06-08-2015 05:57 AM - edited 03-17-2019 03:15 AM
All,
Centralized CM and UCCX. Remote site has SRST. All DNs work fine in SRST mode except for the UCCX numbers. Since WAN connectivity is lost these calls are failing. I am not having any luck with the alias cm-fallback command. I am pretty sure putting the extensionon a phone AND still having it in UCCX will cause a conflict. Any tips on how to handle this is appreciated.
All replies rated.
06-08-2015 07:09 AM
Hi Scott,
The UCCX and CCM integrates with AXL and CTI Route Points and the CTI RPs register to the CCM.
When the WAN link fails, the CTI-RP does get unregistered (I presume) hence the calls to CCX fails.
More over if you could post the topology, it will be more easier to answer the query.
Wilson samuel
06-08-2015 07:27 AM
Thanks. I don't have a Visio at the moment, but it is a hub and spoke design with CM and UCCX at the central site and remote sites connected by an MPLS. The PRI is local to the remote site The CTI-RP does not unregister. What happens is that the call comes into the PRI which normally sends it over the WAN to UCCX. UCCX then sends the call to several phones at the same time at the remote site. When the WAN is down the voice gateway cannot send the calls over the WAN to UCCX and the call fails
06-08-2015 08:27 AM
Hi Scott
You just need to configured SRST to translate the inbound DDIs to hunt groups, or to alias them to specific handsets that will be registered on site when SRST is active...
Aaron
06-08-2015 08:46 AM
Hey Aaron,
Alias was the first thing I tried, but I can't seem to get it to work
06-08-2015 08:51 AM
Thanks for the clarification Scott.
Just wondering, what is the final outcome that you would prefer to happen when the VG is in SRST Mode.
1. All calls that come to the Remote Site (via PRI for the CCX) to be directed towards a bunch phones?
2. All calls that come to the Remote Site (via PRI for the CCX) to be directed back to the PSTN for the HQ?
06-08-2015 12:00 PM
Hello Wilson,
Option 1 is the preferred outcome
06-08-2015 12:14 PM
Thanks Scott,
Could you please post the SRST Config?
06-08-2015 12:34 PM
06-08-2015 07:28 AM
Hi Scott.
What I guess is that you have the UCCX DDIs routed to remote site form TSP and, once the WAN goes down, they are obviously unreachable.
What I can suggest you is to create a backup using BACD feature on remote gateway so that you can still receive calls on those DDIs with a limited service.
Here is a reference doc.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl.pdf
Carlo
