ā11-09-2017 06:26 PM - edited ā03-18-2019 12:22 PM
Scenario: Call Forward All to a 4 digit TP that expands out to E164 format. 5170 to +13309265170. +13309265170 is a CTI Route Point that CFA's to Unity Call Handler. I can dial 5170 and it works but if I try to CFA it goes lines voicemail box and doesnt forward to the CTI RP. DNA shows it expands and hits the CTI RP but it doesnt hit the Call Handler. If I CFA to +913309265170 it works.
I am so lost any help would be great!
ā11-09-2017 07:20 PM
So, if I understand this correctly
DN 1111 with CFA -> 5170, which is a TP that expands to +13309265170 -> +13309265170 has CFA to VM
You call 1111 with CFA, and end up in 1111's VM, that is the expected behavior as CUC by default uses the original called number to find the mailbox.
You'd need to change the whole system behavior to use the last redirecting number to do that, or try to play with routing rules in CUC.
ā11-09-2017 07:27 PM
So would I have to setup a Direct or forwarded routing rule? I assume it I change the setting use last rather than first it would potentially effect a lot more then just my scenario and Call Handler.
