Unable to conference more than 4 people in H323.
Siddharam M
i have a CCM cluster located in my central office. and i have a H323 gateway's in all my locations.
I have selected local router as Conference bridge for conferences. I can add upto 4 people in the conference without any issue but when i am trying to add 5th person in conf the 1st participant gets dropped automatically.
I have already set the Maximum ad hoc conference value to 8
CCM v8.5
Router : 2911 and PVDM3-64
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register CFB00077deac9d0
 registration retries 5
 registration timeout 8
 keepalive retries 7
 keepalive timeout 50
 connect retries 5
 connect interval 60
 switchback method graceful
 switchback interval 120
sccp ccm group 2
 associate profile 2 register MTP00077deac9d0
 keepalive retries 7
 connect retries 5
 connect interval 60
dspfarm profile 2 transcode
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729br8
 codec g729r8
 maximum sessions 4
 associate application SCCP
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 3
Can someone help me on this..
Thanks in advance.
Manish Gogna
The default max no of conference participants on IOS CFB is 8. If you already have the cucm service parameter also set to a higher number, then in both the scenarios ( cucm CFB or IOS CFB ) , then you should be able to add more than 4 participants. Can you try a test conference with CUCM based CFB by adjusting the Device pool / MRGL and see if that works or not. A detailed ccm trace for a failed call when adding 5th participant to the conf would be helpful to see what could be going wrong.
Manish
Hi Manish,
I can see below error logs in the CCM trace.. AllocateMtpResourceReq failed is the msg i am getting.
But i don't know what is exactly it means..
MediaTerminationPointControl(3)::getResourcesAllocated -- No matching caps for either side A or side B, MTP not allocated|2,100,17,145046.2^10.18.33.207^Port 20085
MediaTerminationPointControl(3)::getResourcesAllocated -- match1=0 match2=0|2,100,17,145046.2^10.18.33.207^Port 20085
MediaTerminationPointControl(3)::getResourcesAllocated -- allocateErrBitset=0x60|2,100,17,145046.2^10.18.33.207^Port 20085
MediaTerminationPointControl(3)::SendMTPResourceErrToSender - ERROR  AllocateMtpResourceReq failed -- Ci=36867484, errBitset=0x64|2,100,17,145046.2^10.18.33.207^Port 20085
MediaResourceCdpc(159561)::resource_rsvp_AllocateMtpResourceErr Device=MTP_3 deviceCapIntersec=0|2,100,17,145046.2^10.18.33.207^Port 20085
MediaResourceCdpc(159561)::adjustDeviceTblMTP - mCepn=77b46497-ff7e-46ac-93e8-5687856b42c7, allocateErrBitset=0x64, devCapIntersect=0x0, mandatoryCaps=0x0, resourceCount=1|2,100,17,145046.2^10.18.33.207^Port 20085
MediaResourceCdpc(159561)::adjustDeviceTblMTP - Codec Mismatch|2,100,17,145046.2^10.18.33.207^Port 20085
MediaResourceCdpc(159561)::removeDevicePidTableEntry - cepn=77b46497-ff7e-46ac-93e8-5687856b42c7 deviceName=MTP_3 deviceTblSize=3|2,100,17,145046.2^10.18.33.207^Port 20085
MediaResourceCdpc(159561)::waiting_MrmAllocateMtpResourceReq - CI=36867484 Count=1 TryPassThru=0|2,100,17,145046.2^10.18.33.207^Port 20085
Issue  is happening only to my remote locations, the main office where my CUCM cluster is located i have not observed any issue.
I am attaching my g/w router config. pls let me know if any issue related to config.
Sid
