unable to access web interface of 8851
stats
I have now a 3PCC version 8851 and when i try to connect to the web interface it says cisco in title bar and just a spinning hour glass
i have tried multiple browsers and still same issue
factory reset - same issue
software ver sip88xx.11-0-1mpp-477.loads
I am coming from using all Cisco 303 phones with an asterisk server, any help is appreciated
8 Replies 8
Leo Laohoo
11.0(1) firmware.  Wow.  That is really, really old firmware.
It was released way back 29 June 2017.
well this is the version that came with the phone i just bought, which version do you recommend ?
Something recent.
Information i have found to update firmware requires getting into the web interface to change the upgrade settings and using a tftp server, if i cannot get into that what other way can i do this
What kind of browser are you using?
Do you have any browser running on, say, Windows 7 or 8?
I have tried firefox, Chrome and Edge
I only have windows 10 avail
** Update:  I was able to get into the web interface with the old IE only, why is that ??
I suspect Adobe Flash.
Now that you're able to get access, update the firmware and see if it makes any difference with newer browsers.
Upgraded to latest MPP: sip88xx.11-3-3MPP0001-377.loads
https://software.cisco.com/download/home/286319926/type/286320168/release/11.3.3
i can now get to it on chrome
thanks
