Unable to add smart license to CUC 12.5
I am currently running CUC 12.5 and I am having problems licensing with CLI commands.
admin:license smart authorization install "<authorization code>" enter <specificPLR>...
Any help on how this should be enter, I get the error:
Expected 1 mandatory and up 0 non-mandatory parameter(s)
but 14 parameter(s) were found
Executed command unsuccesfully
Error executing command
6 Replies 6
Probably a lot easier to do the setup/connection of smart licensing from the webUI instead of from the CLI. There you basically just set the url to your on-prem SSM, if you have it, and then use a token created in SSM to have the system connect to it.
Response Signature
Unfortunately, my CUC 12.5 is part of a enclosed network.  I do not have the option to set the url.  I absolutely not sure if I am inputting the commands correctly.
Jaime Valencia
Have you reviewed the CLI reference guide?
All the commands and how to use them are explained in there.
java
if this helps, please rate
Are you sure your using the correct command? From what I could tell on our 12.5 CUCs these are the license commands.
If you where to setup the connection to SSM I think the command to use would be license smart register idtoken token_id [force]
Response Signature
admin:license smart reservation install....then when inputting the license it errors out.
Have a look at this presentation from ciscounitytools.com about CUC and SL.
Response Signature
