UK CME ISDN Dial Plan Help
DOUGLAS DRURY
I'm new to the world of CME.  I really could do with some help configuring incoming and outgoing calling, Internal calling works fine.  I have a UK BT ISDN2E line with 2 channels.  At the moment I'm trying to configure a main number in my lab that would be answered by a receptionists.  My assigned number from my provider is 01779478064 if someone could help me get over this hurdle I would be very grateful as I'm a bit confused by the Cisco books and sample dial plans.  Below is my config.
TS-UCME-01#sh run br
Building configuration...
Current configuration : 8797 bytes
! Last configuration change at 10:55:40 PCTime Sun May 25 2014 by tsadmin
version 15.1
hostname TS-UCME-01
boot-start-marker
boot-end-marker
enable secret 5 $1$B2oE$/iD9ywnNv28iVOQx2e2pQ.
no aaa new-model
clock timezone PCTime 0 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.15.1 192.168.15.9
ip dhcp excluded-address 192.168.15.201 192.168.15.254
ip dhcp pool UCME
 import all
 network 192.168.15.0 255.255.255.0
 domain-name test.local
 dns-server 8.8.8.8
 option 150 ip 192.168.15.1
 lease 0 10
ip domain name test.local
no ipv6 cef
isdn switch-type basic-net3
voice hunt-group 1 parallel
 list 5401,5402
 pilot 2001
voice translation-rule 1
 rule 1 /^.*/ /478064/
voice translation-rule 2
 rule 1 /^478064$/ /5402/
voice translation-profile CALLER_ID_478064
 translate calling 1
voice translation-profile In_2
 translate called 2
voice-card 0
crypto pki trustpoint TP-self-signed-2390328788
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2390328788
 revocation-check none
 rsakeypair TP-self-signed-2390328788
crypto pki certificate chain TP-self-signed-2390328788
 certificate self-signed 01
license udi pid CISCO2811 sn FCZ123570ZM
username tsadmin privilege 15 secret 5 $1$h3QN$JDGfI/oPLZGmIRgLk8.K01
redundancy
no ip ftp passive
interface FastEthernet0/0
 description Phone_LAN
 ip address 192.168.15.1 255.255.255.0
 duplex auto
 speed auto
interface Service-Engine0/0
 ip unnumbered FastEthernet0/0
 service-module ip address 192.168.15.2 255.255.255.0
 service-module ip default-gateway 192.168.15.1
interface FastEthernet0/1
 description Inside LAN
 ip address 192.168.1.253 255.255.255.0
 duplex auto
 speed auto
interface BRI0/0/0
 description Test_ISDN_1
 no ip address
 isdn protocol-emulate network
 isdn layer1-emulate network
 isdn skipsend-idverify
interface BRI0/0/1
 no ip address
 isdn point-to-point-setup
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip route 192.168.15.2 255.255.255.255 Service-Engine0/0
tftp-server flash:phone/sccp6921-6941-6961/SCCP69xx.9-1-1-0.loads alias SCCP69xx.9-1-1-0.loads
tftp-server flash:phone/sccp6921-6941-6961/SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn
tftp-server flash:phone/sccp6921-6941-6961/DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:phone/sccp6921-6941-6961/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:phone/sccp7905/CP7905080003SCCP070409A.sbin alias CP7905080003SCCP070409A.sbin
tftp-server flash:phone/sccp7905/CP7905080003SCCP070409A.zup alias CP7905080003SCCP070409A.zup
tftp-server flash:phone/sccp7906-7911/SCCP11.9-1-1SR1S.loads alias SCCP11.9-1-1SR1S.loads
tftp-server flash:phone/sccp7906-7911/apps11.9-1-1TH1-16.sbn alias apps11.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7906-7911/cnu11.9-1-1TH1-16.sbn alias cnu11.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7906-7911/cvm11sccp.9-1-1TH1-16.sbn alias cvm11sccp.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7906-7911/dsp11.9-1-1TH1-16.sbn alias dsp11.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7906-7911/jar11sccp.9-1-1TH1-16.sbn alias jar11sccp.9-1-1TH1-16.sbn
tftp-server flash:term06.default.loads alias term06.default.loads
tftp-server flash:term11.default.loads alias term11.default.loads
tftp-server flash:phone/sccp7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:phone/sccp7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:P00307020200.bin alias P00307020200.bin
tftp-server flash:phone/sccp7940-7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:phone/sccp7940-7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:phone/sccp7940-7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:phone/sccp7940-7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:phone/sccp7941-7961/SCCP41.9-1-1SR1S.loads alias SCCP41.9-1-1SR1S.loads
tftp-server flash:phone/sccp7941-7961/apps41.9-1-1TH1-16.sbn alias apps41.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7941-7961/cnu41.9-1-1TH1-16.sbn alias cnu41.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7941-7961/cvm41sccp.9-1-1TH1-16.sbn alias cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7941-7961/dsp41.9-1-1TH1-16.sbn alias dsp41.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7941-7961/jar41sccp.9-1-1TH1-16.sbn alias jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:phone/sccp7941-7961/term41.default.loads alias term41.default.loads
tftp-server flash:phone/sccp7941-7961/term61.default.loads alias term61.default.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
mgcp profile default
dial-peer voice 1 voip
 destination-pattern 5499
 session protocol sipv2
 session target ipv4:192.168.15.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 2 voip
 destination-pattern 5498
 codec g711ulaw
 no vad
dial-peer voice 3 pots
 destination-pattern 901779T
dial-peer voice 4 pots
 description In
 translation-profile incoming In_2
 incoming called-number 478064
 direct-inward-dial
 port 0/0/0
telephony-service
 no auto-reg-ephone
 max-ephones 10
 max-dn 10
 ip source-address 192.168.15.1 port 2000
 system message Tekserv IT
 cnf-file location flash:
 load 7915-12 B015-1-0-4.SBN
 load 7915-24 B015-1-0-4.SBN
 load 7916-12 B016-1-0-4.SBN
 load 7916-24 B016-1-0-4.SBN
 load 7906 SCCP11.8-3-3S.loads
 load 7911 SCCP11.8-3-3S.loads
 load 7920 cmterm_7920.4.0-02-00.bin
 load 7960-7940 P00307020200.loads
 load 7941 SCCP41.9-1-1SR1S.loads
 load 7941GE SCCP41.9-1-1SR1S.loads
 load 7961 SCCP41.9-1-1SR1S.loads
 load 7961GE SCCP41.9-1-1SR1S.loads
 load 6921 SCCP69xx.9-1-1-0.loads
 load 6941 SCCP69xx.9-1-1-0.loads
 load 6961 SCCP69xx.9-1-1-0.loads
 date-format dd-mm-yy
 voicemail 5499
 max-conferences 8 gain -6
 hunt-group logout HLog
 moh flash:/Cisco_CallManagerOHM.au
 multicast moh 239.1.1.1 port 16384 route 192.168.1.253 192.168.15.1
 web admin system name phoneadmin password phoneadmin
 dn-webedit
 transfer-system full-consult
 night-service code *1234
 night-service day Sun 07:31 07:30
 night-service day Mon 17:00 07:30
 night-service day Tue 17:00 07:30
 night-service day Wed 17:00 07:30
 night-service day Thu 17:00 07:30
 night-service day Fri 17:00 07:30
 night-service day Sat 07:31 07:30
 directory entry 1 907890757673 name Phil Rennie - Mobile
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn-template  1
 call-forward busy 5499
 call-forward noan 5499 timeout 18
ephone-template  1
 softkeys hold  Join Newcall Resume Select
 softkeys idle  Pickup Dnd Cfwdall Gpickup Redial Newcall Login
 softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback
 softkeys alerting  Acct Callback Endcall
 softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
ephone-dn  1  dual-line
 number 5401
 pickup-group 1
 label Ext - 5401
 description Phil Rennie
 name Phil Rennie
 call-forward noan 5499 timeout 10
ephone-dn  2  dual-line
 number 5402
 pickup-group 1
 label Ext - 5402
 description Doug Drury
 name Doug Drury
ephone-dn  3
 number 1
 name All
 paging ip 239.0.0.1 port 2000
ephone-dn  4  dual-line
 number 5403
 label Ext - 5403
 description Test
 name test test
ephone  1
 device-security-mode none
 mac-address 0012.00EC.B345
 ephone-template 1
 username "phil"
 paging-dn 3
 type 7940
 button  1:1
ephone  2
 mac-address 0012.0101.0C75
 ephone-template 1
 username "doug" password 123456
 paging-dn 3
 type 7940
 button  1:2
 pin 123456
ephone  3
 mac-address 001B.2A89.88B0
 ephone-template 1
 username "test" password 123456
 type 7961
 button  1:4
 pin 123456
line con 0
line aux 0
line 194
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
 transport output telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 194.164.127.6 prefer source FastEthernet0/1
end
TS-UCME-01#
20 Replies 20
Hi Carlo,
I've just added the sugested command.  Below is the sh isdn status
TS-UCME-01#sh isdn stat
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
        ******* Network side configuration *******
        dsl 0, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000003
ISDN BRI0/0/1 interface
        dsl 1, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0x00000000
    Total Allocated ISDN CCBs = 0
Hi Douglas.
If your ISDN is connected to BRI 0/0/0 interface, please modify your config as follows:
remove  isdn protocol-emulate network
Add
isdn static-tei 0
See if it makes any difference
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Yes all works perfectly!  Thanks you very much for your help.
Douglas
Glad that helped Douglas
Thanks for nice rating
Carlo
good to know that :-) +5 to Carlo.
Suresh
Also put below commands under voice port 0/0/0 and test..
compand-type a-law
cptone <as per location>
Suresh
