ā05-01-2013 08:58 AM - edited ā03-16-2019 05:05 PM
Hi Everyone,
I have a confusion about licensing on CUCM, I knew that there are DLU's , Node license and application license. But i am quite not sure what these licenses are used for ?
CUCM-USR-LIC-ADD Top Level Sku For Adding User License
LIC-CUCM-USR-A Unified Communications Manager Enhanced Single User-Under 1K
UCSS-UCM-3-1-A UC Manager Enh UCSS Less than 1K users - 1 user - 3 years
LIC-CUCM-BASIC-A Unified Communications Manager Basic Single User-Under 1K
UCSS-UCM-BAS-3-1-A UC Manager Basic UCSS Less than 1K users - 1 user - 3 years
Does anyone have any good document which explains all of these ?
Thanks in advance.
Solved! Go to Solution.
ā05-01-2013 09:02 AM
Hi Pankaj,
You can refer ordering guide
http://www.cisco.com/web/partners/sell/technology/ipc/uc_tech_readiness.html
regds,
aman
Hi Pankaj,
regds,
aman
ā05-01-2013 09:15 AM
Thanks Aman for prompt response.
Is there any tool from which we can fetch all this data depending upon our requirement? Because learning all this is quite not possible, what do you suggest?
Cheers!!
Pankaj Malhotra
ā05-01-2013 09:34 AM
Hi Pankaj,
You can use Dynamic Configuration Tool which is normally used by Pre-Sales guy for making Bill of Quotation [BoQ].
http://www.cisco.com/web/ordering/root/index.html
regds,
aman
ā05-01-2013 09:44 AM
Thanks Aman.
