UC560 and no SIP
BrianErkC108
We have a Cisco UC560 and it has SIP and PSTN failover. We now just want PSTN as we canceled the SIP service. I have disabled the SIP service and created a PSTN trunk group, assigned the outgoing call handling to be PSTN only but when I make a call I get a fast busy signal.
not sure what steps to take from here.
5 Replies 5
Terry Cheema
You haven't posted sufficient information. Can you go to CLI and take the output of the below commands:
sh isdn status
sh run
Also post back what number you are trying to dial out.
-Terry
Please rate all helpful posts
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.01.21 17:18:07 =~=~=~=~=~=~=~=~=~=~=~=
login as: admin123
CCCisco Configuration Assistant. Version: 3.2 (3). Sat Oct 19 14:44:21 PDT 2013Using keyboard-interactive authentication.
Password:
Psynergy-UC560-01#sh run
Building configuration...
Current configuration : 49618 bytes
! Last configuration change at 17:18:13 PST Wed Jan 21 2015 by admin123
! NVRAM config last updated at 00:30:02 PST Wed Jan 21 2015
version 15.1
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname Psynergy-UC560-01
boot-start-marker
boot system flash:/uc500-advipservicesk9-mz.151-4.M4b
boot-end-marker
card type t1 0 3
 --More--         no logging queue-limit
logging buffered 1000000
no logging rate-limit
no logging console
no logging monitor
enable secret 5 $1$g8.4$TkS4KR2HcM55eL0AKpl6/0
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network localauthor local
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
 --More--         crypto pki token default removal timeout 0
crypto pki trustpoint TP-self-signed-3516316044
 enrollment selfsigned
 serial-number
 subject-name cn=IOS-Self-Signed-Certificate-3516316044
 revocation-check none
 rsakeypair my-rsa-keys
crypto pki certificate chain TP-self-signed-3516316044
 certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31363831 33373134 3335301E 170D3132 30373234 31383535
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36383133
  37313433 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AB5E 90E6F76D B6048434 47A6CA9A 180139FF 8D259E73 D3FF83F8 A5088F00
  3AA6C532 EAB1AD3B D4FFA41D C25B2398 E9EA02AC 43836379 285EBEF8 C9C5BBAE
  FE421BBA 7DEEBE1A 8616FE0E 86F2CF26 144E5408 97A23D82 79FCA621 ECAC7BF2
  6C071096 39A79520 67C1BF31 A53A6CAA CAB20A9B 98C36238 8392E5EF 54A7B0B4
  D3D90203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
  551D1104 09300782 05554335 3630301F 0603551D 23041830 16801453 53291CAD
 --More--           D8947FA3 44367ACA 80C9F8B3 F47C8230 1D060355 1D0E0416 04145353 291CADD8
  947FA344 367ACA80 C9F8B3F4 7C82300D 06092A86 4886F70D 01010405 00038181
  008D51E1 4718ECA6 E2D93863 FEE81AFA 796A1DE4 E784D4BF 416B432D 9F98F8E5
  69813952 08DD83F6 8BFB5A1E 542FD10B 25E8F621 1BFF24F4 D52E7DBC 5A76E4FA
  077ED663 45E04091 0C4D6FF4 A05A3196 B534ACC8 2EA7B96C C83C5662 F86AAAF8
  9918C22B 2A6862E6 2A8B6C5D 0384E92D 0F05C6F7 0D46F655 FEF0F74A E3BDDA67 49
   quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.145.1 192.168.145.10
ip dhcp excluded-address 192.168.145.11 192.168.145.254
ip dhcp pool phone
 network 10.1.1.0 255.255.255.0
 default-router 10.1.1.1
 option 150 ip 10.1.1.1
 --More--         ip domain name psynergynet.local
ip name-server 192.168.145.11
ip inspect WAAS flush-timeout 10
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_T1E1
 max-retry 5
 voice-class cause-code 1
 hunt-scheme sequential
 translation-profile outgoing PROFILE_ALL_T1E1
voice service voip
 ip address trusted list
 --More--           ipv4 12.194.0.0 255.255.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 sip
  bind control source-interface Vlan1
  bind media source-interface Vlan1
  g729 annexb-all
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice class custom-cptone CCAleavetone
 dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
 dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
 --More--         !
voice class cause-code 1
 no-circuit
voice translation-rule 4
 rule 1 /288/ /108/
voice translation-rule 5
 rule 1 /289/ /109/
voice translation-rule 6
 rule 1 /240/ /110/
voice translation-rule 7
 rule 1 /241/ /114/
voice translation-rule 8
 rule 1 /244/ /129/
voice translation-rule 9
 rule 1 /282/ /210/
 --More--         !
voice translation-rule 10
 rule 1 /285/ /211/
voice translation-rule 11
 rule 1 /287/ /212/
voice translation-rule 12
 rule 1 /284/ /213/
voice translation-rule 13
 rule 1 /283/ /300/
voice translation-rule 14
 rule 1 /286/ /310/
voice translation-rule 15
 rule 1 /245/ /315/
voice translation-rule 16
 rule 1 /290/ /410/
voice translation-rule 17
 rule 1 /246/ /503/
 --More--         !
voice translation-rule 18
 rule 1 /299/ /555/
voice translation-rule 19
 rule 1 /298/ /611/
voice translation-rule 20
 rule 1 /250/ /296/
voice translation-rule 21
 rule 1 /180/ /180/
voice translation-rule 22
 rule 1 /294/ /294/
voice translation-rule 23
 rule 1 /258/ /180/
voice translation-rule 24
 rule 1 /258/ /180/
voice translation-rule 25
 rule 1 /257/ /139/
 --More--         !
voice translation-rule 26
 rule 1 /256/ /138/
voice translation-rule 27
 rule 1 /255/ /425/
voice translation-rule 28
 rule 1 /256/ /125/
voice translation-rule 30
 rule 1 /257/ /305/
voice translation-rule 31
 rule 1 /253/ /139/
voice translation-rule 32
 rule 1 /254/ /138/
voice translation-rule 34
 rule 1 /6742180/ /180/
voice translation-rule 39
 rule 1 /4658240/ /110/
 --More--         !
voice translation-rule 40
 rule 1 /4658241/ /114/
voice translation-rule 41
 rule 1 /4658242/ /280/
voice translation-rule 42
 rule 1 /4658243/ /280/
voice translation-rule 43
 rule 1 /4658244/ /129/
voice translation-rule 44
 rule 1 /4658245/ /315/
voice translation-rule 45
 rule 1 /4658246/ /503/
voice translation-rule 46
 rule 1 /4658247/ /280/
voice translation-rule 47
 rule 1 /4658248/ /280/
 --More--         !
voice translation-rule 48
 rule 1 /4658249/ /280/
voice translation-rule 49
 rule 1 /4658250/ /296/
voice translation-rule 50
 rule 1 /4658251/ /280/
voice translation-rule 51
 rule 1 /4658252/ /280/
voice translation-rule 52
 rule 1 /4658253/ /139/
voice translation-rule 53
 rule 1 /4658254/ /138/
voice translation-rule 54
 rule 1 /4658255/ /425/
voice translation-rule 55
 rule 1 /4658256/ /125/
 --More--         !
voice translation-rule 56
 rule 1 /4658257/ /305/
voice translation-rule 57
 rule 1 /4658258/ /180/
voice translation-rule 58
 rule 1 /4658259/ /280/
voice translation-rule 59
 rule 1 /4658280/ /280/
voice translation-rule 60
 rule 1 /4658281/ /101/
voice translation-rule 61
 rule 1 /4658282/ /210/
voice translation-rule 62
 rule 1 /4658283/ /300/
voice translation-rule 63
 rule 1 /4658284/ /213/
 --More--         !
voice translation-rule 64
 rule 1 /4658285/ /211/
voice translation-rule 65
 rule 1 /4658286/ /310/
voice translation-rule 66
 rule 1 /4658287/ /212/
voice translation-rule 67
 rule 1 /4658288/ /108/
voice translation-rule 68
 rule 1 /4658289/ /109/
voice translation-rule 69
 rule 1 /4658290/ /410/
voice translation-rule 70
 rule 1 /4658291/ /280/
voice translation-rule 71
 rule 1 /4658292/ /280/
 --More--         !
voice translation-rule 72
 rule 1 /4658293/ /480/
voice translation-rule 73
 rule 1 /4658294/ /802/
voice translation-rule 74
 rule 1 /4658295/ /201/
voice translation-rule 75
 rule 1 /4658296/ /200/
voice translation-rule 76
 rule 1 /4658297/ /400/
voice translation-rule 77
 rule 1 /4658298/ /611/
voice translation-rule 78
 rule 1 /4658299/ /555/
voice translation-rule 79
 rule 1 /4658460/ /280/
 --More--         !
voice translation-rule 80
 rule 1 /8316742180/ /180/
voice translation-rule 81
 rule 1 /8312234119/ /180/
voice translation-rule 82
 rule 1 /8312635000/ /180/
voice translation-rule 83
 rule 1 /8318565091/ /180/
voice translation-rule 84
 rule 1 /8318565093/ /125/
voice translation-rule 85
 rule 1 /8318565094/ /180/
voice translation-rule 86
 rule 1 /8318565328/ /180/
voice translation-rule 87
 rule 1 /4089610005/ /801/
 --More--         !
voice translation-rule 89
 rule 1 /5594293006/ /280/
voice translation-rule 90
 rule 1 /4089642097/ /280/
voice translation-rule 91
 rule 1 /9610005/ /801/
voice translation-rule 96
 rule 1 /296/ /100/
voice translation-rule 104
 rule 1 /293/ /480/
voice translation-rule 107
 rule 1 /012/ /212/
voice translation-rule 108
 rule 1 /297/ /400/
voice translation-rule 110
 rule 1 /281/ /101/
 --More--         !
voice translation-rule 116
 rule 1 /280/ /280/
voice translation-rule 119
 rule 1 /295/ /201/
voice translation-rule 122
 rule 15 /^...$/ /4084658280/
voice translation-rule 889
 rule 1 /^8\(.*\)/ /\1/
voice translation-rule 890
 rule 1 /^.*/ /4084658280/
voice translation-rule 999
 rule 1 reject /109/
voice translation-rule 1000
 rule 1 /.*/ //
 rule 2 /5594293006/ /280/
voice translation-rule 1111
 --More--         !
voice translation-rule 1112
 rule 1 /^914084195290$/ //
 rule 2 /^914088226000$/ //
 rule 3 /^94195290$/ //
 rule 4 /^98226000$/ //
 rule 5 /^94084195290$/ //
 rule 6 /^94088226000$/ //
 rule 7 /^9\([2-9].........$\)/ /\1/
 rule 8 /^91\([2-9].........$\)/ /\1/
 rule 14 /^9\([2-9]......$\)/ /408\1/
 rule 15 /^9/ //
voice translation-rule 2000
 rule 1 /294/ /294/
voice translation-rule 2001
voice translation-rule 2002
 rule 1 /^7/ //
voice translation-rule 2222
 rule 1 /^91900......./ //
 rule 2 /^91976......./ //
 --More--         !
voice translation-rule 2223
 rule 3 /^919165581784/ //
 rule 4 /^919164647547/ //
 rule 5 /^919165528700/ //
 rule 6 /^918002369747/ //
 rule 7 /^919166572592/ //
 rule 8 /^917075885026/ //
 rule 9 /^914083242112/ //
 rule 10 /^93242112/ //
voice translation-rule 5001
 rule 1 /.*/ /5594293006/
voice translation-rule 5002
 rule 1 /.*/ /4089642097/
voice translation-rule 5004
 rule 1 /.*/ /4089610005/
voice translation-rule 5342
 --More--          rule 2 /4084658240/ /110/
 rule 3 /4084658241/ /114/
 rule 4 /4084658242/ /280/
 rule 5 /4084658243/ /280/
 rule 6 /4084658244/ /129/
 rule 7 /4084658245/ /315/
 rule 8 /4084658246/ /503/
 rule 9 /4084658247/ /280/
 rule 10 /4084658248/ /280/
 rule 11 /4084658249/ /280/
 rule 12 /4084658250/ /296/
 rule 13 /4084658251/ /280/
 rule 14 /4084658252/ /280/
 rule 15 /4084658253/ /139/
 rule 16 /4084658254/ /138/
 rule 17 /4084658255/ /425/
 rule 18 /4084658256/ /125/
 rule 19 /4084658257/ /305/
 rule 20 /4084658258/ /180/
 rule 21 /4084658259/ /280/
 rule 22 /4084658280/ /280/
 rule 23 /4084658281/ /101/
 rule 24 /4084658282/ /210/
 rule 25 /4084658283/ /300/
 --More--          rule 26 /4084658284/ /213/
 rule 27 /4084658285/ /211/
 rule 28 /4084658286/ /310/
 rule 29 /4084658287/ /212/
 rule 30 /4084658288/ /108/
 rule 31 /4084658289/ /109/
 rule 32 /4084658290/ /410/
 rule 33 /4084658291/ /280/
 rule 34 /4084658292/ /280/
 rule 35 /4084658293/ /480/
 rule 36 /4084658294/ /802/
 rule 37 /4084658295/ /201/
 rule 38 /4084658296/ /200/
 rule 39 /4084658297/ /400/
 rule 40 /4084658298/ /611/
 rule 41 /4084658299/ /555/
 rule 42 /4084658460/ /280/
 rule 44 /8312234119/ /180/
 rule 45 /8312635000/ /180/
 rule 46 /8318565091/ /180/
 rule 47 /8318565093/ /125/
 rule 48 /8318565094/ /180/
 rule 49 /8318565328/ /180/
 rule 50 /4089610005/ /801/
 --More--          rule 51 /5594293006/ /280/
 rule 52 /4089642097/ /280/
 rule 100 /........../ /290/
voice translation-profile 0005voip_Called_87
 translate calling 3265
 translate called 87
voice translation-profile 101_Called_110
 translate called 110
voice translation-profile 108_Called_4
 translate called 4
voice translation-profile 109_Called_5
 translate called 5
voice translation-profile 110_Called_6
 translate called 6
voice translation-profile 114_Called_7
 translate called 7
 --More--         voice translation-profile 121_Called_107
 translate called 107
voice translation-profile 129_Called_8
 translate called 8
voice translation-profile 200_Called_96
 translate called 96
voice translation-profile 201_Called_119
 translate called 119
voice translation-profile 2097voip_Called_90
 translate calling 5002
 translate called 90
voice translation-profile 210_Called_9
 translate called 9
voice translation-profile 211_Called_10
 translate called 10
voice translation-profile 212_Called_11
 translate called 11
 --More--         !
voice translation-profile 213_Called_12
 translate called 12
voice translation-profile 2180voip_Called_34
 translate called 34
voice translation-profile 2234119_Called_81
 translate called 81
voice translation-profile 3006voip_Called_89
 translate called 89
voice translation-profile 300_Called_13
 translate called 13
voice translation-profile 310_Called_14
 translate called 14
voice translation-profile 315_Called_15
 translate called 15
 --More--         !
voice translation-profile 400_Called_108
 translate called 108
voice translation-profile 410_Called_16
 translate called 16
voice translation-profile 480_Called_104
 translate called 104
voice translation-profile 503_Called_17
 translate called 17
voice translation-profile 5091voip_Called_83
 translate called 83
voice translation-profile 5093voip_Called_84
 translate called 84
voice translation-profile 5094voip_Called_85
 translate called 85
 --More--         !
voice translation-profile 5328voip_Called_86
 translate called 86
voice translation-profile 555_Called_18
 translate called 18
voice translation-profile 611_Called_19
 translate called 19
voice translation-profile 6742180voip_Called_80
 translate called 80
voice translation-profile 8241voip_Called_40
 translate called 40
voice translation-profile 8242voip_Called_41
 translate called 41
voice translation-profile 8243voip_Called_42
 --More--          translate calling 3265
 translate called 42
voice translation-profile 8244voip_Called_43
 translate called 43
voice translation-profile 8245voip_Called_44
 translate called 44
voice translation-profile 8246voip_Called_45
 translate called 45
voice translation-profile 8247voip_Called_46
 translate called 46
voice translation-profile 8248voip_Called_47
 translate called 47
voice translation-profile 8249voip_Called_48
 translate called 48
voice translation-profile 8250voip_Called_49
 translate called 49
voice translation-profile 8251voip_Called_50
 translate called 50
voice translation-profile 8252voip_Called_51
 translate called 51
voice translation-profile 8253voip_Called_52
 translate called 52
voice translation-profile 8254voip_Called_53
 translate called 53
voice translation-profile 8255voip_Called_54
 translate called 54
voice translation-profile 8256voip_Called_55
 translate called 55
voice translation-profile 8257voip_Called_56
 translate called 56
voice translation-profile 8258voip_Called_57
 translate called 57
voice translation-profile 8259voip_Called_58
 translate called 58
voice translation-profile 8280voip_Called_59
 translate called 59
voice translation-profile 8281voip_Called_60
 translate called 60
voice translation-profile 8282voip_Called_61
 translate called 61
voice translation-profile 8283voip_Called_62
 translate called 62
voice translation-profile 8284voip_Called_63
 translate called 63
voice translation-profile 8285voip_Called_64
 translate called 64
voice translation-profile 8286voip_Called_65
 translate called 65
voice translation-profile 8287voip_Called_66
 translate called 66
voice translation-profile 8288voip_Called_67
 translate called 67
voice translation-profile 8289voip_Called_68
 translate called 68
voice translation-profile 8290voip_Called_69
 translate called 69
voice translation-profile 8291voip_Called_70
 translate called 70
voice translation-profile 8292voip_Called_71
 translate called 71
voice translation-profile 8293voip_Called_72
 translate called 72
voice translation-profile 8294voip_Called_73
 translate called 73
voice translation-profile 8295voip_Called_74
 translate called 74
voice translation-profile 8296voip_Called_75
 translate called 75
voice translation-profile 8297voip_Called_76
 translate called 76
voice translation-profile 8298voip_Called_77
 translate called 77
voice translation-profile 8299voip_Called_78
 translate called 78
voice translation-profile 8460voip_Called_79
 translate called 79
voice translation-profile 9610005voip_Called
 translate called 91
voice translation-profile ADick_Called_28
 translate called 28
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
 translate calling 1111
voice translation-profile CVClient1_Called_31
 translate called 31
voice translation-profile CVClient2_Called_32
 translate called 32
voice translation-profile CVClinic_Called_30
 --More--          translate called 30
voice translation-profile CallBlocking
 translate called 2222
voice translation-profile Conference_Called_20
 translate called 20
voice translation-profile FAX_POTS_Outgoing
 translate calling 890
 translate called 889
voice translation-profile Fresno_Outgoing
 translate calling 5001
 translate called 1112
voice translation-profile MainElm_Called_21
 translate called 21
voice translation-profile MainElm_voip_Called_82
 translate called 82
voice translation-profile MainHale_Called_116
 --More--          translate called 116
voice translation-profile MainSip_Called_39
 translate called 39
voice translation-profile OUTGOING_TRANSLATION_PROFILE
voice translation-profile PROFILE_ALL_T1E1
 translate calling 122
voice translation-profile REJECT
 translate calling 999
voice translation-profile SanJose1_Outgoing
voice translation-profile SanJose2_Outgoing
 translate calling 5004
voice translation-profile TempMainElm_Called_24
 --More--          translate called 24
voice translation-profile TinaArmer_Called_27
 translate called 27
voice translation-profile UserCallBlocking
 translate called 2223
voice translation-profile VM_Profile
 translate called 2000
voice translation-profile Voicemail_Called_22
 translate called 22
voice translation-profile XFER_TO_VM_PROFILE
 translate redirect-called 2002
voice translation-profile emvs_in
 translate called 5342
voice translation-profile nondialable
 translate called 1000
 --More--         voice-card 0
 dspfarm
 dsp services dspfarm
license udi pid UC560-T1E1-K9 sn FGL153810JZ
archive
 log config
  logging enable
  logging size 600
  hidekeys
username tmgroot privilege 15 secret 4 FJKN3GzOa1oAtChSS9UOt09isTKIFes6uXg5T9wQ2eg
username admin123 privilege 15 secret 5 $1$OH2C$qFrgmigFY1pv9qQpehV9U/
username tmg privilege 15 secret 5 $1$C.LF$Z48pmnPrfDAp3yLoftoKz.
username cisco privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
controller T1 0/3/0
 shutdown
ip tftp source-interface Vlan100
 --More--         class-map match-any media
 match  dscp ef
class-map match-any signaling
 match  dscp cs3
 match  dscp af31
policy-map queue
 class signaling
  bandwidth percent 5
 class media
  priority percent 50
 class class-default
  fair-queue
policy-map shape
 class class-default
  shape average 2880000
  service-policy queue
crypto isakmp policy 1
 encr aes 256
 authentication pre-share
 --More--          group 2
crypto isakmp policy 3
 encr 3des
 group 2
crypto isakmp client configuration group vpnclient
 key supes-secres
 domain psynergyvpn.com
 pool dynpool
 acl ALLOWED_LANS
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
 set transform-set myset
 reverse-route
crypto map clientmap client authentication list default
crypto map clientmap isakmp authorization list localauthor
crypto map clientmap client configuration address respond
 --More--         crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface GigabitEthernet0/0
 bandwidth 2880
 ip address 12.149.156.227 255.255.255.240 secondary
 ip address 12.149.156.226 255.255.255.240
 ip access-group ipFlex-in in
 load-interval 30
 shutdown
 duplex auto
 speed auto
 no cdp enable
 service-policy output shape
interface Integrated-Service-Engine0/0
 description cue is initialized with default IMAP group
 ip unnumbered Vlan90
 service-module ip address 10.1.10.1 255.255.255.252
 service-module ip default-gateway 10.1.10.2
 --More--         !
interface GigabitEthernet0/1/0
 switchport mode trunk
 no ip address
 macro description cisco-switch
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 description Interface used to communicate with integrated service module
 switchport access vlan 90
 no ip address
interface Vlan1
 --More--          ip address 192.168.145.5 255.255.255.0
interface Vlan90
 ip address 10.1.10.2 255.255.255.252
interface Vlan100
 ip address 10.1.1.1 255.255.255.0
ip local pool EZVPN_POOL_1 10.80.4.2 10.80.4.12
ip local pool dynpool 10.34.251.10 10.34.251.20
ip default-gateway 192.168.145.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 192.168.145.1
ip route 10.1.10.1 255.255.255.255 Vlan90
ip access-list extended ALLOWED_LANS
 permit ip 10.1.1.0 0.0.0.255 10.34.251.0 0.0.0.255
 permit ip 10.1.10.0 0.0.0.255 10.34.251.0 0.0.0.255
 permit ip 192.168.145.0 0.0.0.255 10.34.251.0 0.0.0.255
 --More--          permit ip 192.168.1.0 0.0.0.255 10.34.251.0 0.0.0.255
 permit ip 192.168.2.0 0.0.0.255 10.34.251.0 0.0.0.255
ip access-list extended SIP_GROUP_IN
 permit ip 72.18.224.224 0.0.0.31 any
 deny   ip any any log
ip access-list extended ipFlex-in
 permit icmp any any unreachable
 permit icmp any any echo-reply
 permit tcp host 75.149.53.25 host 12.149.156.227 eq 22
 permit tcp host 75.149.53.25 host 68.189.87.76 eq 22
 permit ip host 75.149.53.25 any
 permit udp host 75.149.53.25 host 12.149.156.227 eq isakmp
 permit udp host 75.149.53.25 host 12.149.156.227 eq non500-isakmp
 permit ip host 50.193.27.213 any
 permit udp 12.194.0.0 0.0.255.255 host 12.149.156.226 gt 1023
 permit ip 12.194.0.0 0.0.255.255 any
 permit icmp any host 12.149.156.227 echo-reply
 permit icmp any host 12.149.156.227 time-exceeded
 permit icmp any host 12.149.156.227 unreachable
 deny   ip any any log
kron occurrence backup at 0:30 recurring
 policy-list save-config
 --More--         kron policy-list save-config
 cli write
logging 192.168.145.8
access-list 23 permit 75.149.53.25
access-list 23 permit 10.1.1.0 0.0.0.255
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.145.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
tftp-server flash:phones/30x/spa50x-30x-7-4-6.bin alias spa50x-30x-7-4-6.bin
tftp-server flash:/phones/7921/GUI-1.4.1SR1.SBN alias GUI-1.4.1SR1.SBN
tftp-server flash:/phones/7921/SYS-1.4.1SR1.SBN alias SYS-1.4.1SR1.SBN
tftp-server flash:/phones/7921/APPS-1.4.1SR1.SBN alias APPS-1.4.1SR1.SBN
tftp-server flash:/phones/7921/TNUXR-1.4.1SR1.SBN alias TNUXR-1.4.1SR1.SBN
tftp-server flash:/phones/7921/TNUX-1.4.1SR1.SBN alias TNUX-1.4.1SR1.SBN
tftp-server flash:/phones/7921/CP7921G-1.4.1SR1.LOADS alias CP7921G-1.4.1SR1.LOADS
 --More--         tftp-server flash:/phones/7921/WLAN-1.4.1SR1.SBN alias WLAN-1.4.1SR1.SBN
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/320x212x12/List.xml.BAK alias Desktops/320x212x12/List.xml.BAK
tftp-server flash:/Desktops/320x212x16/List.xml alias Desktops/320x212x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml.BAK alias Desktops/320x212x16/List.xml.BAK
tftp-server flash:/Desktops/320x216x16/List.xml alias Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x216x16/List.xml.BAK alias Desktops/320x216x16/List.xml.BAK
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
 --More--         tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
 --More--         tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
 --More--         tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/ringtones/RingList.xml.BAK alias RingList.xml.BAK
tftp-server flash:/ringtones/DistinctiveRingList.xml.BAK alias DistinctiveRingList.xml.BAK
control-plane
voice-port 0/0/0
 timeouts interdigit 3
 timeouts ringing infinity
 station-id name Residential
 caller-id enable
voice-port 0/0/1
 station-id name Residential2
 --More--          caller-id enable
voice-port 0/0/2
 station-id name Residential3
 caller-id enable
voice-port 0/0/3
 station-id name Residential4
 caller-id enable
voice-port 0/1/0
 connection plar opx 112
 description Configured by CCA 4FXO-0/1/0-Custom-OP
 caller-id enable
voice-port 0/1/1
 trunk-group ALL_T1E1 64
 connection plar opx 801
 shutdown
 description Configured by CCA 4 FXO-0/1/1-Custom-AA
 caller-id enable
 --More--         voice-port 0/1/2
 shutdown
 description Configured by CCA 4 FXO-0/1/2-Custom-AA
 caller-id enable
voice-port 0/1/3
 shutdown
 description Configured by CCA 4 FXO-0/1/3-Custom-AA
 caller-id enable
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control -15
 description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 --More--          associate profile 1 register confprof1
dspfarm profile 1 conference
 description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
 codec g711ulaw
 codec g711alaw
 maximum conference-participants 16
 maximum sessions 8
 conference-join custom-cptone CCAjointone
 conference-leave custom-cptone CCAleavetone
 associate application SCCP
dial-peer cor custom
 name internal
 name local
 name local-plus
 name international
 name national
 name national-plus
 name emergency
 name toll-free
 name non-emergency
 name 7local
 --More--         !
dial-peer cor list call-internal
 member internal
dial-peer cor list call-local
 member local
dial-peer cor list call-local-plus
 member local-plus
dial-peer cor list call-national
 member national
dial-peer cor list call-national-plus
 member national-plus
dial-peer cor list call-international
 member international
dial-peer cor list call-emergency
 member emergency
dial-peer cor list call-toll-free
 member toll-free
 --More--         !
dial-peer cor list user-internal
 member internal
 member emergency
dial-peer cor list user-local
 member internal
 member local
 member emergency
 member toll-free
 member 7local
dial-peer cor list user-local-plus
 member internal
 member local
 member local-plus
 member emergency
 member toll-free
 member 7local
dial-peer cor list user-national
 member internal
 member local
 member local-plus
 --More--          member national
 member emergency
 member toll-free
 member 7local
dial-peer cor list user-national-plus
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
 member 7local
dial-peer cor list user-international
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
 --More--          member 7local
dial-peer cor list call-non-emergency
 member non-emergency
dial-peer cor list user-non-emergency
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
 member 7local
dial-peer cor list call-7local
 member 7local
dial-peer cor list user-7local
 member toll-free
 member 7local
 --More--         dial-peer voice 1 pots
 service stcapp
 port 0/0/0
dial-peer voice 2 pots
 service stcapp
 port 0/0/1
dial-peer voice 4 pots
 service stcapp
 port 0/0/3
dial-peer voice 5 pots
 description ** MOH Port **
 destination-pattern ABC
 port 0/4/0
 no sip-register
dial-peer voice 50 pots
 description ** incoming dial peer **
 incoming called-number ^AAAA$
 port 0/1/0
dial-peer voice 51 pots
 --More--          description ** incoming dial peer **
 port 0/1/1
dial-peer voice 52 pots
 port 0/1/2
dial-peer voice 53 pots
 port 0/1/3
dial-peer voice 54 pots
 description ** FXO pots dial-peer **
 destination-pattern A0
 port 0/1/0
 no sip-register
dial-peer voice 55 pots
 corlist outgoing call-international
 description **CCA*North American*International**
 translation-profile outgoing FAX_POTS_Outgoing
 --More--          shutdown
 destination-pattern 9011T
 port 0/1/1
 forward-digits all
 no sip-register
dial-peer voice 56 pots
 destination-pattern A2
 port 0/1/2
 no sip-register
dial-peer voice 57 pots
 destination-pattern A3
 port 0/1/3
 no sip-register
dial-peer voice 2000 voip
 description ** cue voicemail pilot number **
 translation-profile outgoing XFER_TO_VM_PROFILE
 destination-pattern 294
 b2bua
 session protocol sipv2
 --More--          session target ipv4:10.1.10.1
 no voice-class sip outbound-proxy
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2012 voip
 description ** cue prompt manager number **
 translation-profile outgoing PSTN_CallForwarding
 destination-pattern 802
 b2bua
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 3 pots
 service stcapp
 port 0/0/2
dial-peer voice 2001 voip
 description ** cue auto attendant number **
 --More--          translation-profile outgoing PSTN_CallForwarding
 destination-pattern 801
 b2bua
 voice-class sip outbound-proxy ipv4:10.1.10.1
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2004 voip
 destination-pattern 856
 b2bua
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 6207 voip
 translation-profile outgoing PSTN_Outgoing
 --More--          destination-pattern 9[2-9]......$
 rtp payload-type cisco-codec-fax-ind 98
 session target sip-server
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 fax rate 14400
 fax protocol none
 ip qos dscp ef signaling
 no vad
dial-peer voice 6208 voip
 destination-pattern 9[2-9].........$
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
 fax protocol none
 --More--          no vad
dial-peer voice 6209 voip
 destination-pattern 91[2-9].........$
 dtmf-relay rtp-nte
 codec g711ulaw
 fax rate 14400
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
 no vad
dial-peer voice 1990 voip
 description ** Incoming call from SIP trunk (eMVS) **
 translation-profile incoming emvs_in
 incoming called-number 4084658281
 --More--          voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 codec g711ulaw
 fax rate 14400
 fax protocol none
 no vad
dial-peer voice 1991 voip
 description ** IB Fax to 408-465-8295 (eMVS) **
 incoming called-number 4084658295
 dtmf-relay rtp-nte
 codec g711ulaw
 fax rate 14400
 fax protocol none
 no vad
dial-peer voice 1992 voip
 --More--          description ** IB Fax to 408-465-8293 (eMVS) **
 incoming called-number 4084658293
 dtmf-relay rtp-nte
 codec g711ulaw
 fax rate 14400
 fax protocol none
 no vad
dial-peer voice 6 pots
 description "catch all dial peer for BRI/PRI"
 translation-profile incoming nondialable
 incoming called-number .%
 direct-inward-dial
dial-peer voice 73 pots
 trunkgroup ALL_T1E1
 corlist outgoing call-local
 description **CCA*North American*7-Digit Local**
 --More--          translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
 preference 5
 forward-digits all
 no sip-register
dial-peer voice 64 pots
 trunkgroup ALL_T1E1
 description **CCA*North American*Service Numbers**
 preference 5
 destination-pattern 9[2578]11
 forward-digits all
 no sip-register
dial-peer voice 65 pots
 trunkgroup ALL_T1E1
 corlist outgoing call-local-plus
 description **CCA*North American*Emergency**
 preference 5
 destination-pattern 9911
 forward-digits all
 --More--          no sip-register
dial-peer voice 58 pots
 trunkgroup ALL_T1E1
 preference 5
 forward-digits all
 no sip-register
dial-peer voice 59 pots
 trunkgroup ALL_T1E1
 preference 5
 forward-digits all
 no sip-register
dial-peer voice 60 pots
 trunkgroup ALL_T1E1
 --More--          corlist outgoing call-local
 preference 5
 forward-digits all
 no sip-register
dial-peer voice 61 pots
 trunkgroup ALL_T1E1
 preference 5
 forward-digits all
 no sip-register
dial-peer voice 62 pots
 trunkgroup ALL_T1E1
 corlist outgoing call-national-plus
 description **CCA*North American*Info Services**
 preference 5
 --More--          destination-pattern 9[46]11
 forward-digits all
 no sip-register
dial-peer voice 63 pots
 trunkgroup ALL_T1E1
 description **CCA*North American*Long Distance**
 preference 5
 destination-pattern 91[2-9]..[2-9]......
 forward-digits all
 no sip-register
dial-peer voice 66 pots
 destination-pattern A1
 port 0/1/1
 no sip-register
telephony-service
 --More--          sdspfarm conference mute-on 111 mute-off 222
 sdspfarm units 5
 sdspfarm tag 1 confprof1
 conference hardware
 no auto-reg-ephone
 authentication credential tmgroot w1ll0w
 fxo hook-flash
 max-ephones 114
 max-dn 600
 ip source-address 10.1.1.1 port 2000
 max-redirect 20
 auto assign 1 to 1 type bri
 calling-number initiator
 service phone videoCapability 0
 service phone ehookenable 1
 service phone displayIdleTimeout 00:01
 service phone displayOnWhenIncomingCall 1
 service phone daysDisplayNotActive 1,7
 service phone displayOnTime 05:45
 service phone displayOnDuration 11:15
 service dnis overlay
 service dnis dir-lookup
 service dss
 timeouts interdigit 5
 --More--          system message Psynergy
 url services http://10.1.10.1/voiceview/common/login.do
 url authentication http://10.1.10.2/CCMCIP/authenticate.asp
 cnf-file perphone
 load 7921 CP7921G-1.4.1SR1
 load 521G-524G cp524g-8-1-17
 load 501G spa50x-30x-7-4-9c
 load 502G spa50x-30x-7-4-9c
 load 504G spa50x-30x-7-4-9c
 load 508G spa50x-30x-7-4-9c
 load 509G spa50x-30x-7-4-9c
 load 301 spa50x-30x-7-4-9c
 load 303 spa50x-30x-7-4-9c
 time-zone 5
 keepalive 60
 live-record 803
 voicemail 294
 max-conferences 8 gain -6
 call-forward pattern .T
 moh flash:/media/music-on-hold.au
 multicast moh 239.10.16.16 port 2000
 web admin system name cisco secret 5 $1$RHdk$Iln5oIVKS60mrMyFIfBfd0
 dn-webedit
 time-webedit
 --More--          transfer-system full-consult dss
 transfer-pattern 9.T
 transfer-pattern .T
 transfer-pattern 7... blind
 secondary-dialtone 9
 night-service code *293
 night-service day Sun 09:00 08:00
 night-service day Mon 17:00 08:00
 night-service day Tue 17:00 08:00
 night-service day Wed 17:00 08:00
 night-service day Thu 17:00 08:00
 night-service day Fri 17:00 08:00
 night-service day Sat 09:00 08:00
 night-service date Jul 4 00:01 23:59
 night-service date Sep 5 00:01 23:59
 night-service date Nov 22 00:01 23:59
 night-service date Dec 25 00:01 23:59
 night-service date Jan 1 00:01 23:59
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
 softkeys remote-in-use  Newcall
 --More--          softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
 softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
 softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
 button-layout 7931 2
ephone-template  16
ephone-template  17
 softkeys remote-in-use  CBarge Newcall
ephone-template  18
 --More--          softkeys remote-in-use  CBarge Newcall
ephone-dn  9
 number BCD no-reg primary
 description MoH
 moh out-call ABC
ephone-dn  11  dual-line
 number 108 no-reg both
 label 108 Client
 description Client PhoneOne108
 name Client PhoneOne
 allow watch
 corlist incoming user-7local
 translation-profile incoming UserCallBlocking
ephone-dn  12  dual-line
 --More--          number 109 no-reg both
 label 109 Client
 description Client PhoneTwo109
 name Client PhoneTwo
 allow watch
ephone-dn  17  dual-line
 number 112 no-reg primary
 label 112 Small Conference
 description 112 Small Conference
 name Small Conf
ephone-dn  19  dual-line
 number 138 no-reg both
 label 138 Client
 allow watch
 --More--         !
ephone-dn  20  dual-line
 number 139 no-reg both
 label 139 Client
 allow watch
ephone-dn  45  dual-line
 number 401 no-reg primary
 label 401 Vienna
 description Vienna Dumlao
 name Vienna Dumlao
 allow watch
ephone-dn  48  dual-line
 number 504 no-reg primary
 label 504
 description Lynda Kaufmann
 --More--          name Lynda Kaufmann
 call-forward busy 294
 call-forward noan 294 timeout 20
ephone-dn  49  dual-line
 number 316 no-reg primary
 label 316 Dolan Fielding
 description Dolan Fielding
 name Dolan Fielding
 allow watch
 call-forward noan 294 timeout 15
 corlist incoming user-national
 translation-profile incoming CallBlocking
ephone-dn  577
 number 803 no-reg primary
 name LiveRecord
 call-forward all 294
ephone-dn  578
 --More--          number 253 no-reg primary
 park-slot
 label Park Slot 253
ephone-dn  579
 number 252 no-reg primary
 park-slot
 label Park Slot 252
ephone-dn  580
 number 251 no-reg primary
 park-slot
 label Park Slot 251
ephone-dn  581
 number 250 no-reg primary
 park-slot
 label Park Slot 250
ephone-dn  582  octo-line
 --More--          number 296 no-reg primary
 conference meetme
 preference 1
ephone-dn  583  octo-line
 conference meetme
 no huntstop
ephone-dn  584  octo-line
 number C007 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  585  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  586  octo-line
 --More--          number C006 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  587  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  588  octo-line
 number C005 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  589  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  590  octo-line
 --More--          number C004 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  591  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  592  octo-line
 number C003 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  593  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  594  octo-line
 --More--          number C002 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  595  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  596  octo-line
 number C001 no-reg primary
 conference ad-hoc
 preference 1
ephone-dn  597  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  598
 --More--          number 7... no-reg primary
 description ***CCA XFER TO VM EXTENSION***
ephone-dn  599
 number A801... no-reg primary
 mwi off
ephone-dn  600
 number A800... no-reg primary
 mwi on
ephone  1
 device-security-mode none
 mac-address 0F1A.9926.2000
 max-calls-per-button 2
 type anl
ephone  2
 --More--          device-security-mode none
 mac-address 0F1A.9926.2001
 type anl
ephone  3
 mac-address 0F1A.9926.2002
 type anl
ephone  4
 mac-address 0F1A.9926.2003
 type anl
ephone  6
 --More--          conference drop-mode creator
 conference admin
 description 108 Client PhoneOne
 video
 mac-address 5475.D02A.BDB3
 ephone-template 15
 username "cphoneone" password 1234
 presence call-list
 type 301
 missed-calls all
 button  1:11
ephone  7
 conference admin
 description 109 Client PhoneTwo
 video
 mac-address 5475.D02A.BDB0
 ephone-template 15
 --More--          max-calls-per-button 2
 username "cphonetwo" password 1234
 presence call-list
 type 301
 missed-calls all
 button  1:12
ephone  14
 conference admin
 description 138 Client PhoneOne
 video
 mac-address 5475.D02A.BD9B
 ephone-template 15
 username "cvistaphoneone" password 1234
 presence call-list
 mtp
 type 301
 missed-calls all
 button  1:19
 --More--         !
ephone  15
 conference admin
 description 139 Client PhoneTwo
 video
 mac-address D0D0.FD0B.A0FA
 ephone-template 15
 username "cvistaphonetwo" password 1234
 presence call-list
 mtp
 type 301
 missed-calls all
 button  1:20
ephone  39
 conference admin
 description 401 Vienna Dumlao
 video
 mac-address 8843.E132.9544
 ephone-template 15
 max-calls-per-button 4
 username "vdumlao" password 1234
 presence call-list
 type 7921
 missed-calls all
 button  1:45
ephone  40
 conference admin
 mac-address 5475.D02A.BDAC
 ephone-template 15
 username "sconference" password 1234
 presence call-list
 --More--          type 301
 button  1:17
ephone  200
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCCCisco Configuration Assistant. Version: 3.2 (3). Sat Oct 19 14:44:21 PDT 2013^C
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 speed 115200
line vty 0 4
 --More--          transport input ssh
line vty 5 15
 transport input telnet ssh
line vty 16 100
 transport input all
ntp master
ntp server 65.55.56.206 prefer
end
the command sh isdn didn't work.
Im just trying to dial my cell phone which is in the same area code as the UC.
Terry Cheema
Are you using FXO as your T1 controller is shutdown
controller T1 0/3/0
 shutdown
And the trunk group you have created is assigned only to one port which is in shutdown and your dial-peer (73, 64, etc) are pointing to this trunk group:
So unshut this port and try again or point your dial-peers to the working ports.
voice-port 0/0/0
 caller-id enable
voice-port 0/0/1
 caller-id enable
voice-port 0/0/2
 caller-id enable
voice-port 0/0/3
 caller-id enable
voice-port 0/1/0
 caller-id enable
voice-port 0/1/1
 shutdown
 caller-id enable
voice-port 0/1/2
 shutdown
 caller-id enable
voice-port 0/1/3
 shutdown
 caller-id enable
voice-port 0/4/0
 auto-cut-through
 signal immediate
-Terry
Please rate helpful posts
Hi, Terry. After fiddling for a couple of weeks, trying to use the Cisco Configuration Assistant, I'm no closer to figuring out how to enter the information you posted. I've type the first line in via telnet but it doesn't accept it. How do I get it setup with the CCA?
Hi, Terry. After getting nowhere, I ended up factory resetting the UC560 and going through the wizard and was able to get it working except for one problem: I have two phones that are at a remote location that will no longer register with the UC560. The UC560 was not being used for VPN as it was sitting behind a Peplink VPN router. The Peplink's haven't been modified so there is no reason to think the problem is there. The phones were communicating with the UC560 before the reset. I have added their MAC address back in but still nothing. I have factory reset the phones and still nothing. I'm clearly missing a configuration step to get these phones at the remote location back online. Any clue what that might be?
