09-04-2012 06:22 AM - edited 03-16-2019 01:01 PM
Hi to all,
I have a small problem with this device:
Please if someone could help me with this.
Solved! Go to Solution.
09-04-2012 06:29 AM
When you do that, you create an FXO to FXO connection. In that case, the DSP must remain in the loop to detect disconnect tones. For that, have
voice-card 0
no local-bypass
Check if that improves the situation.
09-04-2012 06:29 AM
voice-card 0
no local-bypass
09-04-2012 06:52 AM
Thanks a lot, I will try that and post the results.
Going a little further:
09-04-2012 07:51 AM
Voice-card is actually configuration for DSP, where the commands applies.
And, disconnect signal rarely works because telco do not support it. Only accurate tone configuration works.
