UC500 SIP Trunk
davidfield
Level 3
Level 3
Hello All,
Apologies in advance for the long winded post. helping with the config woudl be awesome, but I'm not expecitng that and some concise links would be aprreciated.
I've been asked to setup a SIP trunk on the office UC540.   Using CCA I thought it would not be a problem, but suffice it to say that when I applied the settings through CCA it broke a lot of stuff that one of the other guys had been doing through CLI - He has left so need to work out on my own.
In summary we have a SIP account with a provider and I've been doing a lot of reading but confusion has set in.  Can anyone point me to a good CLI example of the following:
- Setup of SIP trunk
- Dial Peers.  In summary I need to be able to press say 8....... to get a Line through SIP and 9...... to get a line through FXO
- An example of how to Map SIP DDI's to internal Extensions.
This is what I have from the Provider:
Number of Channels: 4
IP Address: 178.AA.42.156
SIP signalling gateway address: 88.BB.61.195
- UDP port 5060 egress/ingress to 88.BB.61.195 (IPDC SIP signalling gateways).
- All UDP ports between 6000 - 40000 egress/ingress to 88.BB.61.196 (IPDC Media gateway) Omission of this setting will result in one-way speech
DDI 02034478900- 02034478910
From what I can gather they haven't provided a Username/password and are authenticating my use of the service via my source IP so I assume something like as follows:
Internal Extensions are 2000-2100
voice translation-profile PROVIDER
translate calling 2010
translate called 2011
translate redirect-called 2011
dial-peer voice 888 voip
description SIP to Provider
translation-profile outgoing PROVIDER
preference 1
destination-pattern [8]...
rtp payload-type comfort-noise 13
session protocol sipv2
session target ipv4:88.BB.61.195
session transport udp
voice-class codec 2
dtmf-relay rtp-nte
fax-relay ecm disable
no vad
I assume I have to create a copy of above for every destination pattern that is present for the FXO to go out the SIP when preceeding 8 is pressed.
No idea on how to map the DDI's to an internal extension.
Am I missing anything?
I should also mention there is another SIP trunk to another UC520 over a VPN.  This is what gets messed up when I use the CCA.
Thanks in advance
Dave
To get this number to ring on extension 2800..
You need to change this config as follows..
voice translation-rule 4
rule 1 /^02036678903/ /2800/
Leave this dial-peer as it is..
dial-peer voice 3000 voip
description DDIRange
translation-profile incoming DDIRange_Called_4
session target sip-server
incoming called-number 02036678903
dtmf-relay rtp-nte
codec g711alaw
no vad
By the way try and send me the logs when the MTP was active. Send debug ccsip messages
To enable your ocnference profile back, you need to disable the MTP
dspfarm profile 2 mtp
shut
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
34 Replies 34
Tagir Temirgaliyev
voice service voip
allow−connections sip to sip
no supplementary−service sip moved−temporarily
!−−−Disable 302 sending
no supplementary−service sip refer
!−−−Disable REFER sending
sip
registrar server expires max 3600 min 3600
localhost dns:domain.test.com
voice class codec 1
codec preference 1 g711ulaw
!−−− SIP UA Configuration −−−
sip−ua
authentication username 5123781000 password 075A701E1D5E415447425B
no remote−party−id
retry invite 2
retry register 10
retry options 0
timers connect 100
registrar dns:domain.test.com expires 3600
sip−server dns:domain.test.com
host−registrar
!−−− CME Telephony Service Configuration −−−
telephony−service
no auto−reg−ephone
load 7960−7940 P0030702T023
max−ephones 168
max−dn 500
ip source−address 172.22.1.107 port 2000
calling−number initiator
!−−− Preserves the caller−id of a call when transferred or forwarded
dialplan−pattern 1 51237812.. extension−length 3 extension−pattern 2.. no−reg
voicemail 600
max−conferences 12 gain −6
call−forward pattern .T
call−forward system redirecting−expanded
!−−− Enables translation rule features for call−forwarding
moh music−on−hold.au
transfer−system full−consult dss
transfer−pattern 9.T
secondary−dialtone 9
create cnf−files version−stam
Hello and thankyou for the above sample and it has helped.
I'm still having some issues but at least now I can get a handset to ring internally when I ring the SIP trunk number. When the call is anwsered I just jet continuous ringing and no call connect.   From the SIP trace it looks like I get a 403 Forbidden but from what I can see the SIP trunk is up and running.
The only reason we are using the SIP trunk is to allow some staff to had Direct DDI numbers but primarily for a DDI for the Auto Attendant on 2888.  So I only really need inbound calling ans the ability to translate to their internal extension. All outbound calling is via the analogue lines.
PS: I've disabled trust list and access list at the moment on the Public interface for testing.  So really the only config on the router is the NAT translations below.
Can anyone point me in the right direction?
Thanks in advance Dave
SIP trunk config
rule 1 /020366XXXXX/ /2888/
sip-ua
keepalive target ipv4:88.BB.61.195:5060
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
sip-server ipv4:88.BB.61.195:5060
host-registrar
g729-annexb override
ephone-dn  64
number 020366XXXXX
description SIP Main Number registration
preference 10
incoming called-number 020366XXXXX
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Gamma) **
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
Router config
ip nat pool SIPPORTFWD 10.44.1.254 10.44.1.254 netmask 255.255.255.0 type rotary
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static udp 10.44.1.254 5060 interface Dialer0 5060
ip nat inside source static tcp 10.44.1.254 5060 interface Dialer0 5060
ip nat inside destination list 100 pool SIPPORTFWD
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 100 permit udp any any range 4000 6000
Stip Status
UC520London#sh sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): DISABLED
SIP User Agent bind status(media): DISABLED
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
Out-of-dialog Refer: DISABLED
Presence support is DISABLED
protocol mode is ipv4
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio video image
Network types supported: IN
Address types supported: IP4 IP6
Transport types supported: RTP/AVP udptl
SIP trace:
eceived:
INVITE sip:020366XXXXX@10.44.1.254;user=phone SIP/2.0
Max-Forwards: 69
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: <>020366XXXXX@88.BB.61.195:5060;user=phone>
Call-ID: 2052182-3567595023-902808@MSX27.gammatelecom.com
CSeq: 1 INVITE
Allow: CANCEL, ACK, INVITE, BYE, OPTIONS, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Via: SIP/2.0/UDP 88.BB.61.195:5060;branch=z9hG4bK91317f87f846673dc8a1e9f22f018b64
Contact: <>anonymous@88.BB.61.195:5060>
Content-Type: application/sdp
Accept: application/sdp
Content-Length: 291
v=0
o=MSX27 8020304351181920704 1 IN IP4 88.BB.61.195
s=sip call
c=IN IP4 88.BB.61.196
t=0 0
m=audio 37052 RTP/AVP 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no;mr=0;mg=0;jmdelay=no;mrmods=
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
035630: //33514/86BC294EA21E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 14:37:03 gmt
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
035631: //33514/86BC294EA21E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 403 Forbidden
To: <>020366XXXXX@88.BB.61.195:5060;user=phone>;tag=3DB43710-1D63
CSeq: 1 INVITE
Reason: Q.850;cause=21
Content-Length: 0
035632: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:020366XXXXX@10.121.30.4;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001mqPBF;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
035633: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
Call-ID: 2052186-3567595026-635188@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.BB.61.195:5060;branch=z9hG4bK5d9d0ab5eb372d2af55964025249a27e
Content-Length: 290
v=0
o=MSX27 355439370013519270 1 IN IP4 88.BB.61.195
s=sip call
t=0 0
m=audio 37060 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
035634: //33515/885E44DFA223/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 14:37:06 gmt
CSeq: 1 INVITE
Content-Length: 0
035635: //33515/885E44DFA223/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <>020366XXXXX@88.BB.61.195:5060;user=phone>;tag=3DB441C4-1F8A
CSeq: 1 INVITE
Content-Length: 0
035636: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001JOBYy;icid-generated-at=10.121.0.0;orig-ioi=tes001-tss-tra.gamma.uktel.org.uk
Content-Length: 0
035637: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <>+21268947446@88.BB.61.195>;tag=3567595028-778280
P-Asserted-Identity: <>+21268947446@88.BB.61.195;user=phone>
Call-ID: 2052190-3567595028-778272@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.BB.61.195:5060;branch=z9hG4bK8d95134536808daa650be8e082389233
Contact: <>+21268947446@88.BB.61.195:5060>
Content-Length: 291
v=0
o=MSX27 8052248780475719226 1 IN IP4 88.BB.61.195
s=sip call
t=0 0
m=audio 37068 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
035638: //33516/89A43523A228/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 14:37:08 gmt
CSeq: 1 INVITE
Content-Length: 0
035639: //33516/89A43523A228/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <>020366XXXXX@88.BB.61.195:5060;user=phone>;tag=3DB44A1C-1672
CSeq: 1 INVITE
Content-Length: 0
035640: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001mqPDa;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
035641: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <>+21268947446@88.BB.61.195>;tag=3567595030-728142
Call-ID: 2052192-3567595030-728133@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.BB.61.195:5060;branch=z9hG4bK18dafbd1d89e8995616aeecba29f6fe5
Content-Length: 290
v=0
o=MSX27 805097837701719365 1 IN IP4 88.BB.61.195
s=sip call
t=0 0
m=audio 37072 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
035642: //33517/8AD082ADA22D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 14:37:10 gmt
CSeq: 1 INVITE
Content-Length: 0
035643: //33517/8AD082ADA22D/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <>020366XXXXX@88.BB.61.195:5060;user=phone>;tag=3DB451CC-649
CSeq: 1 INVITE
Content-Length: 0
035644: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001mqPER;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
035645: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
Call-ID: 2052196-3567595033-871426@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.BB.61.195:5060;branch=z9hG4bK5b0510fde6c0568e953b811145d6a896
Content-Length: 291
Reason why call is disconnected is this
Sent:
To resolve this..
You need to configure the ip address of your sip providedr under the ip address trusted list as follows:
voice service voip
     ipv4 []
Sent:
To resolve this..
voice service voip
     ipv4 []
Thanks for hte quick repsonse.  For testing purposes I applied accept all
voice service voip
  ipv4 0.0.0.0 0.0.0.0
The 402 forbiden is gone now but I still dont get a call to the autoattendant.  I think my dial peers are a bit messed up adn I'm also getting 503 service unavailable. I can dial Auto Attendant on 2888 ok from inside.
rule 1 /02036678903/ /2888/
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
ephone-dn  64
number 02036678903
preference 10
voice translation-profile DDIRange_Called_4
translate calling 3265
translate called 4
permission term
voice-class codec 1
dtmf-relay rtp-nte
no vad
Kindest Regards
David
Sip messages updated
UC520London#
038231: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:02036678903@10.44.1.254;user=phone SIP/2.0
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2074374-3567602887-218880@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK0ba712fb0a799c8991707f8325564588
Contact:
Content-Length: 290
v=0
o=MSX27 805031372727595675 1 IN IP4 88.215.61.195
s=sip call
c=IN IP4 88.215.61.196
t=0 0
m=audio 12572 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
038232: //34293/D5A19D6DA81F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <02036678903>
Date: Sat, 19 Jan 2013 16:48:07 gmt
CSeq: 1 INVITE
Content-Length: 0
038233: //34293/D5A19D6DA81F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <02036678903>;tag=3E2C3220-9AA
CSeq: 1 INVITE
Reason: Q.850;cause=47
Content-Length: 0
038234: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:02036678903@10.121.30.4;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Contact:
P-Charging-Vector: icid-value=00001mrGo0;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
038235: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2074375-3567602887-320117@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK63c5132a9094e9192af12818c740f8c4
Contact:
Content-Length: 289
v=0
o=MSX27 80201582476225700 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 12574 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
038236: //34296/D5B0DFB7A826/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <02036678903>
CSeq: 1 INVITE
Content-Length: 0
038237: //34296/D5B0DFB7A826/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3E2C3288-1119
CSeq: 1 INVITE
Content-Length: 0
038238: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Contact:
Content-Length: 0
038239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2074376-3567602887-420670@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK4d4f7748163fc2804f0ad064bd3fe33b
Contact:
Content-Length: 291
v=0
o=MSX27 8020234744357331980 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 12576 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
038240: //34299/D5C02167A82D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <02036678903>
CSeq: 1 INVITE
Content-Length: 0
038241: //34299/D5C02167A82D/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3E2C32F0-248F
CSeq: 1 INVITE
Content-Length: 0
Where is the dial-peer for the auto attendant? 2888..I cant see it...
can you also send the debug voip ccapi inout
Thanks Aokanlawan for helping  I have attached the UC520 config, debug Voip Ccapi & debug translations
I think my issue is the translations but the error 503 from what I've read is indicative of a more fundamental issue.  As menitoned above I just need this one number ot land on the Auttoattendant and for the caller to be able to menu their way through to someone onsite.
I tried to use the CCA to configure the SIP trunk and it messed up all my call handling with my other sites.  So rolled back and trying to configure via CLI and its proving to be quite a mission to put it together.
The pressure is on me to have the inbound calling running by Monday so I really appreciate your input.
David
I just noticed that there is a Dial Peer 2001 being referenced in the Ccapi which relates to the Autoattendant.  2001 has a translation profile of PSTN_Call_forwarding which is not in the config.  when I purged the CCA config I took all the translations out as they were causing issues as mentioned above.  So when a call comes in do I also need a Dial peer for the outbound response also?
This what was removed.
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^....$/ /02036678903/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 1 /^ABCD909[01]......../ //
rule 2 /^ABCD9090[89]......./ //
rule 3 /^ABCD9098\(.*\)/ //
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
translate calling 1111
translate called 1112
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
Please configure your dial-peer as follows:
codec g711ulaw
dtmf-relay rtp-nte
no vad
Then configure this..
voice service voip
allow connections sip to sip
Test again and send debug ccsip messages
codec g711ulaw
dtmf-relay rtp-nte
no vad
voice service voip
I get a carrier message saying the service cannot be connected. below is also CCSIP for codec G729r8 and get busy tone from carrier.
Codec g711ulaw
C520London#
043832: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2094307-3567610710-66437@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK641c34fb3ca4f8206c4bd5272547073d
Contact:
Content-Length: 291
v=0
o=MSX27 3586393515818613715 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 17596 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
043833: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
To: <02036678903>;tag=3EA38EFC-8EB
Date: Sat, 19 Jan 2013 18:58:30 gmt
CSeq: 1 INVITE
Warning: 304 10.44.1.254 "Media Type(s) Unavailable"
Reason: Q.850;cause=65
Content-Length: 0
Codec for dial peer 3000  set to g729r8 - get busy signal
UC520London#
043845: Jan 19 19:03:30.297: %SYS-5-CONFIG_I: Configured from console by cisco on vty0 (10.44.1.2)
043846: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2095053-3567611021-709411@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKd2196116f7d14da022ab0ea32b42a839
Contact:
Content-Length: 291
v=0
o=MSX27 8020103151071525935 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 17758 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
043847: //35289/C62A3BC3AF87/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <02036678903>
Date: Sat, 19 Jan 2013 19:03:41 gmt
CSeq: 1 INVITE
Content-Length: 0
043848: //35289/C62A3BC3AF87/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3EA85068-2332
CSeq: 1 INVITE
Content-Length: 0
043849: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Contact:
P-Charging-Vector: icid-value=00001mryTP;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
043850: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2095054-3567611021-825050@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKf9daa50b7e6c072d22ec9e37a17cc767
Contact:
Content-Length: 290
v=0
o=MSX27 801812905228314342 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 17760 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
043851: //35292/C63E607DAF8E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <02036678903>
CSeq: 1 INVITE
Content-Length: 0
043852: //35292/C63E607DAF8E/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3EA850EC-64B
CSeq: 1 INVITE
Content-Length: 0
043853: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Contact:
Content-Length: 0
043854: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
To: <02036678903>
Call-ID: 2095055-3567611021-964582@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKee873fc0b7285e08252bd8346e061349
Contact:
Content-Length: 290
v=0
o=MSX27 805270580154421636 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 17762 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
043855: //35295/C653BD87AF95/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <02036678903>
CSeq: 1 INVITE
Content-Length: 0
043856: //35295/C653BD87AF95/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3EA85178-1D5E
CSeq: 1 INVITE
Content-Length: 0
043857: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Contact:
Content-Length: 0
043834: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Contact:
P-Charging-Vector: icid-value=00001JPi6i;icid-generated-at=10.121.0.0;orig-ioi=tes001-tss-tra.gamma.uktel.org.uk
Content-Length: 0
Ok..I see whats going on now..
Your provider are only sending G711alaw and G729. These are the only two codecs they can support. This is going to be an issue because the auto attendant only supports g711ulaw i believe..So we are going to need some MTP resource...
Do you have any dsp or pvdm in your gateway...
ok.   I'm still a bit new to the SIP/Cisco Voice.  So before probing the DSP/PVDM requirements, would this cause a problem with assigning the SIP inbound to say an extension and not the Auto-Attendant?
I ran the following re DSP. Not sure if this helps with what is/isn't presnet.  I inherited the system.
dsp 1:
State: UP, firmware: 28.3.5
Max signal/voice channel: 16/16
Max credits: 240
num_of_sig_chnls_allocated: 14
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 225, reserved credits: 0
Signaling channels allocated: 14
Voice channels allocated: 1
Credits used (rounded-up): 15
Voice channels:
Ch01: voice port: 0/4/0, codec: g711ulaw, credits allocated: 15
dsp 2:
Max credits: 240
num_of_sig_chnls_allocated: 0
Group: FLEX_GROUP_CONF, complexity: CONFERENCE
Shared credits: 0, reserved credits: 240
Codec: CONF_G711, maximum participants: 32
Sessions per dsp: 2
0 DSP resource allocation failure
UC520London#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description : DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Maximum conference participants : 32
Codec Configuration: num_of_codecs:2
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    2   28.3.5   UP     N/A  FREE  conf    1      -         -         -
Total number of DSPFARM DSP channel(s) 2
Cisco UC520W-16U-4FXO-K9 (MPC8358) processor (revision 0x202) with 235520K/26624K bytes of memory.
Processor board ID FTX1236Z1BW
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
22 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
8 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
