UCCX 8.5.1.11003-32 Restore Fail - UCDB component fails
I am in the process of virtualizing and upgrading a UCCX server and I am unable to restore onto my virtual platform.
All components except for "UCDB" restore properly. UCDB fails with the following error, thoughts?
UCCX: 8.5.1.11003-32
----> BEGIN Standard Error
bad decrypt
8977:error:06065064:digital envelope routines:EVP_DecryptFinal:bad decrypt:evp_enc.c:438:
Mon Sep 18 11:15:15 EDT 2017:main:connect() SQLException
Mon Sep 18 11:15:15 EDT 2017:main:handleConnectionException: ErrorCode is -908
No processnode record
Traceback (most recent call last):
File "/usr/local/cm/bin/do_restore.py", line 185, in ?
nodes = len(dbllib.getProcessNodeList(''))
File "/usr/local/cm/lib/dbllib.py", line 741, in getProcessNodeList
raise Exception, "Cannot get processnode list"
Exception: Cannot get processnode list
----> END Standard Error
BradEast1
Level 3
Level 3
Are you using DNS? If so, does the new VM have access?
Thanks for your reply.
DNS is configured in the existing server, the new server does NOT have access to DNS servers.
I can't definitively say that is your issue, but that would be my hunch. You could reach out to TAC for confirmation or maybe someone else has an idea.
Daniov1
Solved?
