05-08-2013 05:25 AM - edited 03-16-2019 05:12 PM
Hello all
Is there a way to setup Cisco to Cisco VoIP calling on separate organizations UC systems? I heard that the product that Cisco had to facilitate this in the past was pulled. Thanks
Erik
05-08-2013 05:52 AM
Erik,
Are you referring to Cisco IME (Intercompany media engine)? If so, I have not heard of it being pulled and to my knowledge is available.
HTH,
Chris
05-08-2013 05:56 AM
Cisco IME is end-of-life. It was announced earlier this year.
GTG
05-08-2013 05:56 AM
Ps found this EOL notice. Is there a replacement product?
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps10669/end_of_life_notice_c51-706734.html
05-08-2013 05:59 AM
The closest replacement is VCS-X.
(But if you're looking to establish connections between a small number of CUCM clusters, then why not look at things like SIP/Inter-cluster trunks, IP VPNs, etc ?)
GTG
05-08-2013 06:00 AM
Interesting, must have missed that, though did not see it going far anyway :-(
The announcement states this is EOL of IME easy order bundle, but since there is no replacement I am assuming the whole solution is gone.
Chris
05-08-2013 06:02 AM
I've done a fair amount of work with IME, and the product is dead. Don't think of doing any new installations and shut down any existing installations (Assuming there were some...)
GTG
05-08-2013 06:05 AM
Good to know Gordon (+5), I am glad I have not been pitching it in to my customers :-)
Chris
05-08-2013 06:06 AM
All of this feedback is much appreciated! We just want our larger clients to be able to reach out call center via VoIP rather than PSTN. We have Vpns to them. So is inter cluster trunks the route to investigate then?
05-08-2013 05:54 AM
Chris
Thank you yes that's exactly it I just didn't know what it was called. I wonder if our tech folks are blowing smoke.
Does the product work we'll in you opinion?
Thanks for the reply!
Erik
