Unable to configure CfwdAll on CME
Translator
Community Manager
Community Manager
Hello, it became necessary to turn on call forwarding at the reception area, where all the landline phone calls are being received. When the phone calls are being forwarded to the mobile, all calls arriving at the landline number are being dropped. I will be grateful for help in solving the problem
voice translation-rule 1
rule 1 /5991979/ /1000/
voice translation-rule 2
rule 1 /^9\(.*\)/ /\1/
voice translation-profile Income
translate called 1
voice translation-profile SIP_Out
translate called 2
telephony-service
no auto-reg-ephone
max-ephones 20
max-dn 20
ip source-address 192.168.99.1 port 2000
calling-number local
timeouts interdigit 3
cnf-file location flash:
load 7942 SCCP42.9-4-2SR3-1S.loads
time-zone 34
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 5991979 extension-length 3 no-reg
voicemail 850
max-conferences 8 gain -6
call-forward pattern 9T
call-forward pattern .T
call-forward system redirecting-expanded
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9T
transfer-pattern .T
ephone-dn 2
number 1000
pickup-group 10
name Reception
corlist incoming International
no huntstop
transfer-mode consult
TONY SMITH
I guess from the profile called "SIP_Out" that your external calls are carried by a SIP provider. Have a look at SIP debugs (debug ccsip mess) for a forwarded call, that will tell you whether your configuration is trying to forward the call but the carrier is rejecting it.  Or whether it's not even trying.  You should see an outbound INVITE almost immediately after the inbound.
