uc500 & hardware conference (more than three people)
recep.sefer
are the anyone?
who makes hardware conference with UC500
I am try yo configure UC500
taking th following error messages
Jun 22 09:42:25.703: sccp_process_swb_control_message: appl 8437CA68, soc_recv err 254, len -1, appl_type 3
Jun 22 09:42:35.711: sccp_process_swb_control_message: appl 8437CA68, soc_recv err 254, len -1, appl_type 3
Jun 22 09:42:43.791: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
Jun 22 09:42:45.719: sccp_process_swb_control_message: appl 8437CA68, soc_recv err 254, len -1, appl_type 3
Jun 22 09:42:55.727: sccp_process_swb_control_message: appl 8437CA68, soc_recv err 254, len -1, appl_type 3
Jun 22 09:43:05.735: sccp_process_swb_control_message: appl 8437CA68, soc_recv err 254, len -1, appl_type 3
Jun 22 09:43:15.743: sccp_process_swb_control_message: appl 8437CA68, soc_recv err 254, len -1, appl_type 3
8 Replies 8
paolo bevilacqua
Which exact IOS are you using ?
12.4(11)XW6
Can you upgrade to XW8 to eliminate chances this is caused by a bug already fixed ?
12.4(11)XW7 is available for UC500
I cannot find 12.4(11)XW8
I try 12.4(11)XW7, problem continues.
thanks
Yes I can find 12.4(11)XW8, however since I cannot guarantee that is the problem, does the conferencing works beside the error message ? can you send config ?
here is my config;
stcapp ccm-group 1
stcapp
stcapp feature access-code
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice-card 0
dspfarm
dsp services dspfarm
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
crypto map SDM_CMAP_1
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
caller-id enable
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register mtp001e1314cf42
keepalive retries 5
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dial-peer voice 1 pots
preference 7
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
telephony-service
sdspfarm units 4
sdspfarm tag 1 mtp001e1314cf42
conference hardware
ephone-template 1
conference admin
network-locale 1
user-locale 1
keep-conference
ephone-dn 5 dual-line
number 301
label 301
description 301
name 301
ephone-dn 6 dual-line
number 302
label 302
description 302
name 302
ephone-dn 7 dual-line
number 303
label 303
description 303
name 303
ephone-dn 8 dual-line
number 304
label 304
description 304
name 304
ephone-dn 10 dual-line
number 201
pickup-group 4
label 201
call-forward busy 600
call-forward noan 600 timeout 10
ephone-dn 11 dual-line
number 202
pickup-group 4
label 202
ephone 5
device-security-mode none
video
ephone-template 1
type 7975
button 1:10
ephone 6
video
ephone-template 1
type 7975
button 1:11
Hi, you're missing a large number of required commands for HW conferencing, please check the administrator guide again to see all the ones that are required.
excuse me,
I have missed some
The following is true
The same config works on 2851 (3 PVDM)
But it cannot work UC500 (2 PVDM)
stcapp ccm-group 1
stcapp
voice service voip
sip
no update-callerid
voice class codec 1
voice-card 0
dspfarm
interface Loopback0
ip nat inside
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
caller-id enable
sccp
sccp ccm group 1
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
preference 7
service stcapp
port 0/0/0
service stcapp
port 0/0/1
service stcapp
port 0/0/2
service stcapp
port 0/0/3
telephony-service
sdspfarm units 4
conference hardware
ephone-template 1
conference admin
network-locale 1
user-locale 1
keep-conference
number 301
label 301
description 301
name 301
number 302
label 302
description 302
name 302
number 303
label 303
description 303
name 303
number 304
label 304
description 304
name 304
ephone-dn 30 dual-line
number 8889
name Conference
conference ad-hoc
no huntstop
ephone-dn 31 dual-line
number 8889
name Conference
conference ad-hoc
preference 1
no huntstop
ephone-dn 32 dual-line
number 8889
name Conference
conference ad-hoc
preference 2
no huntstop
ephone-dn 33 dual-line
number 8889
name Conference
conference ad-hoc
preference 3
number 201
pickup-group 4
label 201
number 202
pickup-group 4
label 202
ephone 5
video
ephone-template 1
type 7975
button 1:10
ephone 6
video
ephone-template 1
type 7975
button 1:11
