uc520 radius alive and dead and enable password stopped working
sunilpatelmw
After adding our asa5505 to our network, the uc520 started to act up. I constantly get a radius alive and dead message on the terminal screen. Also the enable password stopped working. Any ideas?
8 Replies 8
paolo bevilacqua
Alive and dead actually meas dead, and that explains why you can't enable, as no backup method was configured.
You can check ASA config or remove it from the critical path.
Paolo, could you explain how to remove it from the critical path?
UC500 ---- RADIUS
And no ASA in the middle. Or no RADIUS at all.
I was able to change the password and conflicting ip.   How do I get rid of the radius server all together.  I don't need to use it.  It's disabled on CCA already.   Here are the messages that keep coming.
Nov 28 10:07:38.289 CST: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.172.5:1645,1813 is not responding.
000714: Nov 28 10:07:38.289 CST: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.172.5:1645,1813 is being marked alive.
000715: Nov 28 10:08:13.223 CST: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.172.5:1645,1813 is not responding.
000716: Nov 28 10:08:13.223 CST: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.172.5:1645,1813 is being marked alive.
Check config and remove using CLI.
Please remember to rate useful posts clicking on the stars below.
sunilpatelmw
Can you tell me what the actual Comand is on cli to remove radius all together. We are not using it.
Anyone?
sunilpatelmw
I would be willing to pay someone to remote into my system via log me in to take care of this.
