01-14-2008 08:37 AM - edited 03-15-2019 08:12 AM
Hi all,
I created a TCL script which is geting the call, playing a wave file and route the call to the destination on a callmanager's cluster. If i use it on a Pots dial-peer, it is working good.
If i use it on a voip dial-peer it is working good but if i try to use the pots first, to redirect the IP phone to the phone number of the second dial-peer it is failing. I configured the G711µlaw codec.
Any idea?
Best Regards
Eric
01-14-2008 09:33 AM
Hi Eric,
Call setup in TCL is a "delicate" matter. Ar you using leg setup or handoff ? And what is the other TCL script you mentioned ?
01-14-2008 09:38 AM
Hi Paolo
I use the Leg Setup method. Both scripts are the same, i only configured it on separate routers.
I done a CCAPI inout debug and found the error:
*Jan 14 17:06:45.651: //50454/009E7CBED810/CCAPI/cc_api_get_ssCTreRoutingNotSupported
You can find attached the TCL scritp i use.
thank you for your help.
01-14-2008 10:11 AM
Ok, even before looking at the script, does the call comes in via pots or voip?
Can you please describe very exactly the call flow and the desired re-routing.
01-14-2008 12:54 PM
Sorry, i forgot to mention that:
Call is comming from pots dial-peer, the TCL trigger is on the incoming pots dial-peer. The TCL play the prompt, then the call is routed to the Callmanager. The CCM route the call to the phone but because of a Call Forward All, the call is routed to another GW using the same TCL script. The second TCL script is triggered on the incoming voip dial-peer.
If i test each TCL script seperatly, it is Ok but if i configure the CFA it is a failure.
I tried with a CFNoA and it is working.
It looks like a TCL limitation.
In the Cisco IOS Tcl IVR and VoiceXML Application Guide it is written:
- "When Tcl 2.0 or VoiceXML applications transfer calls to a telephone number, the outbound dial peer can specify a Tcl 2.0 or VoiceXML application to accept the transfer"
and
"Transfer (and handoff) to or from the default application is not supported".
Any idea?
01-14-2008 01:11 PM
OK. So:
pots -> script1 -> CM CFAll -> script2 -> pots
does not work but
pots -> script1 -> CM CFNoA -> script2 -> pots
works, correct ?
Also I suppose script 1 and 2 are actually the same script invoked as a different service and parameters.
If so, it's strange. The only difference should be the redirect reason of the incoming call leg to script2. I suggest you make a debug print of all applicable parameters, and possibly a debug voip dialpeer too.
I don't think the statement mentioned does apply as you are not even doing a proper transfer, just a fresh leg setup.
The second statement is even false because handoff to default application is exactly what B-ACD/AA does for dial-by-extension.
01-14-2008 01:25 PM
Thank you for your point of view.
