Unable to Access Services In Cisco IP communicator.
moses.ezra1
Hi All,
I am using CIPC version 7.0.4.0 and CUCM version 10.5.1. When i try to access the Services in CIPC i couldn't use it because it Displaying Select Service...
I also configured the services for this Phone in CUCM.Based on the below link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsem.html
Even then I couldn't solve it and also i visited on the below link to troubleshoot the issue but i couldn't do it .
https://supportforums.cisco.com/discussion/12292751/ip-communicator-service-issue
Is there is any other way to troubleshoot this issue. Here i have enclosed the ScreenShots of CIPC Services,Service Configuration,and Subscribed Services. Kindly Share your Ideas
Thanks in Advance!!!
8 Replies 8
Manish Gogna
With cucm 10.5 you need to use CIPC version 8.6.4
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_4/CIPC_BK_C6B0FEBA_00_cisco-ip-communicator-864-release.html
Manish
Hi Manish,
Once i downloaded i'll try Manish...
Thank you!!!
You need to enable the 'Enable' checkbox in the Service Configuration window
Hi Mohammed,
Thanks even then it is showing the same.....................
-Moses
Please also check if Enable Extension Mobility box is checked at the phone level.
Deepak
Hello Deepak,
Now i enabled that check box deepak, but the problem is now it responding as
Host not Found...  So What would be the Problem? Kindly help me!!
Moses
Change the URL from Host Name to IP Address under System >> Enterprise Parameters >> Phone URL Parameters like below for all the URLs:
http://IPAddress:8080/ccmcip/authenticate.jsp
Deepak
Thank you Deepak i'll Check now.
Moses
