02-18-2015 08:24 AM - edited 03-17-2019 02:01 AM
Hi, I am in the process of configuring and testing SIP trunk with ITSP as a pilot. I have CUCM 8.6 cluster with a bunch of PRIs at the moment and will eventually switch to SIP trunk if testing goes well. Does anyone has a configuration checklist that i can use to configure my CUCM? I will be performing the tests in the production CUCM clusters so don't want to cause any interruption in voice service. Thanks for your help.
~ Khanal
Solved! Go to Solution.
02-18-2015 08:59 AM
Not much to it:
Most of the config/important stuff goes on CUBE, i.e. dial-peers, sip service configuration for which you need to know things such as:
02-18-2015 09:33 AM
Since this is a pilot and you want to test it before you put it into production for all users then you should build separate route patterns/PTs/CSS and assign the CSS to test phones. Also, see if you are using Local Route Group concept for routing these calls, if so you would not need separate PT/CSS/Route Patterns, but simply a new device pool that uses the SIP Route Group as SLRG.
02-18-2015 08:59 AM
Not much to it:
02-18-2015 09:31 AM
Thank you so much Chris. It is very helpful.
Regarding the route patterns, since I already have route patterns pointing to existing route list, route groups and eventually to h323 gateways, do i have to create the same route pattens but put them in a new partition or there is another way to reuse the existing route patterns? Thanks, Khanal
02-18-2015 09:33 AM
