UC520 Incoming Calls
g.portellas
We have configured and began testing with our UC520. US style T1 PRI: Outbound calls work fine but no incoming calls to our trigger number are not being answered by the AutoAttendant, incoming callers get dial tone - they are able to then dial the AA or an extension fine.
Calls to any DID number are also being answered but they also get dial tone - I assume I have an issue with our Dial Peers but not sure where to look.
thanks
Rajesh Revuru
Level 4
Level 4
Can you post your config here?
Here it is, minus the ephones
Got it fixed - the telco was stripping off the first 6 digits - changed my rules and all works fine.
