07-30-2009 01:46 AM - edited 03-15-2019 07:08 PM
I would like to order UC520-16U-4FXO-K9 for 9 users but the system comes with 8 ports integrated poe.
1-Do i need to order another 8-port Cisco Catalyst Express 520 switch or does it come with UC520-16U-4FXO-K9 ?
2-Do the UC520-16U-4FXO-K9 comes with 4 analog fxs ports ?
Solved! Go to Solution.
07-30-2009 03:40 AM
No Idea on this. Since I am not sure I would not like to comment on this part about what I feel, becasue anything can happen :)
07-30-2009 04:56 AM
Hi Kolawole,
The WS-CE520-24TT-K9 is not a PoE switch so you may want something like the WS-CE520-24PC-K9 which does supply 24 PoE ports. The other consideration here is that the 520 Series of switches have been announced as End of Life :( There are recommended replacement switch part numbers in the attached doc;
End-of-Sale and End-of-Life Announcement for the Cisco Catalyst Express 520 Series Switches
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7238/end_of_life_notice_c51-544034.html
Hope this helps!
Rob
07-30-2009 02:41 AM
1) Yes you need an additional C520 switch "WS-CE520-8PC-K9".
2) This model comes with 4 FXO, 4FXS and one expansion slot.
-> Sushil
07-30-2009 03:14 AM
Could i use WS-CE520-24TT-K9 in replacement to WS-CE520-8PC-K9 ?
Thank you.
07-30-2009 03:40 AM
07-30-2009 04:56 AM
Hi Kolawole,
Hope this helps!
Rob
07-30-2009 06:11 AM
Thanks Rob
