UC520 Hunt group config
Brendon Bell
Hi there,
I want to configure a clients phone system so that if someone phones in on the main office number 03 3484943, if Jills phone is already on a call (extension 407) then the call will go to Melissa'a phone (extension 404).
Currently what is happening is that the phone call goes to voicemail.
I think this is the appropriate section of the config.
ephone-dn  20  dual-line
number 407 no-reg primary
pickup-group 1
label Christine
description Jill
name Jill
call-forward busy 8500
call-forward noan 8500 timeout 15
ephone-hunt 1 sequential
pilot 500
list 403, 411
final 8411
timeout 16, 20
no-reg pilot
present-call onhook-phone
ephone-hunt 2 peer
pilot 5501
list 403
final 8411
timeout 15
no-reg pilot
description Nicki Ext403
ephone-hunt 3 sequential
pilot 5502
list 407
final 8407
timeout 15
no-reg pilot
description Jill Ext407
ephone-hunt 4 peer
pilot 5503
list 404
final 8411
timeout 15
no-reg pilot
description Melissa Ext404
ephone-hunt 5 peer
pilot 5504
list 403, 404
final 8411
timeout 15, 15
no-reg pilot
description Operator Ext403 Ext404
ephone-hunt 6 peer
pilot 5505
list 404
final 8411
timeout 15
no-reg pilot
description Visa
ephone-hunt 10 longest-idle
pilot 5510
list 403, 404, 405, 406, 407
final 8411
timeout 15, 15, 15, 15, 15
no-reg pilot
statistics collect
Thanks in advance,
Brendon.
Rob Huffman
Hi Brendon,
I'll just add a note to the good info from my friend Paolo (+5 "P")
If the calls to the main number are routing to Jill via;
pilot 5502
list 407
final 8407
timeout 15
no-reg pilot
then you might try;
pilot 5502
list 407,404
final 8407
timeout 15,15
no-reg pilot
If the calls to the main number are not routing to Jill via the above
Hunt config, then you might try;
pickup-group 1
label Christine
description Jill
name Jill
call-forward busy 404
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
paolo bevilacqua
You will need to have an ephone-hunt with the correct list, as it seem you don't now.
Rob Huffman
Hi Brendon,
pilot 5502
list 407
final 8407
timeout 15
no-reg pilot
then you might try;
pilot 5502
list 407,404
final 8407
timeout 15,15
no-reg pilot
pickup-group 1
label Christine
description Jill
name Jill
Cheers!
Rob
-Springsteen
Thanks Rob for explaining what I just hinted!
Brendon Bell
Thanks guys for your responses
Now the customer has changed the requirement slightly.
Instead of the main incoming number 03 3484943 pointing to Ext 407 they want it to point into a hunt group where phones 404, 403 and 407 will ring sequentially.
Can I change this voice translation rule to pint directly into a hunt group?
voice translation-rule 550
rule 1 /^02825526848/ /550/
rule 2 /^033484943/ /407/      => change to rule 2 /^033484943/ /5502/
rule 3 /^0508668247/ /5510/
rule 10 /^.*/ /550/
Then hunt group 5502 should read:
pilot 5502
list 404, 407, 403
final 8500
timeout 15, 15, 15
no-reg pilot
description 03 3484943
This then makes me wonder what all this other junk does and if any of it can be removed / condensed or tidied up?
(Existing config)
pilot 500
list 403, 411
final 8411
timeout 16, 20
no-reg pilot
ephone-hunt 2 peer
pilot 5501
list 403
final 8411
timeout 15
no-reg pilot
pilot 5502
list 407
final 8407
timeout 15
no-reg pilot
ephone-hunt 4 peer
pilot 5503
list 404
final 8411
timeout 15
no-reg pilot
ephone-hunt 5 peer
pilot 5504
list 403, 404
final 8411
timeout 15, 15
no-reg pilot
ephone-hunt 6 peer
pilot 5505
list 404
final 8411
timeout 15
no-reg pilot
description Visa
pilot 5510
final 8411
no-reg pilot
statistics collect
Brendon.
