           3       1333  0.00%  0.00%  0.00%   0 Crypto HW Proc
175      100000           2      50000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
176       60000      193248          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
177     1932000     4826915          0  0.00%  0.00%  0.00%   0 Skinny MOH Serve
178           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
179           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
180           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
181           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
182           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
183           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
184      372000        9175         40  0.00%  0.00%  0.00%   0 LOCAL AAA
185           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
186           0           2          0  0.00%  0.00%  0.00%   0 VSP_MGR
187           0           1          0  0.00%  0.00%  0.00%   0 FW_TEST_TRP
188           0           1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
189           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
190           0           2          0  0.00%  0.00%  0.00%   0 Crypto Support
191           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
192   285928000     1664352        171  0.00%  0.00%  0.00%   0 CCVPM_HTSP
193           0           2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
194           0           1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
195           0           1          0  0.00%  0.00%  0.00%   0 EPHONE MWI Refre
196           0        5368          0  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
197           0           2          0  0.00%  0.00%  0.00%   0 EPHONE MWI BG Pr
198           0           1          0  0.00%  0.00%  0.00%   0 Skinny HW confer
199     3100000     3812724          0  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
200     3040000     1787707          1  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
201           0           2          0  0.00%  0.00%  0.00%   0 CTI Front End Pr
202           0           2          0  0.00%  0.00%  0.00%   0 CTI Call Control
203           0           2          0  0.00%  0.00%  0.00%   0 CTI Line Monitor
204           0           1          0  0.00%  0.00%  0.00%   0 CME CTI Device M
205     2012000      161153         12  0.00%  0.00%  0.00%   0 VOICE REG BG Pro
206           0           1          0  0.00%  0.00%  0.00%   0 Presence Process
207     2948000       27889        105  0.00%  0.00%  0.00%   0 SCCP Telephony C
208           0           1          0  0.00%  0.00%  0.00%   0 http client proc
209           0           1          0  0.00%  0.00%  0.00%   0 ASNL
210           0           1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
211           0           1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
212           0           1          0  0.00%  0.00%  0.00%   0 VoIP AAA
213        4000           2       2000  0.00%  0.00%  0.00%   0 Dialog Manager
214           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
215           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
216           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
217   619344000       98424       6292  0.00%  0.00%  0.00%   0 crypto sw pk pro
218           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
219           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
220           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKMP
221           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
222     1300000      241426          5  0.00%  0.00%  0.00%   0 IPSEC key engine
223           0           1          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
224           0           6          0  0.00%  0.00%  0.00%   0 Crypto ACL
225           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
226           0           1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
227           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY
228           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY AC
229     3768000      967805          3  0.00%  0.00%  0.00%   0 Environmental mo
230      280000     2434450          0  0.00%  0.00%  0.00%   0 PM Callback
231           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
232           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
233           0           1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
234           0           1          0  0.00%  0.00%  0.00%   0 DATA Collector
235     4028000       25772        156  0.07%  0.00%  0.00%   0 AAA SEND STOP EV
236           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Track
237           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Resource
238           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
239      512000      482837          1  0.00%  0.00%  0.00%   0 RMON Recycle Pro
240           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
241           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
242       64000      150973          0  0.00%  0.00%  0.00%   0 Crypto cTCP proc
243       20000           2      10000  0.00%  0.00%  0.00%   0 VLAN Manager
244      312000       80476          3  0.00%  0.00%  0.00%   0 DHCPD Database
245      896000     4826515          0  0.00%  0.00%  0.00%   0 trunk conditioni
246           0           1          0  0.00%  0.00%  0.00%   0 trunk conditioni
247           0           7          0  0.00%  0.00%  0.00%   0 RTSP_CLIENT
248      340000     4831167          0  0.00%  0.00%  0.00%   0 CME Extension Mo
249      404000        8140         49  0.00%  0.00%  0.00%   0 EEM Server
250           0           2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
251           0           3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
252           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
253           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
254           0           3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
255           0           3          0  0.00%  0.00%  0.00%   0 EEM ED None
256           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
257           0           3          0  0.00%  0.00%  0.00%   0 Collection proce
258       20000      120993          0  0.00%  0.00%  0.00%   0 EEM ED Timer
259           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
260           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
261           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Test
262           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Config
263           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
264           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
265           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Nf
266      260000       22138         11  0.00%  0.00%  0.00%   0 Syslog
267     2848000      965620          2  0.00%  0.00%  0.00%   0 VDC process
268           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
269   135748000     5220038         26  0.00%  0.00%  0.00%   0 Net Input
270     4280000      966835          4  0.00%  0.00%  0.00%   0 Compute load avg
271   966648000       82927      11656  0.00%  0.01%  0.00%   0 Per-minute Jobs
272           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
273           0           2          0  0.00%  0.00%  0.00%   0 Key Proc
274      172000     4831367          0  0.00%  0.00%  0.00%   0 TRP_PSEUDOTIMER
275     1452000       91515         15  0.00%  0.00%  0.00%   0 Resource Monitor
276     9212000      226289         40  0.00%  0.00%  0.00%   0 CC-API_VCM
277           0           2          0  0.00%  0.00%  0.00%   0 confmsp
278   563484000     1646124        342  0.00%  0.01%  0.00%   0 DSMP
279   523376000     2155151        242  0.00%  0.00%  0.00%   0 VTSP
280    15976000      197962         80  0.00%  0.00%  0.00%   0 VOIP_RTCP
281        4000           4       1000  0.00%  0.00%  0.00%   0 Session Applicat
282        4000           2       2000  0.00%  0.00%  0.00%   0 swmtp_msp
283     9960000       70170        141  0.00%  0.00%  0.00%   0 TSP
284           0           1          0  0.00%  0.00%  0.00%   0 lib_off_app
285        4000        5308          0  0.00%  0.00%  0.00%   0 Voice Player
286           0           1          0  0.00%  0.00%  0.00%   0 Media Record
287           0           1          0  0.00%  0.00%  0.00%   0 Resource Measure
288       12000           2       6000  0.00%  0.00%  0.00%   0 CCH323_CT
289           0           1          0  0.00%  0.00%  0.00%   0 CCH323_DNS
290   204920000      293270        698  0.00%  0.01%  0.00%   0 CCSIP_SPI_CONTRO
291           0           1          0  0.00%  0.00%  0.00%   0 CCSIP_DNS
292    83400000      340007        245  0.07%  0.01%  0.00%   0 CCSIP_UDP_SOCKET
293        4000           2       2000  0.00%  0.00%  0.00%   0 CCSIP_TCP_SOCKET
294           0           6          0  0.00%  0.00%  0.00%   0 CCSIP_TLS_SOCKET
295      616000       80478          7  0.00%  0.00%  0.00%   0 RTPSPI
296     2680000    19312139          0  0.00%  0.00%  0.00%   0 e1t1 Framer back
297     2956000       32533         90  0.00%  0.00%  0.00%   0 DHCPD Receive
298           0           1          0  0.00%  0.00%  0.00%   0 RTSP_DNS
299    58884000       73177        804  0.00%  0.00%  0.00%   0 ISDN
300           0          13          0  0.00%  0.00%  0.00%   0 ISDN Timer
301           0        9281          0  0.00%  0.00%  0.00%   0 ISDNMIB Backgrou
302        8000       21902          0  0.00%  0.00%  0.00%   0 CallMIB Backgrou
303     5004000      498009         10  0.00%  0.00%  0.00%   0 ISDN From Driver
304     1596000     4827024          0  0.00%  0.00%  0.00%   0 DHCP Client
305     1440000      965620          1  0.00%  0.00%  0.00%   0 RAC I/F Conf.
306      452000     9431808          0  0.00%  0.00%  0.00%   0 IP NAT Ager
307           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
308           0           1          0  0.00%  0.00%  0.00%   0 IP VFR proc
309     3492000      746907          4  0.00%  0.00%  0.00%   0 MRCP_CLIENT
310     3660000     4827020          0  0.00%  0.00%  0.00%   0 DNS Server
311           0           2          0  0.00%  0.00%  0.00%   0 IP SNMP
312           0           1          0  0.00%  0.00%  0.00%   0 PDU DISPATCHER
313       52000           4      13000  0.00%  0.00%  0.00%   0 SNMP ENGINE
314           0           2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
315           0           1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
316           0           2          0  0.00%  0.00%  0.00%   0 SNMP Traps
317           0           1          0  0.00%  0.00%  0.00%   0 NAT MIB Helper
318           0           1          0  0.00%  0.00%  0.00%   0 DNS Server Input
319      972000         163       5963  0.00%  0.00%  0.00%   0 HTTP CP
320     1736000    19313846          0  0.00%  0.00%  0.00%   0 MLD
321           0           3          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
322           0           2          0  0.00%  0.00%  0.00%   0 Skinny MOH Event
323      284000        1400        202  0.00%  0.00%  0.00%   0 Skinny Socket Se
324  1053820000       18795      56069  0.00%  0.00%  0.00%   0 Web Write Housek
325     3592000     4913010          0  0.00%  0.00%  0.00%   0 NTP
326    20524000      878732         23  0.00%  0.00%  0.00%   0 ISDN L2 Process
327      640000       34384         18  0.00%  0.00%  0.00%   0 ISDN L3 Timer Pr
328     8164000      488630         16  0.00%  0.00%  0.00%   0 ISDN L2D SRQ Pro
------------------ show process cpu history ------------------
UC_560   04:15:35 PM Tuesday Dec 7 2010 PST
    22                                   22222
    00                         11111222229999966666          111
100
90
80
70
60
50
40
30                                      *****
20 **                                   *****
10 **                                   **********
   0....5....1....1....2....2....3....3....4....4....5....5....6
             0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
    2 1222112 1 1 11 11 2  212311111 11141 1 21  1 11 1 1  11
    925553094234439459936266534344968065813741456445025429434323
100
90
80
70
60
50                                     *
40                                     *
30 *  **               *  *  *         *
20 * **** **     *  ** *  ****   **  ***  * *     *  *
10 * ***#*## * * ***** * *####***##****#* * ***** ** * ** **
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    2542434441    11 1111132345253543  1    1111 1141121112111111   1    131
    708381670089960280075947490956739894978753105007850465020000088707888748
100
90
80
70
60                             * *
50  ** * **                 ** * *                *
40  ** * ***                ** *****              *
30 *** *****             ***********              *                      *
20 *********          **************       *      **** ***              ***
10 ************************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show diag ------------------
Slot 0:
UC500 Mainboard 1GE, 3 GE Switching, MOH, Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
Hardware Crypto Engine Details:
   The CHIP id is 0x0
   The SEC revision no is 0x1
EEPROM contents at hardware discovery:
Chassis MAC Address      : 68ef.bd40.c000
PCB Serial Number        : FOC14262RJH
Hardware Revision        : 1.0
Processor type           : CA
Part Number              : 73-12315-02
Board Revision           : C0
Deviation Number         : 110857
Fab Version              : 02
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
MAC Address block size   : 32
Chassis Serial Number    : FHK1427F48H
Product (FRU) Number     : UC560-T1E1-K9
Version Identifier       : V02
Top Assy. Part Number    : 800-32441-02
EEPROM format version 4
EEPROM contents (hex):
   0x00: 04 FF C3 06 68 EF BD 40 C0 00 C1 8B 46 4F 43 31
   0x10: 34 32 36 32 52 4A 48 40 06 6D 41 01 00 09 CA 82
   0x20: 49 30 1B 02 42 43 30 88 00 01 B1 09 02 02 03 00
   0x30: 81 00 00 00 00 04 00 43 00 20 C2 8B 46 48 4B 31
   0x40: 34 32 37 46 34 38 48 CB 92 55 43 35 36 30 2D 54
   0x50: 31 45 31 2D 4B 39 20 20 20 20 20 89 56 30 32 00
   0x60: D9 04 40 C1 C2 CB C0 46 03 20 00 7E B9 02 FF FF
   0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FXO Voice IO Card:
PCB Serial Number        : FOC14184FN3
Part Number              : 73-12323-02
Board Revision           : B0
Deviation Number         : 0
Fab Version              : 02
RMA History              : 00
Top Assy. Part Number    : 800-33042-02
Product (FRU) Number     : VOICE IO CARD
   0x00: 04 FF C1 8B 46 4F 43 31 34 31 38 34 46 4E 33 40
   0x10: 06 6F 41 01 00 82 49 30 23 02 42 42 30 88 00 00
   0x20: 00 00 02 02 03 00 81 00 00 00 00 04 00 C0 46 03
   0x30: 20 00 81 12 02 CB 8D 56 4F 49 43 45 20 49 4F 20
   0x40: 43 41 52 44 FF FF FF FF FF FF FF FF FF FF FF FF
   0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision        : 4.0
Part Number              : 73-8541-05
Board Revision           : C0
Fab Version              : 04
PCB Serial Number        : FOC14242GSP
RMA History              : 00
Processor type           : 00
Product (FRU) Number     : PVDM2-64
Version Identifier       : V01
   0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 43 30
   0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 34 32 34
   0x20: 32 47 53 50 03 00 81 00 00 00 00 04 00 09 00 CB
   0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
   0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision           : C0
Fab Version              : 04
PCB Serial Number        : FOC14242GQV
RMA History              : 00
Processor type           : 00
   0x20: 32 47 51 56 03 00 81 00 00 00 00 04 00 09 00 CB
VIC Slot 0:
3rd generation - FXS DID Voice daughter card (4 port)
Longitudinal Calibration : 01 10 10 8B 68 10 10 96
                            9A 10 10 7B 6F 10 10 71
                            8D
Product (FRU) Number     : VIC3-4FXS/DID
PCB Serial Number        :
   0x00: 04 FF 40 05 1B D3 11 01 10 10 8B 68 10 10 96 9A
   0x10: 10 10 7B 6F 10 10 71 8D CB 8D 56 49 43 33 2D 34
   0x20: 46 58 53 2F 44 49 44 89 56 30 31 20 C1 8B 20 20
   0x30: 20 20 20 20 20 20 20 20 20 FF FF FF FF FF FF FF
   0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
VIC Slot 1:
2nd generation - FXO Voice daughter card (4 port)
Product (FRU) Number     : VIC2-4FXO
Version Identifier       : V03
PCB Serial Number        :
   0x00: 04 FF 40 00 4C CB 89 56 49 43 32 2D 34 46 58 4F
   0x10: 89 56 30 33 20 C1 8B 20 20 20 20 20 20 20 20 20
   0x20: 20 20 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
HWIC Slot 2:
FXS Voice daughter card (4 port)
Hardware Revision        : 3.1
Part Number              : 73-6918-02
Board Revision           : E0
Fab Version              : 02
PCB Serial Number        : FOC103746HS
RMA History              : 00
Top Assy. Part Number    : 800-17016-02
Connector Type           : 01
Product (FRU) Number     : VIC-4FXS/DID=
   0x00: 04 FF 40 00 3A 41 03 01 82 49 1B 06 02 42 45 30
   0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 30 33 37
   0x20: 34 36 48 53 03 00 81 00 00 00 00 04 00 C0 46 03
   0x30: 20 00 42 78 02 05 01 FF FF FF FF FF FF FF FF FF
HWIC Slot 3:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision        : 0.0
Top Assy. Part Number    : 800-22628-05
Board Revision           : C0
Fab Version              : 04
PCB Serial Number        : FOC14244B4S
RMA History              : 00
Product (FRU) Number     : VWIC2-1MFT-T1/E1
   0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
   0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
   0x20: 34 32 34 34 42 34 53 03 00 81 00 00 00 00 04 00
   0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
   0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
VIC Slot 4:
One port MOH Voice Interface
Built-in 3 ports Gige Ethernet Switch
Hardware: Marvell 88E6131 Chip   Revision: 6
Onboard Service Engine: 0
------------------ show platform ------------------
CPLD registers:
HW rev               : 0
Motherboard CPLD rev : 19
SW load reg          : 0x2
Reset reason         : 0x0
Dev Reset 1          : 0xFD
Dev Reset 2          : 0x4
HW Present           : 0x3E
Hard reset           : 0x0
Soft reset           : 0x0
LED_1                : 0x0
LED_2                : 0x0
Misc Cntl1           : 0xB0
Misc Cntl2           : 0x0
TDM PLL cntl         : 0x51
TDM PLL status       : 0x90
Temp Relay reg       : 0x1E
Temp Switch1 reg     : 0x1B
Temp Switch2 reg     : 0x23
Temp Switch3 reg     : 0x29
PWM Slow reg         : 0x7
PWM Medium Slow reg  : 0x9
PWM Medium Fast reg  : 0xC
PWM Fast reg         : 0xF
Fan Tach reg         : 0x26
FRIO rev             : 8
FRIO status          : 0x3
FRIO wic_enable      : 0x0
FRIO CPLD rev        : 9
UART registers:
RxBuf                : 0x0
IER                  : 0xD
IIR                  : 0xC1
LCR                  : 0x7
MCR                  : 0x3
LSR                  : 0x60
MSR                  : 0x0
SR                   : 0x0
UART2 registers:
RxBuf                : 0x0
IER                  : 0x5
IIR                  : 0xC1
LCR                  : 0x7
MCR                  : 0x3
LSR                  : 0x60
MSR                  : 0x10
SR                   : 0x0
MPC8300 Register Dump: Registers start address 0xF0000000
SPR - Special Purpose registers:
msr                  :              0x00009032
svr                  : [SPR - 0286] 0x80C40021
pvr                  : [SPR - 0287] 0x80861011
hid0                 : [SPR - 1008] 0xC000C000
hid1                 : [SPR - 1009] 0x0A000000
hid2                 : [SPR - 1011] 0x00040000
ctr                  : [SPR - 0009] 0x81A1738C
dec                  : [SPR - 0022] 0x7CF91DE8
tbl                  : [SPR - 0268] 0x8306B466
tbu                  : [SPR - 0269] 0x000134F4
mbar                 : [SPR - 0311] 0x00000000
ibat0u               : [SPR - 0528] 0xFF8000FF
ibat0l               : [SPR - 0529] 0xFF800001
ibat1u               : [SPR - 0530] 0x80001FFF
ibat1l               : [SPR - 0531] 0x00000001
ibat2u               : [SPR - 0532] 0x90001FFF
ibat2l               : [SPR - 0533] 0x10000001
ibat3u               : [SPR - 0534] 0x00000000
ibat3l               : [SPR - 0535] 0x00000000
ibat4u               : [SPR - 0560] 0x00000000
ibat4l               : [SPR - 0561] 0x00000000
ibat5u               : [SPR - 0562] 0x00000000
ibat5l               : [SPR - 0563] 0x00000000
ibat6u               : [SPR - 0564] 0x00000000
ibat6l               : [SPR - 0565] 0x00000000
ibat7u               : [SPR - 0566] 0x00000000
ibat7l               : [SPR - 0567] 0x00000000
dbat0u               : [SPR - 0536] 0x80001FFF
dbat0l               : [SPR - 0537] 0x0000000A
dbat1u               : [SPR - 0538] 0x90001FFF
dbat1l               : [SPR - 0539] 0x1000000A
dbat2u               : [SPR - 0540] 0x00000000
dbat2l               : [SPR - 0541] 0x00000000
dbat3u               : [SPR - 0542] 0x00000000
dbat3l               : [SPR - 0543] 0x00000000
dbat4u               : [SPR - 0568] 0x10001FFF
dbat4l               : [SPR - 0569] 0x1000000A
dbat5u               : [SPR - 0570] 0x00000000
dbat5l               : [SPR - 0571] 0x00000000
dbat6u               : [SPR - 0572] 0x70001FFF
dbat6l               : [SPR - 0573] 0x7000002A
dbat7u               : [SPR - 0574] 0xF0001FFF
dbat7l               : [SPR - 0575] 0xF000002A
SYS_CONF  - System Configuration registers:
immrbar              : [0xF0000000] 0xF0000000
lblawbar0            : [0xF0000020] 0xF0000000
lblawar0             : [0xF0000024] 0x8000001B
lblawbar1            : [0xF0000028] 0x00000000
lblawar1             : [0xF000002C] 0x00000000
lblawbar2            : [0xF0000030] 0x00000000
lblawar2             : [0xF0000034] 0x00000000
lblawbar3            : [0xF0000038] 0x00000000
lblawar3             : [0xF000003C] 0x00000000
pcilawbar0           : [0xF0000060] 0x70000000
pcilawar0            : [0xF0000064] 0x8000001B
pcilawbar1           : [0xF0000068] 0x00000000
pcilawar1            : [0xF000006C] 0x00000000
ddrlawbar0           : [0xF00000A0] 0x00000000
ddrlawar0            : [0xF00000A4] 0x8000001C
spridr               : [0xF0000108] 0x80C40021
PIT  - Periodic Interval Timer (PIT) registers:
ptcnr                : [0xF0000400] 0x00000081
ptldr                : [0xF0000404] 0x00112A88
ptpsr                : [0xF0000408] 0x00000000
ptctr                : [0xF000040C] 0x0010507F
ptevr                : [0xF0000410] 0x00000000
IPIC  - Integrated Programable Interrupt Controllerregisters:
sicfr                : [0xF0000700] 0x41000000
sivcr                : [0xF0000704] 0x00000000
sipnr_h              : [0xF0000708] 0x00000000
sipnr_l              : [0xF000070C] 0x00000000
simsr_h              : [0xF0000720] 0xFC0000E0
simsr_l              : [0xF0000724] 0x60300800
sicnr                : [0xF0000728] 0x00000000
sepnr_l              : [0xF000072C] 0x02000000
semsr                : [0xF0000738] 0x2D008000
secnr                : [0xF000073C] 0x00000000
sersr                : [0xF0000740] 0x00000000
sermr                : [0xF0000744] 0xFFFE0000
sercr                : [0xF0000748] 0x00000000
Reset  - Reset Module registers:
rcwlr                : [0xF0000900] 0x2905000C
rcwhr                : [0xF0000904] 0xA460D802
rsr                  : [0xF0000910] 0x00000000
rmr                  : [0xF0000914] 0x00000001
rpr                  : [0xF0000918] 0x00000000
rcr                  : [0xF000091C] 0x00000000
rcer                 : [0xF0000920] 0x00000000
Clock  - Clock Module registers:
spmr                 : [0xF0000A00] 0x2905000C
occr                 : [0xF0000A04] 0x8000FFFC
sccr                 : [0xF0000A08] 0x5FFFFFFF
QE PORTS INT  - QE Ports Interrupts:
cepier               : [0xF0000C0C] 0x00000000
cepimr               : [0xF0000C10] 0x80200000
cepicr               : [0xF0000C14] 0x00200000
gp2ier               : [0xF0000D0C] 0xDF100E40
gp2imr               : [0xF0000D10] 0x20000000
gp2icr               : [0xF0000D14] 0x00000000
QE GPIOS  - General Purpose I/O Ports:
gp1dir               : [0xF0000C00] 0x28000000
gp1odr               : [0xF0000C04] 0x00000000
gp2dir               : [0xF0000D00] 0x5D000200
gp2odr               : [0xF0000D04] 0x00000000
sicrl                : [0xF0000114] 0x00000000
sicrh                : [0xF0000118] 0x1FFC0000
DDRMC - DDR Memory Controller :
cs0_bnds             : [0xF0002000] 0x0000000F
cs1_bnds             : [0xF0002008] 0x0010001F
cs2_bnds             : [0xF0002010] 0x00000000
cs3_bnds             : [0xF0002018] 0x00000000
cs0_config           : [0xF0002080] 0x80010102
cs1_config           : [0xF0002084] 0x80010102
cs2_config           : [0xF0002088] 0x00000000
cs3_config           : [0xF000208C] 0x00000000
timing_cfg_0         : [0xF0002104] 0x00260802
timing_cfg_1         : [0xF0002108] 0x37357322
timing_cfg_2         : [0xF000210C] 0x129048C6
timing_cfg3          : [0xF0002100] 0x00000000
ddr_sdram_cfg        : [0xF0002110] 0xC3000008
ddr_sdram_cfg_2      : [0xF0002114] 0x00401000
ddr_sdram_mode       : [0xF0002118] 0x044A0432
ddr_sdram_mode_2     : [0xF000211C] 0x00000000
ddr_sdram_md_cntl    : [0xF0002120] 0x00000000
ddr_sdram_interval   : [0xF0002124] 0x03D90100
ddr_data_init        : [0xF0002128] 0x00000000
ddr_sdram_clk_cntl   : [0xF0002130] 0x02000000
ddrcdr               : [0xF0000128] 0x80080001
I2C - Inter-IC Bus 1:
i2c[0].i2cadr        : [0xF0003000] 0x0000007E
i2c[0].i2cfdr        : [0xF0003004] 0x00000006
i2c[0].i2ccr         : [0xF0003008] 0x00000000
i2c[0].i2csr         : [0xF000300C] 0x00000081
i2c[0].i2cdr         : [0xF0003010] 0x00000000
i2c[0].i2cdfsrr      : [0xF0003014] 0x00000010
I2C - Inter-IC Bus 2:
i2c[1].i2cadr        : [0xF0003100] 0x00000000
i2c[1].i2cfdr        : [0xF0003104] 0x00000030
i2c[1].i2ccr         : [0xF0003108] 0x00000000
i2c[1].i2csr         : [0xF000310C] 0x00000081
i2c[1].i2cdr         : [0xF0003110] 0x00000000
i2c[1].i2cdfsrr      : [0xF0003114] 0x00000010
LBC - Local Bus Controller :
br0                  : [0xF0005000] 0xFF801001
or0                  : [0xF0005004] 0xFF800F41
br1                  : [0xF0005008] 0x00000000
or1                  : [0xF000500C] 0x00000000
br2                  : [0xF0005010] 0x00000000
or2                  : [0xF0005014] 0x00000000
br3                  : [0xF0005018] 0xF2000801
or3                  : [0xF000501C] 0xFFFF8FF7
br4                  : [0xF0005020] 0xF1001081
or4                  : [0xF0005024] 0xFFFF8100
br5                  : [0xF0005028] 0xF3001001
or5                  : [0xF000502C] 0xFFFF8F41
br6                  : [0xF0005030] 0x00000000
or6                  : [0xF0005034] 0x00000000
br7                  : [0xF0005038] 0x00000000
or7                  : [0xF000503C] 0x00000000
mar                  : [0xF0005068] 0x00000000
mamr                 : [0xF0005070] 0x08040000
mbmr                 : [0xF0005074] 0x00000000
mcmr                 : [0xF0005078] 0x00000000
mrtpr                : [0xF0005084] 0x00000000
lsdmr                : [0xF0005094] 0x00000000
lurt                 : [0xF00050A0] 0x00000000
lsrt                 : [0xF00050A4] 0x00000000
lbcr                 : [0xF00050D0] 0x00000000
lcrr                 : [0xF00050D4] 0x80000008
PCI  - PCI Bridge registers:
pot[0].potar         : [0xF0008400] 0x00070000
pot[0].pobar         : [0xF0008408] 0x00070000
pot[0].pocmr         : [0xF0008410] 0x801F8000
pot[1].potar         : [0xF0008418] 0x00078000
pot[1].pobar         : [0xF0008420] 0x00078000
pot[1].pocmr         : [0xF0008428] 0x800F8000
pot[2].potar         : [0xF0008430] 0x00000000
pot[2].pobar         : [0xF0008438] 0x00000000
pot[2].pocmr         : [0xF0008440] 0x00000000
pot[3].potar         : [0xF0008448] 0x00000000
pot[3].pobar         : [0xF0008450] 0x00000000
pot[3].pocmr         : [0xF0008458] 0x00000000
pot[4].potar         : [0xF0008460] 0x00000000
pot[4].pobar         : [0xF0008468] 0x00000000
pot[4].pocmr         : [0xF0008470] 0x00000000
pot[5].potar         : [0xF0008478] 0x00000000
pot[5].pobar         : [0xF0008480] 0x00000000
pot[5].pocmr         : [0xF0008488] 0x00000000
gcr                  : [0xF0008520] 0x00000001
ecr                  : [0xF0008524] 0x00000000
gsr                  : [0xF0008528] 0x00000001
pitar0               : [0xF0008568] 0x00000000
pibar0               : [0xF0008570] 0x00000000
piwar0               : [0xF0008578] 0xE005501D
pitar1               : [0xF0008550] 0x00000000
pibar1               : [0xF0008558] 0x000C0000
piwar1               : [0xF0008560] 0xA005501D
pitar2               : [0xF0008538] 0x00000000
pibar2               : [0xF0008540] 0x00000000
piwar2               : [0xF0008548] 0x00000000
Interrupt Throttling Statistics:
________________________________
Throttle Count   = 00000000   Timer Count      = 00000000
Netint usec      = 00100000   Netint Mask usec = 00001000
Active           =        0   Configured       =        1
Longest IRQ usec = 00001474
Interrupt Statistics:
Vector Count  Handler PC Name
9 0x00059EE5 0x800501C4 16552 Con/Aux Interrupt
10 0x00092BE3 0x8040CB08 16552 CUE line Interrupt
11 0x00000000 0x83780798 SEC Interrupt Handler
18 0x00000000 0x8053CD4C Freddo HWIC mgmt interrupts
20 0x00000000 0x8053CDD4 Freddo HWIC error interrupts
21 0x00000009 0x800A4528 ESW interrupt
23 0x08B6462F 0x8053CE5C FIO WIC/HWIC net interrupts
32 0x00075E11 0x80067770 pqii_pro tsec1 tx interrupt
33 0x00000000 0x8006761C pqii_pro tsec1 rx interrupt
34 0x00000000 0x8006761C pqii_pro tsec1 error interrupt
35 0x07B1EDBD 0x80067770 pqii_pro tsec2 tx interrupt
36 0x067FA58E 0x8006761C pqii_pro tsec2 rx interrupt
37 0x00000000 0x8006761C pqii_pro tsec2 error interrupt
65 0x47FD91B2 0x800262D0 M8300_TIMER_INTERRUPT
66 0x00000000 0x8003072C Host/PCI Bridge Interrupt
74 0x00000000 0x80027B90 M8300 GPIO1 ports
75 0x00000000 0x80027C24 M8300 GPIO2 ports
84 0x00000000 0x80026BD0 Timebase Reference Interrupt
MoH Register values:
POWER                : 0x0000009F
MODE                 : 0x00000012
TRANSMIT PGA         : 0x00000040
RECEIVE PGA          : 0x000000A0
HIGH DTMF            : 0x00000000
LOW DTMF             : 0x00000000
AUX Register         : 0x00000000
------------------ show pci hardware ------------------
------------------ show pci controller ------------------
------------------ show service-module ------------------
------------------ service-module Integrated-Service-Engine0/0 status ------------------
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 7.1.3
CUE is on UC500UC500
------------------ show controllers t1 ------------------
T1 0/3/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (24 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show crypto engine configuration ------------------
        crypto engine name:  Virtual Private Network (VPN) Module
        crypto engine type:  hardware
                     State:  Enabled
              Product Name:  Onboard-VPN
                FW Version:  1
              Time running:  4294967 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                   AES CBC:  Yes (128,192,256)
                  AES CNTR:  No
     Maximum buffer length:  4096
          Maximum DH index:  0030
          Maximum SA index:  0030
        Maximum Flow index:  0060
      Maximum RSA key size:  0000
        crypto lib version:  20.0.0
------------------ show crypto engine accelerator statistic ------------------
Device:   Onboard VPN
:Statistics for encryption device since the last clear
  of counters 4294967 seconds ago
               0 packets in                           0 packets out
               0 bytes in                             0 bytes out
               0 paks/sec in                          0 paks/sec out
               0 Kbits/sec in                         0 Kbits/sec out
               0 packets decrypted                    0 packets encrypted
               0 bytes before decrypt                 0 bytes encrypted
               0 bytes decrypted                      0 bytes after encrypt
               0 packets decompressed                 0 packets compressed
               0 bytes before decomp                  0 bytes before comp
               0 bytes after decomp                   0 bytes after comp
               0 packets bypass decompr               0 packets bypass compres
               0 bytes bypass decompres               0 bytes bypass compressi
               0 packets not decompress               0 packets not compressed
               0 bytes not decompressed               0 bytes not compressed
                  1.0:1 compression ratio                1.0:1 overall
  Last 5 minutes:
               0 bits/sec in                          0 bits/sec out
               0 bytes decrypted                      0 bytes encrypted
               0 Kbits/sec decrypted                  0 Kbits/sec encrypted
Errors:
Total Number of Packet Drops = 0
Pad Error                    = 0
Data Error                   = 0
Packet Error                 = 0
Null IP Error                = 0
Hardware Error               = 0
CP Unavailable               = 0
HP Unavailable               = 0
AH Seq Failure               = 0
Link Down Error              = 0
ESP Seq Failure              = 0
AH Auth Failure              = 0
ESP Auth Failure             = 0
Queue Full Error             = 0
API Request Error            = 0
Invalid Flow Error           = 0
Buffer Unavailable           = 0
QOS Queue Full Error         = 0
Packet too Big Error         = 0
AH Replay Check Failure      = 0
Too Many Particles Error     = 0
ESP Replay Check Failure     = 0
Input Queue Full Error       = 0
Output Queue Full Error      = 0
Pre-batch Queue Full Error   = 0
Post-batch Queue Full Error  = 0
BATCHING Statistics:
Batching Allowed
Batching currently Inactive
No of times batching turned on        = 0
No of times batching turned off       = 0
No of Flush Done                      = 0
Flush Timer in Milli Seconds          = 8
Disable Timer in Seconds              = 20
Threshold Crypto Paks/Sec
  to enable batching                  = 4000
PRE-BATCHING Enabled
Pre-batch count, max_count            = 0, 16
Packets queued to pre-batch queue     = 0
Packets flushed from pre-batch queue  = 0
The Pre-batch Queue Information
The Queuesize is                      = 256
The no entries currently being used   = 0
The Read Index is                     = 0
The Write Index is                    = 0
The entries in use are between Read and Write Index
POST-BATCHING Enabled
Post-batch count, max_count           = 0, 16
Packets queued to post-batch queue    = 0
Packets flushed from post-batch queue = 0
The Post-batch Queue Information
SEC MFIFO Statistics:
Channel 0 allocated times             = 0
Channel 1 allocated times             = 0
Channel 2 allocated times             = 0
Channel 3 allocated times             = 0
Channel 0 freed times                 = 0
Channel 1 freed times                 = 0
Channel 2 freed times                 = 0
Channel 3 freed times                 = 0
Sec MFIFO flush count                 = 0
Sec MFIFO interrupt count             = 0
Sec MFIFO put back count              = 0
Sec MFIFO Timer flush count           = 0
Sec MFIFO Timer put back count        = 0
Sec alloc workq count                 = 0
Sec free workq count                  = 64
------------------ show crypto engine accel ring packet ------------------
Device:   Onboard VPN
------------------ show crypto engine accel ring pool ------------------
Device:   Onboard VPN
Location: Onboard: 0The Crypto Packet Queue Information
The Queuesize is                      = 512
The no entries currently being used   = 512
The entries are
Entry 1  -  0x1F79C960
Entry 2  -  0x1F79CA50
Entry 3  -  0x1F79CB40
Entry 4  -  0x1F79CC30
Entry 5  -  0x1F79CD20
Entry 6  -  0x1F79CE10
Entry 7  -  0x1F79CF00
Entry 8  -  0x1F79CFF0
Entry 9  -  0x1F79D0E0
Entry 10  -  0x1F79D1D0
Entry 11  -  0x1F79D2C0
Entry 12  -  0x1F79D3B0
Entry 13  -  0x1F79D4A0
Entry 14  -  0x1F79D590
Entry 15  -  0x1F79D680
Entry 16  -  0x1F79D770
Entry 17  -  0x1F79D860
Entry 18  -  0x1F79D950
Entry 19  -  0x1F79DA40
Entry 20  -  0x1F79DB30
Entry 21  -  0x1F79DC20
Entry 22  -  0x1F79DD10
Entry 23  -  0x1F79DE00
Entry 24  -  0x1F79DEF0
Entry 25  -  0x1F79DFE0
Entry 26  -  0x1F79E0D0
Entry 27  -  0x1F79E1C0
Entry 28  -  0x1F79E2B0
Entry 29  -  0x1F79E3A0
Entry 30  -  0x1F79E490
Entry 31  -  0x1F79E580
Entry 32  -  0x1F79E670
Entry 33  -  0x1F79E760
Entry 34  -  0x1F79E850
Entry 35  -  0x1F79E940
Entry 36  -  0x1F79EA30
Entry 37  -  0x1F79EB20
Entry 38  -  0x1F79EC10
Entry 39  -  0x1F79ED00
Entry 40  -  0x1F79EDF0
Entry 41  -  0x1F79EEE0
Entry 42  -  0x1F79EFD0
Entry 43  -  0x1F79F0C0
Entry 44  -  0x1F79F1B0
Entry 45  -  0x1F79F2A0
Entry 46  -  0x1F79F390
Entry 47  -  0x1F79F480
Entry 48  -  0x1F79F570
Entry 49  -  0x1F79F660
Entry 50  -  0x1F79F750
Entry 51  -  0x1F79F840
Entry 52  -  0x1F79F930
Entry 53  -  0x1F79FA20
Entry 54  -  0x1F79FB10
Entry 55  -  0x1F79FC00
Entry 56  -  0x1F79FCF0
Entry 57  -  0x1F79FDE0
Entry 58  -  0x1F79FED0
Entry 59  -  0x1F79FFC0
Entry 60  -  0x1F7A00B0
Entry 61  -  0x1F7A01A0
Entry 62  -  0x1F7A0290
Entry 63  -  0x1F7A0380
Entry 64  -  0x1F7A0470
Entry 65  -  0x1F7A0560
Entry 66  -  0x1F7A0650
Entry 67  -  0x1F7A0740
Entry 68  -  0x1F7A0830
Entry 69  -  0x1F7A0920
Entry 70  -  0x1F7A0A10
Entry 71  -  0x1F7A0B00
Entry 72  -  0x1F7A0BF0
Entry 73  -  0x1F7A0CE0
Entry 74  -  0x1F7A0DD0
Entry 75  -  0x1F7A0EC0
Entry 76  -  0x1F7A0FB0
Entry 77  -  0x1F7A10A0
Entry 78  -  0x1F7A1190
Entry 79  -  0x1F7A1280
Entry 80  -  0x1F7A1370
Entry 81  -  0x1F7A1460
Entry 82  -  0x1F7A1550
Entry 83  -  0x1F7A1640
Entry 84  -  0x1F7A1730
Entry 85  -  0x1F7A1820
Entry 86  -  0x1F7A1910
Entry 87  -  0x1F7A1A00
Entry 88  -  0x1F7A1AF0
Entry 89  -  0x1F7A1BE0
Entry 90  -  0x1F7A1CD0
Entry 91  -  0x1F7A1DC0
Entry 92  -  0x1F7A1EB0
Entry 93  -  0x1F7A1FA0
Entry 94  -  0x1F7A2090
Entry 95  -  0x1F7A2180
Entry 96  -  0x1F7A2270
Entry 97  -  0x1F7A2360
Entry 98  -  0x1F7A2450
Entry 99  -  0x1F7A2540
Entry 100  -  0x1F7A2630
Entry 101  -  0x1F7A2720
Entry 102  -  0x1F7A2810
Entry 103  -  0x1F7A2900
Entry 104  -  0x1F7A29F0
Entry 105  -  0x1F7A2AE0
Entry 106  -  0x1F7A2BD0
Entry 107  -  0x1F7A2CC0
Entry 108  -  0x1F7A2DB0
Entry 109  -  0x1F7A2EA0
Entry 110  -  0x1F7A2F90
Entry 111  -  0x1F7A3080
Entry 112  -  0x1F7A3170
Entry 113  -  0x1F7A3260
Entry 114  -  0x1F7A3350
Entry 115  -  0x1F7A3440
Entry 116  -  0x1F7A3530
Entry 117  -  0x1F7A3620
Entry 118  -  0x1F7A3710
Entry 119  -  0x1F7A3800
Entry 120  -  0x1F7A38F0
Entry 121  -  0x1F7A39E0
Entry 122  -  0x1F7A3AD0
Entry 123  -  0x1F7A3BC0
Entry 124  -  0x1F7A3CB0
Entry 125  -  0x1F7A3DA0
Entry 126  -  0x1F7A3E90
Entry 127  -  0x1F7A3F80
Entry 128  -  0x1F7A4070
Entry 129  -  0x1F7A4160
Entry 130  -  0x1F7A4250
Entry 131  -  0x1F7A4340
Entry 132  -  0x1F7A4430
Entry 133  -  0x1F7A4520
Entry 134  -  0x1F7A4610
Entry 135  -  0x1F7A4700
Entry 136  -  0x1F7A47F0
Entry 137  -  0x1F7A48E0
Entry 138  -  0x1F7A49D0
Entry 139  -  0x1F7A4AC0
Entry 140  -  0x1F7A4BB0
Entry 141  -  0x1F7A4CA0
Entry 142  -  0x1F7A4D90
Entry 143  -  0x1F7A4E80
Entry 144  -  0x1F7A4F70
Entry 145  -  0x1F7A5060
Entry 146  -  0x1F7A5150
Entry 147  -  0x1F7A5240
Entry 148  -  0x1F7A5330
Entry 149  -  0x1F7A5420
Entry 150  -  0x1F7A5510
Entry 151  -  0x1F7A5600
Entry 152  -  0x1F7A56F0
Entry 153  -  0x1F7A57E0
Entry 154  -  0x1F7A58D0
Entry 155  -  0x1F7A59C0
Entry 156  -  0x1F7A5AB0
Entry 157  -  0x1F7A5BA0
Entry 158  -  0x1F7A5C90
Entry 159  -  0x1F7A5D80
Entry 160  -  0x1F7A5E70
Entry 161  -  0x1F7A5F60
Entry 162  -  0x1F7A6050
Entry 163  -  0x1F7A6140
Entry 164  -  0x1F7A6230
Entry 165  -  0x1F7A6320
Entry 166  -  0x1F7A6410
Entry 167  -  0x1F7A6500
Entry 168  -  0x1F7A65F0
Entry 169  -  0x1F7A66E0
Entry 170  -  0x1F7A67D0
Entry 171  -  0x1F7A68C0
Entry 172  -  0x1F7A69B0
Entry 173  -  0x1F7A6AA0
Entry 174  -  0x1F7A6B90
Entry 175  -  0x1F7A6C80
Entry 176  -  0x1F7A6D70
Entry 177  -  0x1F7A6E60
Entry 178  -  0x1F7A6F50
Entry 179  -  0x1F7A7040
Entry 180  -  0x1F7A7130
Entry 181  -  0x1F7A7220
Entry 182  -  0x1F7A7310
Entry 183  -  0x1F7A7400
Entry 184  -  0x1F7A74F0
Entry 185  -  0x1F7A75E0
Entry 186  -  0x1F7A76D0
Entry 187  -  0x1F7A77C0
Entry 188  -  0x1F7A78B0
Entry 189  -  0x1F7A79A0
Entry 190  -  0x1F7A7A90
Entry 191  -  0x1F7A7B80
Entry 192  -  0x1F7A7C70
Entry 193  -  0x1F7A7D60
Entry 194  -  0x1F7A7E50
Entry 195  -  0x1F7A7F40
Entry 196  -  0x1F7A8030
Entry 197  -  0x1F7A8120
Entry 198  -  0x1F7A8210
Entry 199  -  0x1F7A8300
Entry 200  -  0x1F7A83F0
Entry 201  -  0x1F7A84E0
Entry 202  -  0x1F7A85D0
Entry 203  -  0x1F7A86C0
Entry 204  -  0x1F7A87B0
Entry 205  -  0x1F7A88A0
Entry 206  -  0x1F7A8990
Entry 207  -  0x1F7A8A80
Entry 208  -  0x1F7A8B70
Entry 209  -  0x1F7A8C60
Entry 210  -  0x1F7A8D50
Entry 211  -  0x1F7A8E40
Entry 212  -  0x1F7A8F30
Entry 213  -  0x1F7A9020
Entry 214  -  0x1F7A9110
Entry 215  -  0x1F7A9200
Entry 216  -  0x1F7A92F0
Entry 217  -  0x1F7A93E0
Entry 218  -  0x1F7A94D0
Entry 219  -  0x1F7A95C0
Entry 220  -  0x1F7A96B0
Entry 221  -  0x1F7A97A0
Entry 222  -  0x1F7A9890
Entry 223  -  0x1F7A9980
Entry 224  -  0x1F7A9A70
Entry 225  -  0x1F7A9B60
Entry 226  -  0x1F7A9C50
Entry 227  -  0x1F7A9D40
Entry 228  -  0x1F7A9E30
Entry 229  -  0x1F7A9F20
Entry 230  -  0x1F7AA010
Entry 231  -  0x1F7AA100
Entry 232  -  0x1F7AA1F0
Entry 233  -  0x1F7AA2E0
Entry 234  -  0x1F7AA3D0
Entry 235  -  0x1F7AA4C0
Entry 236  -  0x1F7AA5B0
Entry 237  -  0x1F7AA6A0
Entry 238  -  0x1F7AA790
Entry 239  -  0x1F7AA880
Entry 240  -  0x1F7AA970
Entry 241  -  0x1F7AAA60
Entry 242  -  0x1F7AAB50
Entry 243  -  0x1F7AAC40
Entry 244  -  0x1F7AAD30
Entry 245  -  0x1F7AAE20
Entry 246  -  0x1F7AAF10
Entry 247  -  0x1F7AB000
Entry 248  -  0x1F7AB0F0
Entry 249  -  0x1F7AB1E0
Entry 250  -  0x1F7AB2D0
Entry 251  -  0x1F7AB3C0
Entry 252  -  0x1F7AB4B0
Entry 253  -  0x1F7AB5A0
Entry 254  -  0x1F7AB690
Entry 255  -  0x1F7AB780
Entry 256  -  0x1F7AB870
Entry 257  -  0x1F7AB960
Entry 258  -  0x1F7ABA50
Entry 259  -  0x1F7ABB40
Entry 260  -  0x1F7ABC30
Entry 261  -  0x1F7ABD20
Entry 262  -  0x1F7ABE10
Entry 263  -  0x1F7ABF00
Entry 264  -  0x1F7ABFF0
Entry 265  -  0x1F7AC0E0
Entry 266  -  0x1F7AC1D0
Entry 267  -  0x1F7AC2C0
Entry 268  -  0x1F7AC3B0
Entry 269  -  0x1F7AC4A0
Entry 270  -  0x1F7AC590
Entry 271  -  0x1F7AC680
Entry 272  -  0x1F7AC770
Entry 273  -  0x1F7AC860
Entry 274  -  0x1F7AC950
Entry 275  -  0x1F7ACA40
Entry 276  -  0x1F7ACB30
Entry 277  -  0x1F7ACC20
Entry 278  -  0x1F7ACD10
Entry 279  -  0x1F7ACE00
Entry 280  -  0x1F7ACEF0
Entry 281  -  0x1F7ACFE0
Entry 282  -  0x1F7AD0D0
Entry 283  -  0x1F7AD1C0
Entry 284  -  0x1F7AD2B0
Entry 285  -  0x1F7AD3A0
Entry 286  -  0x1F7AD490
Entry 287  -  0x1F7AD580
Entry 288  -  0x1F7AD670
Entry 289  -  0x1F7AD760
Entry 290  -  0x1F7AD850
Entry 291  -  0x1F7AD940
Entry 292  -  0x1F7ADA30
Entry 293  -  0x1F7ADB20
Entry 294  -  0x1F7ADC10
Entry 295  -  0x1F7ADD00
Entry 296  -  0x1F7ADDF0
Entry 297  -  0x1F7ADEE0
Entry 298  -  0x1F7ADFD0
Entry 299  -  0x1F7AE0C0
Entry 300  -  0x1F7AE1B0
Entry 301  -  0x1F7AE2A0
Entry 302  -  0x1F7AE390
Entry 303  -  0x1F7AE480
Entry 304  -  0x1F7AE570
Entry 305  -  0x1F7AE660
Entry 306  -  0x1F7AE750
Entry 307  -  0x1F7AE840
Entry 308  -  0x1F7AE930
Entry 309  -  0x1F7AEA20
Entry 310  -  0x1F7AEB10
Entry 311  -  0x1F7AEC00
Entry 312  -  0x1F7AECF0
Entry 313  -  0x1F7AEDE0
Entry 314  -  0x1F7AEED0
Entry 315  -  0x1F7AEFC0
Entry 316  -  0x1F7AF0B0
Entry 317  -  0x1F7AF1A0
Entry 318  -  0x1F7AF290
Entry 319  -  0x1F7AF380
Entry 320  -  0x1F7AF470
Entry 321  -  0x1F7AF560
Entry 322  -  0x1F7AF650
Entry 323  -  0x1F7AF740
Entry 324  -  0x1F7AF830
Entry 325  -  0x1F7AF920
Entry 326  -  0x1F7AFA10
Entry 327  -  0x1F7AFB00
Entry 328  -  0x1F7AFBF0
Entry 329  -  0x1F7AFCE0
Entry 330  -  0x1F7AFDD0
Entry 331  -  0x1F7AFEC0
Entry 332  -  0x1F7AFFB0
Entry 333  -  0x1F7B00A0
Entry 334  -  0x1F7B0190
Entry 335  -  0x1F7B0280
Entry 336  -  0x1F7B0370
Entry 337  -  0x1F7B0460
Entry 338  -  0x1F7B0550
Entry 339  -  0x1F7B0640
Entry 340  -  0x1F7B0730
Entry 341  -  0x1F7B0820
Entry 342  -  0x1F7B0910
Entry 343  -  0x1F7B0A00
Entry 344  -  0x1F7B0AF0
Entry 345  -  0x1F7B0BE0
Entry 346  -  0x1F7B0CD0
Entry 347  -  0x1F7B0DC0
Entry 348  -  0x1F7B0EB0
Entry 349  -  0x1F7B0FA0
Entry 350  -  0x1F7B1090
Entry 351  -  0x1F7B1180
Entry 352  -  0x1F7B1270
Entry 353  -  0x1F7B1360
Entry 354  -  0x1F7B1450
Entry 355  -  0x1F7B1540
Entry 356  -  0x1F7B1630
Entry 357  -  0x1F7B1720
Entry 358  -  0x1F7B1810
Entry 359  -  0x1F7B1900
Entry 360  -  0x1F7B19F0
Entry 361  -  0x1F7B1AE0
Entry 362  -  0x1F7B1BD0
Entry 363  -  0x1F7B1CC0
Entry 364  -  0x1F7B1DB0
Entry 365  -  0x1F7B1EA0
Entry 366  -  0x1F7B1F90
Entry 367  -  0x1F7B2080
Entry 368  -  0x1F7B2170
Entry 369  -  0x1F7B2260
Entry 370  -  0x1F7B2350
Entry 371  -  0x1F7B2440
Entry 372  -  0x1F7B2530
Entry 373  -  0x1F7B2620
Entry 374  -  0x1F7B2710
Entry 375  -  0x1F7B2800
Entry 376  -  0x1F7B28F0
Entry 377  -  0x1F7B29E0
Entry 378  -  0x1F7B2AD0
Entry 379  -  0x1F7B2BC0
Entry 380  -  0x1F7B2CB0
Entry 381  -  0x1F7B2DA0
Entry 382  -  0x1F7B2E90
Entry 383  -  0x1F7B2F80
Entry 384  -  0x1F7B3070
Entry 385  -  0x1F7B3160
Entry 386  -  0x1F7B3250
Entry 387  -  0x1F7B3340
Entry 388  -  0x1F7B3430
Entry 389  -  0x1F7B3520
Entry 390  -  0x1F7B3610
Entry 391  -  0x1F7B3700
Entry 392  -  0x1F7B37F0
Entry 393  -  0x1F7B38E0
Entry 394  -  0x1F7B39D0
Entry 395  -  0x1F7B3AC0
Entry 396  -  0x1F7B3BB0
Entry 397  -  0x1F7B3CA0
Entry 398  -  0x1F7B3D90
Entry 399  -  0x1F7B3E80
Entry 400  -  0x1F7B3F70
Entry 401  -  0x1F7B4060
Entry 402  -  0x1F7B4150
Entry 403  -  0x1F7B4240
Entry 404  -  0x1F7B4330
Entry 405  -  0x1F7B4420
Entry 406  -  0x1F7B4510
Entry 407  -  0x1F7B4600
Entry 408  -  0x1F7B46F0
Entry 409  -  0x1F7B47E0
Entry 410  -  0x1F7B48D0
Entry 411  -  0x1F7B49C0
Entry 412  -  0x1F7B4AB0
Entry 413  -  0x1F7B4BA0
Entry 414  -  0x1F7B4C90
Entry 415  -  0x1F7B4D80
Entry 416  -  0x1F7B4E70
Entry 417  -  0x1F7B4F60
Entry 418  -  0x1F7B5050
Entry 419  -  0x1F7B5140
Entry 420  -  0x1F7B5230
Entry 421  -  0x1F7B5320
Entry 422  -  0x1F7B5410
Entry 423  -  0x1F7B5500
Entry 424  -  0x1F7B55F0
Entry 425  -  0x1F7B56E0
Entry 426  -  0x1F7B57D0
Entry 427  -  0x1F7B58C0
Entry 428  -  0x1F7B59B0
Entry 429  -  0x1F7B5AA0
Entry 430  -  0x1F7B5B90
Entry 431  -  0x1F7B5C80
Entry 432  -  0x1F7B5D70
Entry 433  -  0x1F7B5E60
Entry 434  -  0x1F7B5F50
Entry 435  -  0x1F7B6040
Entry 436  -  0x1F7B6130
Entry 437  -  0x1F7B6220
Entry 438  -  0x1F7B6310
Entry 439  -  0x1F7B6400
Entry 440  -  0x1F7B64F0
Entry 441  -  0x1F7B65E0
Entry 442  -  0x1F7B66D0
Entry 443  -  0x1F7B67C0
Entry 444  -  0x1F7B68B0
Entry 445  -  0x1F7B69A0
Entry 446  -  0x1F7B6A90
Entry 447  -  0x1F7B6B80
Entry 448  -  0x1F7B6C70
Entry 449  -  0x1F7B6D60
Entry 450  -  0x1F7B6E50
Entry 451  -  0x1F7B6F40
Entry 452  -  0x1F7B7030
Entry 453  -  0x1F7B7120
Entry 454  -  0x1F7B7210
Entry 455  -  0x1F7B7300
Entry 456  -  0x1F7B73F0
Entry 457  -  0x1F7B74E0
Entry 458  -  0x1F7B75D0
Entry 459  -  0x1F7B76C0
Entry 460  -  0x1F7B77B0
Entry 461  -  0x1F7B78A0
Entry 462  -  0x1F7B7990
Entry 463  -  0x1F7B7A80
Entry 464  -  0x1F7B7B70
Entry 465  -  0x1F7B7C60
Entry 466  -  0x1F7B7D50
Entry 467  -  0x1F7B7E40
Entry 468  -  0x1F7B7F30
Entry 469  -  0x1F7B8020
Entry 470  -  0x1F7B8110
Entry 471  -  0x1F7B8200
Entry 472  -  0x1F7B82F0
Entry 473  -  0x1F7B83E0
Entry 474  -  0x1F7B84D0
Entry 475  -  0x1F7B85C0
Entry 476  -  0x1F7B86B0
Entry 477  -  0x1F7B87A0
Entry 478  -  0x1F7B8890
Entry 479  -  0x1F7B8980
Entry 480  -  0x1F7B8A70
Entry 481  -  0x1F7B8B60
Entry 482  -  0x1F7B8C50
Entry 483  -  0x1F7B8D40
Entry 484  -  0x1F7B8E30
Entry 485  -  0x1F7B8F20
Entry 486  -  0x1F7B9010
Entry 487  -  0x1F7B9100
Entry 488  -  0x1F7B91F0
Entry 489  -  0x1F7B92E0
Entry 490  -  0x1F7B93D0
Entry 491  -  0x1F7B94C0
Entry 492  -  0x1F7B95B0
Entry 493  -  0x1F7B96A0
Entry 494  -  0x1F7B9790
Entry 495  -  0x1F7B9880
Entry 496  -  0x1F7B9970
Entry 497  -  0x1F7B9A60
Entry 498  -  0x1F7B9B50
Entry 499  -  0x1F7B9C40
Entry 500  -  0x1F7B9D30
Entry 501  -  0x1F7B9E20
Entry 502  -  0x1F7B9F10
Entry 503  -  0x1F7BA000
Entry 504  -  0x1F7BA0F0
Entry 505  -  0x1F7BA1E0
Entry 506  -  0x1F7BA2D0
Entry 507  -  0x1F7BA3C0
Entry 508  -  0x1F7BA4B0
Entry 509  -  0x1F7BA5A0
Entry 510  -  0x1F7BA690
Entry 511  -  0x1F7BA780
Entry 512  -  0x1F7BA870
------------------ show crypto engine accel ring control ------------------
Device:   Onboard VPN
The Queuesize is                      = 32
------------------ show dot11 associations all-client ------------------
------------------ show ip nbar version ------------------
NBAR software version:  7
1   base                 Mv: 2
2   ftp                  Mv: 3
3   http                 Mv: 10
4   static               Mv: 6
5   tftp                 Mv: 1
6   exchange             Mv: 1
7   vdolive              Mv: 1
8   sqlnet               Mv: 1
9   rcmd                 Mv: 1
10  netshow              Mv: 1
11  sunrpc               Mv: 2
12  streamwork           Mv: 1
13  citrix               Mv: 10
14  fasttrack            Mv: 2
15  gnutella             Mv: 4
16  kazaa2               Mv: 7
17  custom-protocols     Mv: 1
18  rtsp                 Mv: 5
19  rtp                  Mv: 5
20  mgcp                 Mv: 2
21  skinny               Mv: 1
22  h323                 Mv: 1
23  sip                  Mv: 1
24  rtcp                 Mv: 2
25  edonkey              Mv: 5
26  winmx                Mv: 3
27  bittorrent           Mv: 4
28  directconnect        Mv: 3
29  hl7                  Mv: 1
30  fix                  Mv: 1
31  skype                Mv: 3
32  sap                  Mv: 1
{} Mv: , {Nv: ; }
            {Iv:    - }
------------------ show webvpn session context all ------------------
------------------ show webvpn stats detail ------------------
User session statistics:
    Active user sessions     : 0          AAA pending reqs         : 0
    Peak user sessions       : 0          Peak time                : never
    Active user TCP conns    : 0          Terminated user sessions : 0
    Session alloc failures   : 0          Authentication failures  : 0
    VPN session timeout      : 0          VPN idle timeout         : 0
    User cleared VPN sessions: 0          Exceeded ctx user limit  : 0
    Exceeded total user limit: 0
    Client process rcvd pkts : 0          Server process rcvd pkts : 0
    Client process sent pkts : 0          Server process sent pkts : 0
    Client CEF received pkts : 0          Server CEF received pkts : 0
    Client CEF rcv punt pkts : 0          Server CEF rcv punt pkts : 0
    Client CEF sent pkts     : 0          Server CEF sent pkts     : 0
    Client CEF sent punt pkts: 0          Server CEF sent punt pkts: 0
    SSLVPN appl bufs inuse   : 0          SSLVPN eng  bufs inuse   : 0
    Active server TCP conns  : 0
Mangling statistics:
    Relative urls            : 0          Absolute urls            : 0
    Non-http(s) absolute urls: 0          Non-standard path urls   : 0
    Interesting tags         : 0          Uninteresting tags       : 0
    Interesting attributes   : 0          Uninteresting attributes : 0
    Embedded script statement: 0          Embedded style statement : 0
    Inline scripts           : 0          Inline styles            : 0
    HTML comments            : 0          HTTP/1.0 requests        : 0
    HTTP/1.1 requests        : 0          Unknown HTTP version     : 0
    GET requests             : 0          POST requests            : 0
    CONNECT requests         : 0          Other request methods    : 0
    Through requests         : 0          Gateway requests         : 0
    Pipelined requests       : 0          Req with header size >1K : 0
    Processed req hdr bytes  : 0          Processed req body bytes : 0
    HTTP/1.0 responses       : 0          HTTP/1.1 responses       : 0
    HTML responses           : 0          CSS responses            : 0
    XML responses            : 0          JS responses             : 0
    Other content type resp  : 0          Chunked encoding resp    : 0
    Resp with encoded content: 0          Resp with content length : 0
    Close after response     : 0          Resp with header size >1K: 0
    Processed resp hdr size  : 0          Processed resp body bytes: 0
    Backend https response   : 0          Chunked encoding requests: 0
HTTP Authentication stats :
    Successful NTLM Auth     : 0          Failed NTLM Auth         : 0
    Successful Basic Auth    : 0          Failed Basic Auth        : 0
    Unsupported Auth         : 0          Unsup Basic HTTP Method  : 0
    NTLM srv kp alive disabld: 0          NTLM Negotiation Error   : 0
    Oversize NTLM Type3 cred : 0          Internal Error           : 0
    Num 401 responses        : 0          Num non-401 responses    : 0
    Num Basic forms served   : 0          Num NTLM forms served    : 0
    Num Basic Auth sent      : 0          Num NTLM Auth sent       : 0
CIFS statistics:
  SMB related Per Context:
    TCP VC's                 : 0          UDP VC's                 : 0
    Active VC's              : 0          Active Contexts          : 0
    Aborted Conns            : 0
  NetBIOS related Per Context:
    Name Queries             : 0          Name Replies             : 0
    NB DGM Requests          : 0          NB DGM Replies           : 0
    NB TCP Connect Fails     : 0          NB Name Resolution Fails : 0
  SMB related Global:
    Sessions in use          : 0          Mbufs in use             : 0
    Mbuf Chains in use       : 0          Active VC's              : 0
    Active Contexts          : 0          Browse Errors            : 0
    Empty Browser List       : 0          NetServEnum Errors       : 0
    Empty Server List        : 0          NBNS Config Errors       : 0
    NetShareEnum Errors      : 0
  HTTP related Per Context:
    Requests                 : 0          Request Bytes RX         : 0
    Request Packets RX       : 0          Response Bytes TX        : 0
    Response Packets TX      : 0          Active Connections       : 0
    Active CIFS context      : 0          Requests Dropped         : 0
  HTTP related Global:
    Server User data         : 0          CIFS User data           : 0
    Net Handles              : 0          Active CIFS context      : 0
    Authentication Fails     : 0          Operations Aborted       : 0
    Timers Expired           : 0          Pending Close            : 0
    Net Handles Pending SMB  : 0          File Open Fails          : 0
    Browse Network Ops       : 0          Browse Network Fails     : 0
    Browse Domain Ops        : 0          Browse Domain Fails      : 0
    Browse Server Ops        : 0          Browse Server Fails      : 0
    Browse Share Ops         : 0          Browse Share Fails       : 0
    Browse Dir Ops           : 0          Browse Network Fails     : 0
    File Read Ops            : 0          File Read Fails          : 0
    File Write Ops           : 0          File Write Fails         : 0
    Folder Create Ops        : 0          Folder Create Fails      : 0
    File Delete Ops          : 0          File Delete Fails        : 0
    File Rename Ops          : 0          File Rename Fails        : 0
    URL List Access OK       : 0          URL List Access Fails    : 0
Socket statistics:
    Sockets in use           : 1          Sock Usr Blocks in use   : 1
    Sock Data Buffers in use : 0          Sock Buf desc in use     : 0
    Select timers in use     : 1          Sock Select Timeouts     : 0
    Sock Tx Blocked          : 0          Sock Tx Unblocked        : 0
    Sock Rx Blocked          : 0          Sock Rx Unblocked        : 0
    Sock UDP Connects        : 0          Sock UDP Disconnects     : 0
    Sock Premature Close     : 0          Sock Pipe Errors         : 0
    Sock Select Timeout Errs : 0
Port Forward statistics:
  Client                                Server
    proc pkts                : 0          proc pkts                 : 0
    proc bytes               : 0          proc bytes                : 0
    cef pkts                 : 0          cef pkts                  : 0
    cef bytes                : 0          cef bytes                 : 0
WEBVPN Citrix statistics:
Connections serviced : 0
               Server                   Client
  Packets in  : 0                        0
  Packets out : 0                        0
  Bytes in    : 0                        0
  Bytes out   : 0                        0
ACL statistics:
    Permit web request       : 0          Deny web request         : 0
    Permit cifs request      : 0          Deny cifs request        : 0
    Permit without ACL       : 0          Deny without match ACL   : 0
    Permit with match ACL    : 0          Deny with match ACL      : 0
Single Sign On statistics:
    Auth Requests            : 0          Pending Auth Requests    : 0
    Successful Requests      : 0          Failed Requests          : 0
    Retranmissions           : 0          DNS Errors               : 0
    Connection Errors        : 0          Request Timeouts         : 0
    Unknown Responses        : 0
URL-rewrite splitter statistics:
    Direct access request    : 0          Redirect request         : 0
    Internal request         : 0
Tunnel Statistics:
    Active connections       : 0
    Peak connections         : 0          Peak time                : never
    Connect succeed          : 0          Connect failed           : 0
    Reconnect succeed        : 0          Reconnect failed         : 0
    SVCIP install IOS succeed: 0          SVCIP install IOS failed : 0
    SVCIP clear IOS succeed  : 0          SVCIP clear IOS failed   : 0
    SVCIP install TCP succeed: 0          SVCIP install TCP failed : 0
    DPD timeout              : 0
  Client                                Server
    in  CSTP frames          : 0          out IP pkts              : 0
    in  CSTP data            : 0          out stitched pkts        : 0
    in  CSTP control         : 0          out copied pkts          : 0
    in  CSTP Addr Reqs       : 0          out bad pkts             : 0
    in  CSTP DPD Reqs        : 0          out filtered pkts        : 0
    in  CSTP DPD Resps       : 0          out non fwded pkts       : 0
    in  CSTP Msg Reqs        : 0          out forwarded pkts       : 0
    in  CSTP bytes           : 0          out IP bytes             : 0
    out CSTP frames          : 0          in  IP pkts              : 0
    out CSTP data            : 0          in  invalid pkts         : 0
    out CSTP control         : 0          in  congested pkts       : 0
    out CSTP Addr Resps      : 0          in  bad pkts             : 0
    out CSTP DPD Reqs        : 0          in  nonfwded pkts        : 0
    out CSTP DPD Resps       : 0          in  forwarded pkts       : 0
    out CSTP Msg Reqs        : 0
    out CSTP bytes           : 0          in  IP bytes             : 0
    cef in CSTP data frames  : 0          cef out forwarded pkts   : 0
    cef in CSTP data bytes   : 0          cef out forwarded bytes  : 0
    cef out CSTP data frames : 0          cef in forwarded pkts    : 0
    cef out CSTP data bytes  : 0          cef in forwarded bytes   : 0
------------------ show webvpn stats context all ------------------
------------------ show webvpn nbns context all ------------------
------------------ show webvpn stats cifs ------------------
CIFS statistics:
    Aborted Conns            : 0
  SMB related Global:
------------------ show webvpn stats sock ------------------
Socket statistics:
------------------ show raw reclaimed ------------------
RAW LEAK REPORT:
ORPHAN    :  0       raw buffers reclaimed
TSP       :  0       raw buffers reclaimed
VTSP      :  1084    raw buffers reclaimed
H323      :  0       raw buffers reclaimed
SIP       :  0       raw buffers reclaimed
CCAPI     :  283     raw buffers reclaimed
VOATM     :  0       raw buffers reclaimed
XGCP      :  0       raw buffers reclaimed
CAS       :  0       raw buffers reclaimed
IVR       :  1108    raw buffers reclaimed
SSAPP     :  0       raw buffers reclaimed
Last Audit Session is at 16:14:34 PST Tue Dec 7 2010
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 20:17:06 PDT Jul 3 2010
Key name: TP-self-signed-1340681818
Storage Device: private-config
Usage: General Purpose Key
Key is not exportable.
Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00CBE009
  D7149D90 6F07E39F 8E23E696 549E3440 8B251455 5699A4DD 65AD4488 01DA8C71
  80B1A0FF BBDE6988 16B88767 F36485BE 6F04532D 208FEAAC 482E923C DA9E3CD6
  E9F2F1BC 3E19610D 432EFFE4 A722042E B52A2DAA F571A2A2 64E35302 6FE2A75D
  14F87510 4E03C1EF D57214D2 CAAE3681 6E97A43F 37D64B45 7BFFEA12 AB020301 0001
% Key pair was generated at: 15:26:56 PST Dec 7 2010
Key name: TP-self-signed-1340681818.server
Temporary key
Usage: Encryption Key
Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00AD2543 FE3788DF
  26090CC5 8387EF1B 0C7A4C99 EE9BDFAD EBFE80F4 37FD3F2A F8B84BA5 A5D7E1A2
  FC935BF5 1BA79DFE 7D3D6D18 A9C85737 5F127CE4 0EBC333C FC0036B0 53D8AD34
  19C1979C 6607CD1F F2DCFD47 09372D8B F55935E7 C78A0006 37020301 0001
------------------ show buffers ------------------
Buffer elements:
     485 in free list (1119 max allowed)
     264859527 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 96, permanent 50, peak 182 @ 7w0d):
     61 in free list (20 min, 150 max allowed)
     56535714 hits, 6833 misses, 16444 trims, 16490 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 127 @ 7w0d):
     23 in free list (10 min, 150 max allowed)
     78215466 hits, 1102 misses, 2407 trims, 2407 created
     85 failures (0 no memory)
Big buffers, 1536 bytes (total 181, permanent 50, peak 269 @ 7w0d):
     135 in free list (5 min, 150 max allowed)
     32525519 hits, 1705 misses, 4984 trims, 5115 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 100 max allowed)
     94913 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 0, permanent 0):
     0 in free list (0 min, 4 max allowed)
Interface buffer pools:
IVR MC buffers, 240 bytes (total 3360, permanent 3360):
     3360 in free list (0 min, 3360 max allowed)
     5364 hits, 0 misses
Onboard DSPRM Pool buffers, 264 bytes (total 300, permanent 300):
     0 in free list (0 min, 300 max allowed)
     300 hits, 0 fallbacks
     300 max cache size, 300 in cache
     15074220 hits in cache, 0 misses in cache
Syslog ED Pool buffers, 600 bytes (total 132, permanent 132):
     100 in free list (132 min, 132 max allowed)
     151420 hits, 0 misses
SEC Eng Packet buffers, 1700 bytes (total 512, permanent 512):
     0 in free list (0 min, 512 max allowed)
     512 hits, 0 fallbacks
     512 max cache size, 512 in cache
IPC buffers, 4096 bytes (total 2, permanent 2):
     1 in free list (1 min, 8 max allowed)
     1 hits, 0 fallbacks, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 384, permanent 384):
     384 hits, 0 misses, 0 trims, 0 created
     384 max cache size, 384 in cache
C5510 Header Pool buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     14727169 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
     128 in free list (128 min, 1024 max allowed)
     256 hits, 0 misses, 0 trims, 0 created
     256 max cache size, 256 in cache
Normal buffers, 1536 bytes (total 512, permanent 512):
     390 hits, 0 misses, 0 trims, 0 created
     128 max cache size, 128 in cache
Private particle pools:
HQF buffers, 0 bytes (total 2000, permanent 2000):
     2000 in free list (500 min, 2000 max allowed)
SEC Eng Particle Header buffers, 256 bytes (total 512, permanent 512):
pp00 buffers, 512 bytes (total 1536, permanent 1536):
     0 in free list (0 min, 1536 max allowed)
     1536 hits, 0 fallbacks
     1536 max cache size, 1024 in cache
     82958035 hits in cache, 0 misses in cache
Serial0/3/0:23 buffers, 512 bytes (total 8, permanent 8):
     0 in free list (0 min, 8 max allowed)
     8 hits, 0 fallbacks
     8 max cache size, 4 in cache
     249171 hits in cache, 0 misses in cache
SEC Eng Particle buffers, 1700 bytes (total 512, permanent 512):
     512 hits, 0 misses
GigabitEthernet0/0 buffers, 1744 bytes (total 384, permanent 384):
     0 in free list (0 min, 384 max allowed)
     384 hits, 0 fallbacks
GigabitEthernet0/1 buffers, 1744 bytes (total 384, permanent 384):
     384 hits, 6 fallbacks
     384 max cache size, 256 in cache
     111742338 hits in cache, 0 misses in cache
------------------ show buffers usage ------------------
Statistics for the Small pool
Caller pc    : 0x8005D30C count:       34
Resource User:   IP Input count:       34
Caller pc    : 0x8052EB14 count:        1
Resource User:  Interrupt count:        1
Number of Buffers used by packets generated by system:   62
Number of Buffers used by incoming packets:              34
Statistics for the Middle pool
Caller pc    : 0x8005D30C count:        2
Resource User:   IP Input count:        2
Number of Buffers used by packets generated by system:   23
Number of Buffers used by incoming packets:               2
Statistics for the Big pool
Caller pc    : 0x81E12FE8 count:       41
Resource User: Skinny Msg count:       38
Resource User: SCCP Appli count:        2
Output IDB   :      Gi0/1 count:        1
Resource User:  HTTP CORE count:        1
Caller pc    : 0x81ABFE48 count:        4
Resource User:   IP Input count:        4
Number of Buffers used by packets generated by system:  181
Number of Buffers used by incoming packets:               0
Statistics for the VeryBig pool
Number of Buffers used by packets generated by system:   10
Statistics for the Large pool
Number of Buffers used by packets generated by system:    0
Statistics for the Huge pool
Statistics for the IVR MC pool
Number of Buffers used by packets generated by system: 3360
Statistics for the Onboard DSPRM Pool pool
Number of Buffers used by packets generated by system:  300
Statistics for the Syslog ED Pool pool
Caller pc    : 0x816C168C count:       32
Resource User: EEM ED Sys count:       32
Number of Buffers used by packets generated by system:  132
Statistics for the SEC Eng Packet pool
Number of Buffers used by packets generated by system:  512
Statistics for the IPC pool
Caller pc    : 0x803CB824 count:        1
Resource User:       Init count:        1
Statistics for the Header pool
Number of Buffers used by packets generated by system:  384
Statistics for the FS Header pool
Caller pc    : 0x80038348 count:      526
Resource User:       Init count:      528
Caller pc    : 0x818344F4 count:        1
Caller pc    : 0x802786F0 count:        1
Number of Buffers used by packets generated by system:  544
Statistics for the C5510 Header Pool pool
Number of Buffers used by packets generated by system:  768
Statistics for the SW Crypto Header pool
Caller pc    : 0x8339A1CC count:        1
Statistics for the Crypto Fragmentation Header pool
Caller pc    : 0x834BC0CC count:        1
------------------ show license udi ------------------
Device#   PID   SN  UDI
*0     UC560-T1E1-K9         FHK1427F48H     UC560-T1E1-K9:FHK1427F48H
------------------ show license feature ------------------
Feature name             Enforcement  Evaluation  Subscription   Enabled
uc-user                  yes          yes         no             yes
------------------ show license file ------------------
License Store: Primary License Storage
  Store Index: 0
    License: 11 uc-user 1.0 LONG NORMAL STANDALONE EXCL 16_KEYS INFINITE_KEYS
             NEVER NEVER NiL SLM_CODE CL_ND_LCK NiL *13NGXD9HKSYFAQ5400 NiL Ni
             L NiL 5_MINS UC560-T1E1-K9FHK1427F48H             DI> zfGrpYLZ,FrDMEPzc1kN3Suqwr,7KHZaDlcMPq5HpBVkHB5YUMejm3ClP0PaY
             ZU1VIUJACUWQ1cZUVf7KyvwG9Vjh06D57SIPUKQZFoZ5C7WLhpRksbcAu0ZLfhF0b
             pqRnL:$AQEBIf8B///5ViJkmYAoES0cdbGvixtv/CAq3SONWSSxX567id6vF
             Zo5eZnGVaDgiDD/vVtvs1pHebPkGlARtYd1UQO7GJ3KnufZ9oZ6JdFniDf5HrQ8Dr
             XdpCz5RgZE+y8fbN200xiXA5cB3fwcJqoPIFZm2HmD1qFfsyTAzuio66t6Xk5y8xo
             1lbVhvoh/FZfy5iRY3oE=
    Comment:
       Hash: szCBdZ4KAwcDjZImb4M3oJMvX90=
  Store Index: 1
    License: 11 uc-user 1.0 LONG NORMAL STANDALONE EXCL 48_KEYS INFINITE_KEYS
             L NiL 5_MINS UC560-T1E1-K9FHK1427F48H             DI> wla5rsWSvmiDGy4WFX,Mf,Bmki5otVTT2owCpvTJyTLSDCVVQiN3VUVvgDC3Y
             rmGfNPzjbLTCwhD8h0yiSP5UGf2P5UpJHrms8aALmZRbzmzfG4UGB7DgpG8KoYuPb
             MPFZL1$AQEBIf8B//9CqLvzNrX6BcmXZRtliBFViN2QlpyTsD2RuSg9Ipmqm
             LHhrPBgWMDTpw4S9Ffes1ZHebPkGlARtYd1UQO7GJ3KnufZ9oZ6JdFniDf5HrQ8Dr
    Comment:
       Hash: jdaciT8kLpxn0OkB99P6MoIs9xM=
License Store: Evaluation License Storage
  Store Index: 0
    License: 11 uc-user 1.0 LONG TRIAL DISABLED 1440 DISABLED STANDALONE ADD 1
             04_KEYS INFINITE_KEYS NEVER NEVER NiL SLM_CODE DEMO NiL NiL Ni Ni
             L NiL 5_MINS NiL L7rwc7DFAHbKOWI59bQnVUIwzCB7bgvnVFePXSoTMoLsjUWv
             eQ:FbjUY7Jg1qEyYLo$AQEBIQAB//+1Nyajm9IR/njepPHloemhpJXQzdvtX
             HbXMhq1FZbIvUHCS//zwtADaR/q0RkrPBlByt9kcrgZxr1VeijPKSIA22YLMhfdZB
             CfdCLWCSD2RicqG/LKp68JbYF1P9/Dg4lR4fq67AfFwP17cNuyAEHAwSqrplWmRvR
             b2D3kg2FZP3k6yFZQOBXAfYEx0XMtVsA=
    Comment:
       Hash: xyMqRaxBZvyDoTsZ6RSXsgNsJFk=
------------------ show license detail ------------------
Index: 1  Feature: uc-user                           Version: 1.0
License Type: Permanent
License State: Active, In Use
Lock type: Node locked
Vendor info: UC560-T1E1-K9FHK1427F48H
License Addition: Exclusive
License Generation version: 0x8100000
License Count: 48/48/0  (Active/In-use/Violation)
License Priority: Medium
Store Index: 1
Store Name: Primary License Storage
Index: 2  Feature: uc-user                           Version: 1.0
License State: Inactive
License Count: 16/0/0  (Active/In-use/Violation)
Store Index: 0
Index: 3  Feature: uc-user                           Version: 1.0
License Type: Evaluation
     Evaluation total period: 8  weeks 4  days
     Evaluation period left: 8  weeks 4  days
Lock type: Non Node locked
Vendor info:
License Addition: Additive
License Count: 104/0/0  (Active/In-use/Violation)
License Priority: None
Store Index: 0
Store Name: Evaluation License Storage
------------------ show license status ------------------
  License Type Supported
permanent               Non-expiring node locked license
extension               Expiring node locked license
evaluation              Expiring non node locked license
  License Operation Supported
install    Install license
clear      Clear license
annotate   Comment license
save       Save license
Modify     Modify license
revoke     Revoke license
call-home  License call-home
  Call-home Operation Supported
show pak   Display license pak via call-home
install    Install license via call-home
revoke     Revoke license via call-home
resend     Fetch license via call-home
  Device status
Device Credential type: DEVICE
Device Credential Verification: PASS
Rehost Type: HARDWARE
SWIFT url status
Swift URL set to default value : https://tools.cisco.com/SWIFT/Licensing
------------------ show license statistics ------------------
  Administrative statistics
Install success count:   0
Install failure count:   0
Install duplicate count: 0
Comment add count:       0
Comment delete count:    0
Clear count:             0
Save count:              0
Save cred count:         0
  Client statistics
Request success count:   3
Request failure count:   0
Release count:           2
Global Notify count:     0
------------------ show inventory ------------------
NAME: "UC560-T1E1-K9 Chassis", DESCR: "UC560-T1E1-K9 Chassis"
PID: UC560-T1E1-K9     , VID: V02, SN: FHK1427F48H
NAME: "Four port FXS DID voice interface daughtercard in DaughterCard Slot 2", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC103746HS
------------------ Mempool statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   85BFADD4   427000364    90122840   336877524   335657980   336401848
      I/O   1F333000    13422592     8444588     4978004     4827456     4746652
-------------- Top 100 allocator pc summary -----------
Allocator PC Summary for: Processor
Displayed first 2048 Allocator PCs only
    PC          Total   Count  Name
0x80309504    7150700    6316  *Packet Header*
0x8135F6F0    5000052       1  Init
0x82A39F24    4529048     313  List Headers
0x802C0C54    3164160     330  Process Stack
0x8231E460    2700916      82  CCE dp subbloc
0x828F7B9C    2597280     148  Init
0x82514754    2295184      34  regex
0x810E5E14    1529856     256  CCSIP_SPI_CONTROL
0x82A8AC20    1354212     268  List Headers
0x807EDF3C    1254260     595  Init
0x801E1AE8    1118760      49  Init
0x8020EA00    1097328    4094  ESWPPM
0x813A1AB0     973384      18  Init
0x8386A3EC     884216     358  CCVPM_HTSP
0x82A8E254     843476      73  TW Buckets
0x81009A00     837684       1  CCH323_CT
0x814DB1A0     768176     164  HTTP CP
0x82952928     757612     152  TCL Chunks
0x81395D64     749684     169  TTY data
0x80709E40     731112      41  Skinny Msg Server
0x811E7D3C     691268       2  CCSIP CCB Pool Chunk
0x813C7108     664264      91  HTTP CP
0x82AD2C7C     617732      13  pak subblock chunk
0x81629014     591072      24  Fair Queueing
0x82643D90     455732       1  RTPSPI
0x8304CC50     396336      12  Firewall State
0x808DFFDC     384872     226  Virtual Exec
0x827A6250     313416    4102  State Machine Instance
0x8092921C     293280       8  dsp channel
0x8330F06C     270168    1812  Init
0x803D08C4     264404       5  IPC Message He
0x81721608     262248       2  CEF: hash table
0x8002A060     262196       1  NVRAM Buffer
0x82A98A54     258484     328  Process
0x8033B7F8     243096      24  Normal
0x810F69D4     213044       1  CCSIP_TCP_SOCKET
0x80D16364     213044       1  CCSIP_TLS_SOCKET
0x82A93038     212564      52  Watched Semaph
0x8033B8A0     209304      76  Normal
0x837854A0     208144       1  epa crypto blk
0x80448D0C     196764       3  Init
0x81CAAEF4     192104       2  Simple Trace
0x813A6F18     184288       2  event_trace_tbs
0x80F9F0AC     183800      50  VTSP
0x82A9BE88     182272     928  Init
0x80B48614     171828     111  HTTP CP
0x82AA64FC     160988       8  RMI-RO_RU Chun
0x813CBA20     158888     600  HTTP CP
0x829529A4     155924      30  TclCreateExecEnv
0x80448C78     147000      70  Init
0x83771474     139264     512  SEC MOD-EXP
0x8135D4C4     138804      43  *Hardware IDB*
0x81773860     135832       4  OCE reinject h
0x802BD9B8     131176       2  CPU RO RU Chun
0x824411E0     131176       2  HQF: blt array
0x803069C4     131124       1  *Init*
0x82675BA4     129120     120  AFW_application_process
0x8187C1FC     117880    1327  Init
0x8247EAE8     116788       1  QOS_MODULE_MAIN
0x8247E994     115764       1  QOS_MODULE_MAIN
0x82AA6598     115332     640  Init
0x80309558     106656     132  *Packet Data*
0x810FBE8C     106548       1  CCSIP_UDP_SOCKET
0x81921474      98356       1  Init
0x8251446C      98080     964  Init
0x80765E80      94296      93  HTTP CP
0x81E170E4      89824      56  TCP CB
0x816697C8      86640      20  EEM Server
0x816697B0      86640      20  EEM Server
0x8383EECC      82620      11  Hashtable Buckets
0x81BC27F0      82172       1  Init
0x8386A3E0      80236     358  HTTP CP
0x80A175E4      80196       2  DSPRM msg chunk
0x82A93524      79128     333  Process Events
0x82952794      78524      17  TCL Chunks
0x8292ADF8      77252       1  Spanning Tree Opt Port Block
0x816706B4      74000      20  EEM Server
0x83715720      72284       2  WEBVPN Queue Descriptor
0x813C0184      71896     923  Parser Linkage
0x83979880      70764     332  Virtual Exec
0x82A89A94      70364       7  List Elements
0x82FACA3C      68852       2  FW SID
0x82319F34      67780       2  CCE dp feature object element
0x82319EB0      67368       2  CCE dp class instance
0x8304F120      67368       2  FW host entry
0x82319E84      67096       2  CCE dp class
0x81DD5698      67028       9  COPS
0x831018D4      66560       2  FW SIP Session
0x823BC000      66528       2  CCE rate list pool
0x83069ED8      66404       2  FW FTP chunk
0x82FCE508      66404       2  FW FTP chunk
0x8370EDA8      66348       2  webvpn session
0x80648940      66224       2  CDAPI Msg Chunk
0x806463B8      66224       2  CDAPI Msg Chun
0x82FAC95C      66212       2  FW sis
0x80B33FB0      66148       2  VTSP cdb chunk
0x822FBF20      66136       2  FPM stat feature object
0x8230F330      66136       2  qos stat feature object
0x822FF02C      66136       2  nat stat feature object
0x8231FBEC      66136       2  CCE dp feature object
Allocator PC Summary for: I/O
    PC          Total   Count  Name
0x8033B7F8    3466368       6  GigabitEthernet0/0
0x80309558    3058912    4486  *Packet Data*
0x8033B8B8    1250240      27  Normal
0x83771518     311296     512  SEC Data Buffer
0x83771860     122944       1  SEC Crypto Pak
0x83771580      49152     512  SEC Key Buffer
0x837715DC      49152     512  SEC IPv4 Buffer
0x83771600      49152     512  SEC IPv4 Options Buffer
0x83771628      49152     512  SEC IPv6 Buffer
0x80656B0C      16448       1  C5510 DSP
0x80656CB4       8256       1  C5510 DSP
0x8053F194       4160       1  HDLC32_TX
0x80069BA4       2176       2  Init
0x80069BE8       1152       2  Init
0x8053F1F4       1088       1  HDLC32_RX
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x1F333000  0x1FFFFFFF    13422592  Iomem  R/W    iomem
0x80000000  0x9F332FFF   523448320  Local  R/W    main
0x800200EC  0x8398371B    60175920  IText  R/O    main:text
0x8398371C  0x8561D41F    29990148  IData  R/W    main:data
0x8561D420  0x85BFADD3     6150580  IBss   R/W    main:bss
0x85BFADD4  0x9F332FFF   427000364  Local  R/W    main:heap
Free Region Manager:
------------------ show dmvpn detail ------------------
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
# Ent --> Number of NHRP entries with same NBMA peer
NHS Status: E --> Expecting Replies, R --> Responding
UpDn Time --> Up or Down Time for a Tunnel
------------------ show crypto ipsec client ezvpn ------------------
Easy VPN Remote Phase: 8
------------------ show ip nat statistics ------------------
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0, occurred 7w0d ago
Outside interfaces:
  GigabitEthernet0/0
Inside interfaces:
  Integrated-Service-Engine0/0, Vlan1, Vlan90, Vlan100
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface GigabitEthernet0/0 refcount 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
------------------ show ip nat translations ------------------
------------------ show crypto map ------------------
No crypto maps found.
------------------ show access-list ------------------
Standard IP access list 1
    10 permit 10.1.1.0, wildcard bits 0.0.0.255
    20 permit 192.168.15.0, wildcard bits 0.0.0.255
    30 permit 10.1.10.0, wildcard bits 0.0.0.3
Extended IP access list 100
    10 deny ip 192.168.15.0 0.0.0.255 any
    20 deny ip host 255.255.255.255 any
    30 deny ip 127.0.0.0 0.255.255.255 any
    40 permit ip any any
Extended IP access list 101
    10 deny ip 10.1.10.0 0.0.0.3 any
    20 deny ip 10.1.1.0 0.0.0.255 any
    30 deny ip host 255.255.255.255 any
    40 deny ip 127.0.0.0 0.255.255.255 any
    50 permit ip any any (10953553 matches)
Extended IP access list 102
    10 permit tcp 10.1.10.0 0.0.0.3 any eq 2000 (652988 matches)
    20 permit udp 10.1.10.0 0.0.0.3 any eq 2000
    30 deny ip 192.168.15.0 0.0.0.255 any
    40 deny ip 10.1.10.0 0.0.0.3 any
    50 deny ip host 255.255.255.255 any
    60 deny ip 127.0.0.0 0.255.255.255 any
    70 permit ip any any (74534018 matches)
Extended IP access list 103
    10 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any (375006 matches)
    20 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
    40 deny ip 10.1.1.0 0.0.0.255 any
    70 permit ip any any (15570125 matches)
Extended IP access list 104
    20 deny ip 10.1.10.0 0.0.0.3 any
    30 deny ip 10.1.1.0 0.0.0.255 any
    40 permit udp any eq bootps any eq bootpc
    50 permit icmp any any echo-reply
    60 permit icmp any any time-exceeded
    70 permit icmp any any unreachable
    80 deny ip 10.0.0.0 0.255.255.255 any
    90 deny ip 172.16.0.0 0.15.255.255 any
    100 deny ip 192.168.0.0 0.0.255.255 any
    110 deny ip 127.0.0.0 0.255.255.255 any
    120 deny ip host 255.255.255.255 any
    130 deny ip any any log
------------------ show crypto isakmp policy ------------------
Default IKE policy
Protection suite of priority 65507
encryption algorithm: AES - Advanced Encryption Standard (128 bit keys).
hash algorithm:  Secure Hash Standard
authentication method: Rivest-Shamir-Adleman Signature
Diffie-Hellman group: #5 (1536 bit)
lifetime:  86400 seconds, no volume limit
Protection suite of priority 65508
authentication method: Pre-Shared Key
Protection suite of priority 65509
hash algorithm:  Message Digest 5
Protection suite of priority 65510
Protection suite of priority 65511
encryption algorithm: Three key triple DES
Diffie-Hellman group: #2 (1024 bit)
Protection suite of priority 65512
Protection suite of priority 65513
Protection suite of priority 65514
------------------ show crypto ipsec transform ------------------
Transform set #$!default_transform_set_1: { esp-aes esp-sha-hmac  }
   will negotiate = { Transport,  },
Transform set #$!default_transform_set_0: { esp-3des esp-sha-hmac  }
------------------ show crypto ipsec profile ------------------
------------------ show crypto isakmp sa ------------------
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
IPv6 Crypto ISAKMP SA
------------------ show crypto engine connection active ------------------
Crypto Engine Connections
   ID  Type    Algorithm           Encrypt  Decrypt LastSeqN IP-Address
------------------ show crypto ipsec sa ------------------
No SAs found
In discussing the problem with a Cisco engineer it was determined that the receptionist was resuming the original call before ending the call to the extension that the 1st call was being transferred to.  This left the 2nd call active which after 10 seconds or so disruppted the original call.  The solution is to end the 2nd call by pressing the EndCall softkey and then resuming the original call.
Thank you all for your replies.
Cas closed.
Dana
