UCS C240 M3 ESXI 5 Installation "local drive: none"
masroor-ali
I am trying to install ESXI 5.0 on UCS C240 M3 with RAID 5, but getting stuck on selecting disk to install, there are 4 hard drive are installed but showing local: (none).
attached are the snap shot of the installation.
can anyone suggest?
Jonathan Schulenberg
The original ESXi 5.0.0 installer lacked the RAID controller driver. Download VMware-VMvisor-Installer-5.0.0.update02-914586.x86_64.iso and try again.
Please remember to rate helpful responses and identify helpful or correct answers.
hello ,
UCS C220 M4 ESXI 5.5.0 Installation it is showing local drive: none
Remote drive:none
Have you verified your RAID config is OK??
java
if this helps, please rate
