12-21-2015 03:29 AM - edited 03-17-2019 05:18 AM
We are using UCS C240 M4X for our UC applications. It says that UCS C 240 M4X is TRC server for UC applications.
BE7000H (M4)
UCS C240 M4SX TRC#1
Click here for BOM
2RU Rack-mount Server
Dual E5-2660 v3 (10-core, 2.6 GHz)
128 GB RAM
VMware + UC apps boot from DAS (four RAID5 volumes, each of 5x 300GB 15K SFF disks)
Ethernet ports on motherboard + 3rd-party NICs
20 total physical cores ("Full UC Performance" CPU type)
124 GB physical RAM
Four volumes of 1.2 TB each
1x 1GbE for CIMC, 2x 1GbE for LOM, 8x 1GbE for NIC
Above guide says that to use Four virtual drives (VD) with RAID-5 and Each VD has five 300-GB hard drives. But in our UCS 240M4X we only see 6 driver with each 900 GB space then how we can make each VD with five 300-GB HD ?
We are using Cisco 12G SAS Modular Raid Controller (SLOT-HBA) in our UCS 240 M4X.
PID says that it is UCSC-C240-M4S and i can see 20 core on it so i assume it is UCS C 240M4X
TRC doc says to use Four virtual drives (VD) with RAID-5 and each VD has five 300-GB hard drives.That makes total 4X5X300=6000 GB
With 6 drive on my UCS =6X900=5400 GB
Solved! Go to Solution.
12-21-2015 06:25 AM
If your server does not have 20 x 300 Gb drives then it would not be TRC deployment and perhaps it was purchased as Spec based. The current and previous TRC models with part numbers are listed here and I don't see any of the C-series servers with larger than 300 GB drives:
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#C240_M4SX_TRC.231
12-21-2015 06:25 AM
12-21-2015 06:44 AM
+5 for Chris !!
Thanks for response Chris. So if i use Virtual Disk group 1 containing 2X900GB with Raid 1 for Vmware and Virtual Disk Group 2 containing 4X900 GB with Raid 5. Will this configuration supported by TAC ? As i read somewhere that if you are not using Cisco guideline on Raid configuration then Cisco TAC support will not provide any support for cases related to server.
In my case as my server is not TRC bases according to you ( which i agree), there should not be any TAC support problem if i use my mentioned raid configuration. Correct ?
12-21-2015 07:22 AM
If your hardware/configuration is different from the TRC then you are under the Spec-Based guidelines and you are still supported by TAC assuming the Spec-based requirements are met:
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#.22Can_I_use_this_server.3F.22
