UCS C210 M2 don´t turn on
wilsonsant
Level 6
Level 6
Hi Guys,
Is this the first experience with UCS C210 M2. I am try install the software CUCM, but, don´t work mouse, keyboard and don´t appear nothing in the video. Is there any initial procedure  to do before start work? I did found nothing error about this.
Wilson
2 Accepted Solutions
Jaime Valencia
Have you already installed ESXi????
Are you connected thru the dongle with the VGA and USB ports??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Wilson,
As I sated above you cannot just install CUCM directly on this server, you need to first install VMWare ESXi 4/5 and then deploy Cisco provided OVAs and install CUCM onto the virtual machine.  Have a look at this doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html
HTH,
Chris
5 Replies 5
Jaime Valencia
java
java
Hi Javalenc,
Thank You for your contact. No, I am not installed ESXi. I am trying install midia CUCM directly.
Wilson
Chris Deren
Did you install VMware ESXi on it?  All applications need to virtulized, you cannot just install CUCM on top of the bare metal server.
Chris
Hi Chris,
As infromed to Javalenc, I am trying install CUCM midia. I don´t have experience about this product. My experience is about MCS 78xx.
Thank,
Wilson
Wilson,
HTH,
Chris
