UC540 -> CME call forward noan to CUE disconnecting
Denis Morin
Here is my call flow
SCCP phone siteA calls an SCCP phone at site B over VPN tunnel. Site B phone has call-forward noan to CUE pilot.  This call get disconnected.
Also if I try the following
SCCP phone siteA calls an SCCP phone at site B over VPN tunnel. Site B phone has call-forward all to CUE pilot.  This call works and we get siteB's phone voicemail box.
If I look at the debug ccsip message I see that the CME is sending a Bye to the CUE.  Any ideas?
000683: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3399@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK18E1E
Remote-Party-ID: <sip:2399@10.1.10.2>;party=calling;screen=no;privacy=off
To: <sip:3399@10.1.10.1>
Date: Fri, 28 Aug 2015 23:55:02 GMT
Call-ID: 89266F1-4D1711E5-83AE974D-B0305AE3@10.1.10.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0143772361-1293357541-2208929613-2955959011
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1440806102
Contact: <sip:2399@10.1.10.2:5060>
Call-Info: <sip:10.1.10.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Diversion: <sip:3340@10.1.10.2>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Length: 0
000684: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
000685: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:3399@10.1.10.1>;tag=dsadf0df0d
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:3399@10.1.10.1:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 89266F1-4D1711E5-83AE974D-B0305AE3@10.1.10.2
000686: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 126
Content-Type: application/sdp
Call-Info: <sip:10.1.10.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 12347123 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20652 RTP/AVP 0
a=rtpmap:0 PCMU/8000
000687: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK19159E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 169
v=0
o=CiscoSystemsSIP-GW-UserAgent 1434 811 IN IP4 10.1.10.2
s=SIP Call
c=IN IP4 10.1.10.2
t=0 0
m=audio 16536 RTP/AVP 0
c=IN IP4 10.1.10.2
000688: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK1A1541
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=0
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0
Content-Length: 0
000689: //292/0891CAC983A9/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
6 Replies 6
Can you describe the topology? Do you have two CMEs @ sites A & B? How are they connected?
I have a UC540 at site A and a CME on a 2921 router at site B.  They are connected over the internet through a VPN tunnel.
Can you share the config of both?
Hi Denis.
A debug ccsip messages from both vg could also be useful
Carlo
Please rate all helpful posts "The more you help the more you learn"
Above is the debug ccsip messages results when going to voicemail.  The UC540 does not use sip to go to the cme.  My main concern is why call-forward all would work and not call-forward noan.  also If I call from SiteB to SiteA both call flow scenarios work fine.
Hi.
As Mohammed suggested, please share both configs.
Also an output of a debug voip diapeer inout would be useful
Carlo
